POV-Ray : Newsgroups : povray.general : Blasted infernal image maps III Server Time
12 Sep 2025 05:15:49 EDT (-0400)
  Blasted infernal image maps III (Message 1 to 7 of 7)
Subject: Blasted infernal image maps III
Date: 21 Aug 2000 09:23:05
Message: <39A12C03.67836EED@my-dejanews.com>
I want a mesh object to have a texture, say
    #declare Texture001= .........................
And then to have an image map applied as a decal in one small place on
it. (Application: a serial number on a military object).
How do I do this?
Simply puting an image map ontop of or after the texture declaration
makes the whole object transparent!
Also, what should the image be?  I want a text decal, so I made it a TGA
in a paint program, where I "masked out" the non-letter parts of the
image.
BTW I did RFTM. It is _____________.
Subject: Re: Blasted infernal image maps III
Date: 21 Aug 2000 10:11:15
Message: <39A138A9.679796E7@schunter.etc.tu-bs.de>
> How do I do this?
Are you sure ?
If you use the image_map texture as the top layer in a layered texture, things
should work.
> image.
You should make it a 256 color png and use:
  image_map {
    png "mypic.png"
    once
    transmit 1, 1.0
then all pixels with index 1 are completely transparent.
Date: 21 Aug 2000 11:25:23
Message: <chrishuff-BFFD82.10264321082000@news.povray.org>
In article <39A12C03.67836EED@my-dejanews.com>,
One way: use a pigment_map to constrain the image_map to the area of the
decal, scale/translate/rotate the image_map to fit, and leave the rest a
transparent texture. Make this a texture layer on your object.
Did you put the image_map in it's own texture{...} block? Otherwise, I
think you are just modifying the original texture, not creating a new
one and layering it onto the object.
Christopher James Huff
Date: 21 Aug 2000 13:29:37
Message: <39A165C1.266BA168@my-dejanews.com>
I went:
object {MyObject01
    scale, rotate,translate
    texture {MyTexture01}
    pigment {image_map....
How should this be done?
Date: 21 Aug 2000 13:51:04
Message: <chrishuff-E6CF32.12522621082000@news.povray.org>
In article <39A165C1.266BA168@my-dejanews.com>,
> I went:
> object {MyObject01
Try:
object {MyObject01
    texture {pigment {image_map....}}
Date: 22 Aug 2000 08:15:06
Message: <39A26D99.A3C973CA@my-dejanews.com>
> Try:
> object {MyObject01
Yes, that was perfect. It's funny how I had to add the texture {} around
the image map in order for it to work.
For this model, it was created with Z as the up dimension and so I had
to do a lot of rotation, etc., in order to get it to aligned properly
for application of the decal.
Date: 22 Aug 2000 11:26:36
Message: <chrishuff-88756D.10275922082000@news.povray.org>
In article <39A26D99.A3C973CA@my-dejanews.com>,
Not really...before, you were just modifying the pigment of the existing
texture. With the texture{} block, POV knew you were making a new
texture to layer on top.
