POV-Ray : Newsgroups : povray.general : No ground fog, why? Server Time
21 Jun 2026 03:44:52 EDT (-0400)
  No ground fog, why? (Message 1 to 10 of 13)
Subject: No ground fog, why?
Date: 20 Sep 2000 10:16:41
Message: <39C8C6BF.451310E2@alleganisd.org>
Here is a scene I am trying to render with POV 3.1g for win 98.
No ground fog ever appears. Why?
// Persistence of Vision Ray Tracer Scene Description File
// File: ?.pov
// Vers: 3.1
// Desc: Basic Scene Example
// Date: mm/dd/yy
// Auth: ?[esp]
#version 3.1;
#include "tex.inc" //contains the texture definition.
global_settings
  assumed_gamma 1.4
default {texture {pigment {color Red}} }
//#include "fog.inc"
fog { fog_type 2 //Layer: Layer2
    rgb <0.620, 0.000, 0.000>
    fog_offset 6
    fog_alt 0.5 //fade away rate
} //fog
camera
  location  <0.0, 0.5, -4.0>
  direction 1.5*z
  right     4/3*x
  look_at   <0.0, 0.0,  0.0>
sky_sphere
  pigment
    gradient y
    color_map { [0.0 color blue 0.6] [1.0 color rgb 1] }
light_source
  0*x // light's position (translated below)
  color red 1.0  green 1.0  blue 1.0  // light's color
  translate <-30, 30, -30>
light_source
  translate <30, -30, -30>
//#include "shape.inc" //has preview shape
plane { y, -1 pigment {color rgb <0.7,0.5,0.3>}}
sphere { 0.0, 1 //start of shape
    texture { Texture1 }
} //Sphere
See my Free stuff page. It compares free website providers, and
lists free internet access providers.
http://www.crosswinds.net/~robertsc/free.htm
Win98 help file loaded with hints and tips, including securing a
Win 95/98 PC in a classroom setting. VB4 help file with lots of
code and hints.
At http://www.crosswinds.net/~robertsc/
Subject: Re: No ground fog, why?
Date: 20 Sep 2000 10:36:38
Message: <39c8cb76@news.povray.org>
Put the keyword "hollow" into the sky_sphere.
Date: 20 Sep 2000 11:08:00
Message: <39c8d2d0$1@news.povray.org>
In article <39c8cb76@news.povray.org> , "Bob Hughes"
This is nonsense.  They keyword hollow does not belong in the sky_sphere (in
fact it won't work there at all!).   sky_sphere does not have any volume, it
is infinite - otherwise you would also get the "camera in non-hollow object"
warning!   sky_spheres are explained in the POV-Ray manual.
Now to the problem. Simply add the "distance [value]" to the fog statement,
for example:
    distance  20
    fog_offset 6
} //fog
This will make the fog very visible.
      Thorsten
Date: 20 Sep 2000 11:20:53
Message: <39C8D5CA.457A2CF7@alleganisd.org>
Thank you, that worked. The help file led me to believe that
"distance" was only for type 1 fog.
> for example:
>     distance  20
>     fog_offset 6
> } //fog
>       Thorsten
code and hints.
Date: 20 Sep 2000 11:21:04
Message: <39C8D5D6.5C59A7B7@alleganisd.org>
> for example:
>     distance  20
>     fog_offset 6
> } //fog
>       Thorsten
code and hints.
Date: 20 Sep 2000 17:03:50
Message: <39C926BB.1B23DBF2@club-internet.fr>
Just for a try. Does 'inverse' to the plane resolve the problem as well ?
Fabien H
> > for example:
> >     distance  20
> >     fog_offset 6
> > } //fog
> >       Thorsten
> code and hints.
Date: 20 Sep 2000 23:07:35
Message: <39c97b77@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:39c8d2d0$1@news.povray.org...
(in
it
object"
Curiously the Scene Help doesn't mention that fact in the section The Sky
Sphere or the fog sections either from what I could see there.
I hate to lead people astray like that, sorry.  Glad you corrected me
Thorsten.
I still use sphere instead of sky_sphere so much it's second nature to add
hollow to that anyway.  Guess when I make the mistake and get the error when
putting hollow into one that I don't think twice about it and remove it.
Date: 20 Sep 2000 23:09:44
Message: <39c97bf8$1@news.povray.org>
news:39C926BB.1B23DBF2@club-internet.fr...
Shouldn't.  The normal of a plane isn't flipped when the float is negative,
only when the plane normal itself is negative.  Inside and outside of a
plane remains constant otherwise.  Unless I'm wrong about that too.
Date: 20 Sep 2000 23:33:59
Message: <39C980FA.40792639@pacbell.net>
You may be suffering from one of those misconceptions that Warp has
been talking about. A sky_sphere is not a sphere object. It is more
like the background feature that has spherical pigment properties.
Date: 21 Sep 2000 02:52:00
Message: <39c9b010@news.povray.org>
Thorsten Froehlich <tho### [at] trfde> wrote:
:> Put the keyword "hollow" into the sky_sphere.
: This is nonsense.  They keyword hollow does not belong in the sky_sphere (in
: fact it won't work there at all!).   sky_sphere does not have any volume, it
: is infinite - otherwise you would also get the "camera in non-hollow object"
: warning!   sky_spheres are explained in the POV-Ray manual.
  Perhaps it could be a good idea to actually TEST the suggestion between
posting it. :)
