POV-Ray : Newsgroups : povray.general : output options Server Time
26 Mar 2026 16:43:04 EDT (-0400)
  output options (Message 1 to 10 of 10)
Subject: output options
Date: 2 May 2000 10:30:56
Message: <390ee6a0@news.povray.org>
I was trying to use these commands in my ini file for an animation:
Preview_Start_Size = 8
Preview_End_Size = 8
It started with the size of 8, but completed the image with size of 1 - but
I want it to complete with size of 8.
Why does it do that?  What is wrong with my statements?
Mike
wk: mik### [at] pyxiscom  www.pyxis.com
hm: mwe### [at] sciticom  www.geocities.com/mikepweber
Subject: Re: output options
Date: 2 May 2000 12:26:33
Message: <390f01b9$1@news.povray.org>
In article <390ee6a0@news.povray.org> , "Mike Weber" <mik### [at] pyxiscom>
Nothing, this is exactly how it works. It is _preview_ only as clearly
explained in the documentation. If you set the end size smaller, it will
first generate previews down to that resolution and the switch to the final
step with full resolution.
If you want it to end with 8, just divide the image width and height by 8,
which gives you exactly the result (preview is not needed for this). Then
scale the image to 800% in a paint program. This will have (nearly) the same
effect as preview 8.
     Thorsten
Date: 2 May 2000 12:43:00
Message: <wQMPOeJMhrFploOf6EI9BMXJF+B+@4ax.com>
On Tue, 02 May 2000 11:26:25 -0500, "Thorsten Froehlich"
Of course, the paint program needs to be the type that doesn't
interpolate when scaling an image 8 times larger. The nicer programs
interpolate by default, and often have no way to turn it off. Older
versions of simpler programs like LView Pro (windows software) will
scale an image upward without interpolation.
Hmmm, I wonder if interpolation is the correct term to use when
talking about up-sizing an image? Would the more technically correct
term actually be extrapolation? It would seem that way to me, but I
have never heard anyone refer to it like that.
Later,
Glen Berry
( Remove the "7" from 7no### [at] ezwvcom to email me. )
Date: 2 May 2000 14:12:56
Message: <390f1aa8$1@news.povray.org>
According to the POV help:
The process continues until it reaches 1*1 pixels or until it reaches the
size you set with Preview_End_Size=n or +EPn. Again the value n should be a
number greater than zero that is a power of two and less than or equal to
Preview_Start_Size. If it is not a power of two, the nearest power of two
less than n is substituted. The default ending value is 1. If you set
Preview_End_Size to a value greater than 1 the mosaic passes will end before
reaching 1*1, but POV-Ray will always finish with a 1*1. For example, if you
want a single 8*8 mosaic pass before rendering the final image, set
Preview_Start_Size=8 and Preview_End_Size=8.
And that's what I did.  Now I understand - it will go from 8, then to 1,
instead of 8,4,2,1 - hmmm - too bad - that's not what I want to do.  Its for
an animation of 450 frames - and to render a very small image, then resize
it larger for 450 frames is a lot of work.  I guess letting it run overnight
is what I need to do....
Mike
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:390f01b9$1@news.povray.org...
but
final
same
>      Thorsten
Date: 2 May 2000 15:01:19
Message: <390f25ff@news.povray.org>
In article <390f1aa8$1@news.povray.org> , "Mike Weber"
Well, this is a different problem: You can try to use QuickTime Movie Player
(Pro edition) to generate an animation out of the sequence of images
automatically. You can the scale the whole movie up at once.
     Thorsten
Date: 2 May 2000 16:00:46
Message: <390f33ee$1@news.povray.org>
I use cmpeg to compose the animation from a batch file.
I see that DTA can:
(Geometrical transformation options)
    /SC[#,#[,#]]   Rescale pictures to screen res. or specified size
    /SCF[#,#[,#]]  Fast, but dumb, rescale
but how do you use that?
/SC[newx, newy]
anyone know?
Mike
news:390f25ff@news.povray.org...
for
resize
overnight
Player
>      Thorsten
Date: 2 May 2000 18:11:39
Message: <kakugskkdrhcs4951o0nm0mlq9k2g3o8rh@4ax.com>
On Tue, 02 May 2000 12:42:58 -0400, Glen Berry <7no### [at] ezwvcom>
Interpolation it is. If you scale an image up 8 times, the only values
you know for certain are those located at pixels with coordinates
which are exactly divisible by 8. The ones in between have to be
interpolated.
Peter Popov ICQ : 15002700
Date: 2 May 2000 18:41:05
Message: <390f5981@news.povray.org>
Uh, ignore my first reply here, I was pretty sure I knew the answer.
I know it partially anyhow.  It is like you thought for the new x and y
dimensions.  I was almost positive the third number was for color
depth.
I still have DTA on this machine so I checked on that.
I could only get the two numbers to be used meaningfully.  What the
third optional number is I couldn't say.  I managed to do a:
dta test.tga /iscaled.tga /ft /sc,8  (but not without comma)
to be without error except the saved targa wasn't anything.
Trying:
dta test.tga /iscaled.tga /ft /sc320,240,8
fails, so it appears to be neither color depth nor predefined resolution.
"Mike Weber" <mik### [at] pyxiscom> wrote in message
news:390f33ee$1@news.povray.org...
| I see that DTA can:
| /SC[newx, newy]
| anyone know?
| Mike
| for
| resize
| overnight
| Player
| >      Thorsten
Date: 2 May 2000 18:45:14
Message: <390f5a7a$1@news.povray.org>
I was trying /sc[500,500] - but that didn't work.
After reading below /sc500,500 works great!
Thanks for everyone's help!  Now I can do very small framed animations,
batch convert to resize, batch run cmpeg and I'm there!
Mike
"Bob Hughes" <per### [at] aolcom?subject=PoV-News:> wrote in message
news:390f5981@news.povray.org...
> depth.
> Trying:
> Bob
> | I see that DTA can:
> | /SC[newx, newy]
> | anyone know?
> | Mike
to 1,
Its
> | for
> | resize
> | overnight
> | Player
> | >      Thorsten
Date: 3 May 2000 00:09:13
Message: <390fa669@news.povray.org>
I think that "bilinear filtering" is also another way of saying the same
thing.
