POV-Ray : Newsgroups : povray.general : 3dnoise docs Server Time
16 Jan 2026 15:55:28 EST (-0500)
  3dnoise docs (Message 1 to 10 of 12)
Subject: 3dnoise docs
Date: 7 Dec 1999 17:30:10
Message: <384D89BC.E40F3EC6@my-dejanews.com>
The version of superpatch that I d/l  had no explanation of 3dnoise.
Do the instructions for this feature exist on the web?
Subject: Re: 3dnoise docs
Date: 9 Dec 1999 07:44:57
Message: <384FA392.DA44408C@my-dejanews.com>
PLEEEEEEASE?????????
Date: 9 Dec 1999 08:09:24
Message: <chrishuff_99-29E48D.08094609121999@news.povray.org>
In article <384FA392.DA44408C@my-dejanews.com>,
You probably mean noise3d(). It is just another isosurface function,
which takes 3 parameters, x, y, and z coordinates for the evaluation
point.
For example:
isosurface {
    function {noise3d(x*2, y*0.2, cos(z))}
    threshold 0.5
Chris Huff
e-mail: chr### [at] yahoocom
Date: 9 Dec 1999 08:53:26
Message: <384FB39F.7E8E599D@my-dejanews.com>
Yes, I'm wondering about the parameters that can go into the equation.  I've
made things that look OK with just linear modifications to x,y,z.  Is there
a source doc or source paragraph somewhere?  I was told that they just plain
forgot to include this in one of the latest releases of superpatch.
I'm also wondering about bounding isosurfaces with isosurfaces.  I actually
wanted a fine-pitch noise3d to show up only where a large scale noise3d
exists.  What I have tried so far (CSG) only leads to the intersecting
surfaces. . .
> point.
> For example:
> isosurface {
>     threshold 0.5
> Chris Huff
> Web page: http://chrishuff.dhs.org/
Date: 9 Dec 1999 09:20:48
Message: <384fbac0@news.povray.org>
"They" would be me.  There are a lot of neat tricks you can do with isosurfaces
that aren't documented with the superpatch.
noise3d takes three parameters, x, y, and z.  What you choose to give it for
those parameters is entirely up to you, and limited only by your imagination.
If you want a cyclic noise, for example, you can feed it a cyclic function as
a parameter, such as
 #declare x_cyclic_noise = fucntion {noise3d( 20*sin(x/20), y, z)}
There is no way to bound an isosurface with anything but a box or a sphere,
due to the way the code is written.  I may try to fix this one day soon,
depending on many factors I won't discuss right now.  You can, however,
create a function that intersects two isosurfaces without using CSG. Try
this and see if it's what you're looking for, but I suspect it'll look
like what you got with intersect:
 #declare noisynoise = function {noise3d( x,y,z) & noise3d(20*x,20*y,20*z)}
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 9 Dec 1999 10:54:48
Message: <384FD0CB.5EBA203A@inapg.inra.fr>
If this can be of help (and this is from memory), if you use a simple
noise3d(A*x,B*y,C*z) function
(which is a very restrictive way to use it, because you can put anything
in noise3d(u,v,t))
then the larger A, B and C are the smaller the "bumps" are.
- noise3d(x,y,z) will give you bumps evenly spaced
- noise3d(0.1*x,y,z) will give you bumps scaled by a factor 10 on the x
axis
Multiplying the noise3d by a value will help control how much they affect
the general shape
10*noise3d(x,y,z) -> big effect
0.1*noise3d(x,y,z) -> small effect
Of course "big", "small" are all relative to the other parts of the
isosurface equation and may make no sense at all in many situations.
The best way to test noise3d effects is to make a simple isosurface
primitive (like a sphere or  a box) and then add the noise3d part to it.
//sphere :
isosurface{
        function{x*x+y*y+z*z + 0.1*noise3d(5*x,5*y,5*z)        }
        bounded_by {sphere {0,2}}
        eval            sign 1        threshold 1
        texture{pigment{Red}}
//box
isosurface{
        function{abs(x)&abs(y)&abs(z) +0.1*noise3d(5*x,5*y,5*z)}
        bounded_by {box {-2,2}}
G.
Date: 9 Dec 1999 13:15:16
Message: <384FF0FD.2595CE04@my-dejanews.com>
Thanks greatly.
Q1:  Here's a math question.  For what values of the function  will I get "nothing"
to show up? negative??  >>threshold??
For example, if I want the noise3d function to be terminated above y=0, there are a
bunch of ways to do this with CSG. All of these would be a harsh cut.   I am
betting there is a way to make a very smooth termination of the function by playing
with the threshold values.
I guess that something like,
isosurface{
               fucntion {noise3d( x, y+9.5, z)}
               threshold 10
might do it, but I'm not sure.
I have actually received advice on the topic before, but I never got a firm handle
on the actual **MATH** behind the function.
Q2:  So what are the operational thingies that work with the isosurface?
    & is and or intersection,
______________
Greg M. Johnson  (Opinions not necessarily those of a povray user).
http://members.xoom.com/gregjohn/animation.html
Date: 9 Dec 1999 13:38:23
Message: <384ff71f@news.povray.org>
Probably not.  what you need to do is add on some function that stays constant
below y ~= 10, then drops smoothly as you approach y=10.  I'm not sure there
are any non-piecewise functions that do that, but you might be able to
approximate it with the right sort of asymptotic function.  If you're using
the preliminary 3.1g superpatch, you'll find that there's a ?: operator in
there that might make piecewise functions possible, but that version has
other problems you might wish to avoid.
>isosurface{
>               threshold 10
Almost definitely not.  The function you've specified there is just the regular
noise3d function translated downward 9.5 units, but the threshold of 10 will
ensure that you only see a solid block, since the noise3d function never goes
above ten (it rarely goes above one.)  (I see you mistyped 'function' the
same way I did. :) )
There's also |, which is merge.  I'm not sure what else there is, believe it
or not.
Date: 9 Dec 1999 16:33:56
Message: <38502008.90A09A76@t-online.de>
> //sphere :
> isosurface{
> //box
> isosurface{
You aren't even restricted to apply noise3d to a basic shape like sphere
or box as a whole, but you also might do so to selected terms, so try
something like that too:
isosurface{function
		{x^2 +(y+0.3*noise3d(1, y/3, 1))^2 +z^2 -3}
nor there is any restriction on "mixing up" the noise3d parameters in a
manner like that:
		function{noise3d(y^2+z^2, x^2+y^2, x^2+y^2)}
again, play around with this stuff and enjoy the mostly strange but
sometimes also useful effects, that will occur. That's the best
tutorial.
ReVerSi
Date: 9 Dec 1999 19:02:15
Message: <chrishuff_99-102C98.19023709121999@news.povray.org>
In article <384FF0FD.2595CE04@my-dejanews.com>,
Here is a list of the functions, operators, and keywords available in
the isosurface functions, I am not sure where I got it or if it is
complete, though.
x  y  z
abs  sqr  sqrt  cub  exp
sin  asin  sinh  asinh
cos  acos  cosh  acosh
tan  atan  tanh  atanh
min  max  noise3d
In the Smellenbergh Multipatch, there is also a if() function. I don't
know if it is in the Superpatch. I think it is used like:
if(A, B, C)
If A is true, B is used, otherwise, C is used.
& is AND, it is used like: funcA() & funcB(). The resulting isosurface
is like an intersection of funcA() and funcB().(all points where both
funcA AND funcB are below threshold)
| is OR, it is used like the same as &. The resulting isosurface is like
a merge of funcA() and funcB().(all points where either funcA OR funcB
^ is not XOR, it is the power operator. a^b means a to the power of b.
% id probably modulus, although I have never used it. a%b is the
remainder of a/b.
The others are pretty self explanatory or documented functions identical
to the normal POV versions.
Chris Huff
