POV-Ray : Newsgroups : povray.general : Isosurface hills Server Time
26 Apr 2026 08:31:38 EDT (-0400)
  Isosurface hills (Message 1 to 10 of 16)
Subject: Isosurface hills
Date: 15 Mar 2000 21:17:37
Message: <38D04586.4AB9@aol.com>
I'm hoping to make an image which will mostly be a series of grassy
hills in the rain. I've got the clouds, I think, and the rain's a task
I'm willing to take a shot at. Grass will be a nightmare of its own and
obviously a lot of fudging is required. I've started working with the
hills, but that's where I've run into the first problems.
I really don't want to generate any height maps for this one. My
preference is to use an isosurface (I'm using the Superpatch) with a
kind of hilly function. I thought of multipying a couple of sine waves
together, but the results on that have so far been pretty terrible.
For those who are interested in knowing more, this is meant to be the
background for a CD cover (I'll be putting an object in the foreground
of the front half), so it will be a 2x1 aspect ratio.
And hey, if anyone has any advice on rendering liquids and radiant
objects (in this case both), *any* advice would be appreciated.
Lummox JR
Subject: Re: Isosurface hills
Date: 16 Mar 2000 23:48:30
Message: <tNoMMDA4RW04Ew8c@econym.demon.co.uk>
Rather than using sin waves, you might find it better to start with an
isosurface of the y plane [ function {abs(y)} ] and then add some random
hilly bumps by subtracting a noise function or a pigment function, like
    function { abs(y) - noise3d(x,0,z)*0.5 }
It's possible to add a suggestion of ground cover (unfortunately, not
particularly grassy) foliage by subtracting another noise or pigment
function at a much smaller scale, like
               -noise3d(x*100,0,z*100)*0.02
Mike Williams * ##
Gentleman of Leisure
Date: 17 Mar 2000 22:01:59
Message: <38D2F2F4.30B8@aol.com>
I took your advice on the basic hill structure (haven't gotten as far as
ground cover yet) and used a formula that was basically
y-noise3d(x,0,z), with a little noise added to x and z as well to
turbulate it a bit.
Unfortunately, although the basic shape is right, I've run into an
interesting problem: Because the noise function is clipped to values of
0 to 1, most of the resulting hills have flat surfaces.
The only good solution I can think of would be to modify the f_func.c
file (I've made extensive modifications already, so this isn't entirely
out of the question) to include an unclipped noise function. (Too bad
the function doesn't allow a user-specified pre-clip scaling to avoid
that.) I'm not particularly anxious to try that tack if something better
can be achieved with the version I'm already using.
I'm going to try some alternate versions like 4*n*(1-n), which should
just give me a lot of valleys instead, and see if that works any better.
In the meantime, suggestions are still much appreciated.
Lummox JR
Date: 18 Mar 2000 03:28:23
Message: <38D33F32.944064C4@unforgettable.com>
> turbulate it a bit.
I vaguely remember someone complaining about a similar problem, and
noting that using dents as a function eliminated the plateaus.
Xplo Eristotle
http://start.at/xplosion/
Date: 18 Mar 2000 09:36:49
Message: <chrishuff_99-ABC303.09384918032000@news.povray.org>
In article <38D33F32.944064C4@unforgettable.com>,
It doesn't eliminate them, but it makes them less noticeable. It just
cubes the noise3d function, which makes the change in curvature almost
invisible.(and I think it is one of the functions which has a special
evaluation method for normals in the official version)
Chris Huff
e-mail: chr### [at] yahoocom
Date: 18 Mar 2000 09:44:15
Message: <chrishuff_99-5EB259.09461518032000@news.povray.org>
> turbulate it a bit.
This is a known problem, one which I wish would get fixed soon. It also
occurs with things like the bozo pattern(which is actually identical to
noise3d()).
I hope someone does it soon. I don't know enough about that kind of
function to do anything, but as I understand it, it would be a fairly
simple modification in one of the hash functions or in the Noise()
function.
What are the modifications you have made? Potential new features?
You might be able to disguise the plateaus by using multiple calls to
noise3d() with different values added to the x, y, and z parameters for
each(to translate the resulting patterns so they don't just reenforce).
Chris Huff
Date: 18 Mar 2000 13:12:14
Message: <38D3C84E.65E7@aol.com>
> noise3d()).
Exactly. Another problem I knew people had was that when seen from a
distance, the noise3d() function can have a sort of quilted look to it
because of how the noise function behaves at near-integer values. I
turbulated x and z a bit to get rid of that (or at least disguise it by
varying the lines).
> function.
Modifications I've made so far to the function code:
- Added functions floor(), ceil(), if() (like the C ?: operator),
  pi, clock, atan2(), radians(), degrees()
- int_func3d() was completely rewritten and evaluate_interval()
  changed to allow interval (method 1) testing which wasn't possible
  before
- norm_<function> functions added to evaluate an exact normal where
  possible (using a new "normal" keyword as part of an isosurface,
  parametric, or my own isoblob)
I figure an unclipped noise function would probably be extremely
beneficial--especially since raw noise is centered about 0 instead of
0.5. (I also considered running noise through something like a sigmoid
function to constrain it to 0-1, but I think the result would look just
terrible.)
Well, I found out that 4*n*(1-n) didn't really work out all that well.
Problem is, of course, that 0.5 (where this hits its maximum) is all too
common a value for noise. Although it doesn't much show in the test
images, this would tend to generate ring-like hills. Squaring or cubing
noise to eliminate the plateaus didn't help either.
My best results came from adding several n*(1-n) values together and
then scaling them to fit within the 0-1 range, but even then the
structures were kind of strange and not very hilly.
I think I'll just go ahead and add an unclipped noise function to the
code; I may as well at this point. I just need something to call it
other than noise3d(), and I'll need to rewrite the interval function to
compensate for the fact that this can reach values beyond the 0-1 limit.
Lummox JR
Date: 18 Mar 2000 14:13:00
Message: <chrishuff_99-3077B0.14145918032000@news.povray.org>
> > noise3d()).
> varying the lines).
> > > entirely
> > > better
> > function.
These sound interesting...I notice that they have already been included
in MegaPOV.
>   before
Could you clarify this? I don't really understand what you mean.
Is this related to the second normal calculation method, also included
in MegaPOV?
Could you add 4D noise while you are at it? :-)
I think this might be useful for some things, maybe for fire.
Chris Huff
Date: 18 Mar 2000 16:38:04
Message: <38D3F88C.7F17@aol.com>
> in MegaPOV.
Hmmm... I wonder if they're mine.
All those function changes I sent out to Ron Parker for the Superpatch.
The isoblob patch I don't think is in there, though.
> >   before
Interval testing works for most functions, but it doesn't work for a
function within a function. Example:
#declare F1=function {cub(x)+sqr(y)}
#declare F2=function {F1(x,y)-F1(y,z)}
An isosurface using function F2 can't use method 1 because the intervals
for F1 aren't tested properly. I rewrote int_func3d, which was basically
just an empty do-nothing function, to act the way it was supposed to in
the first place.
> in MegaPOV?
That I wouldn't know; I haven't seen MegaPOV or its source. For all I
know it might be based on my patch--if you have the source, my name
should be plastered all over f_func.c and several related files if it's
based on my code.
Funny, but I was thinking along the exact same lines earlier when I was
modifying the code. It occurred to me that it would be nice to have an
N-dimensional noise function. Many a time I've wanted to have 4D noise
for clouds and such. If I understand the Noise() code well enough,
basically all you'd have to do would be to recurse the sucker. This
could extend noise to as many dimensions as you'd want, if it was done
right. (Of course, some preprocessing would help to prevent a lot of
useless recalculations, since speed is always a factor.)
I really don't know how this could be included in the function code
without greatly modifying it, since the code wasn't intended to go past
3 arguments per function. (The so-called 4-argument functions are
actually just a declared function number plus 3 more arguments.) I've
always wanted to see if that could be arbitrarily extended; the
challenge is definitely intriguing enough for me to take it up sometime.
BTW, I've gone ahead and added the Noise_raw function to texture.c. I
gave it a function name "bozo", to avoid having to add one more keyword
to the parser.
I added two new functions while I was in there:
range(v,min,max)  -- basically a shortcut for min(max(v,min),max)
bozo(x,y,z) -- raw noise
Lummox JR
Date: 18 Mar 2000 17:28:46
Message: <chrishuff_99-F7DCC7.17304618032000@news.povray.org>
Yep.
In where? MegaPOV, or the source changes you sent to Ron? The isoblob
patch is included in MegaPOV, if that is what you meant.
> based on my code.
Ah, ok. I somehow had the impression you were using MegaPOV source as
your base. I found the code neatly arranged in a single block starting
with this:
#ifdef IsoBlobPatch
/* Functions added by Lummox JR, June 1999 */
I would certainly be interested in the results. It would also be nice to
allow user defined functions to have a variable number of parameters,
how possible do you think that would be?
> to the parser.
Sounds interesting, although the use of "bozo" would have to be changed
before it is distributed...
Maybe call it rnoise()?
Why not call it "clamp()"? I think it is more explanatory.
BTW, I use this code when I need this function, although having it hard
coded is probably a good idea:
#declare clamp = function {min(y, max(x, z))}
clamp(value, minimum, maximum)
Chris Huff
