POV-Ray : Newsgroups : povray.general : Any way to avoid repeated parsing? Server Time
17 Jan 2026 00:26:45 EST (-0500)
  Any way to avoid repeated parsing? (Message 1 to 10 of 52)
Subject: Any way to avoid repeated parsing?
Date: 16 Sep 1999 14:24:52
Message: <37e135f4@news.povray.org>
Is it necessary for POV-Ray to parse a file separately for each view of the
same scene?  Is there any way to "save" the result of the parsing to use in
repeated raytracings from different views?
Thanks in advance for any help with this.
-John VanZwieten
Subject: Re: Any way to avoid repeated parsing?
Date: 16 Sep 1999 15:09:40
Message: <37e14074@news.povray.org>
Hmmm, to view other camera angles reparsing is needed because of the
change in rays going to/from objects.  Their profiles are always going
to be different, well that's my guess anyhow.  Parsing was improved as
I recall for multiple frames or renders of the same scene but think
you're talking about keeping a memory map of sorts which considers any
and all changes to camera position.  Of course if a scenes objects,
etc. change with time then the question is probably moot.
John VanZwieten <Joh### [at] emailmsncom> wrote in message
news:37e135f4@news.povray.org...
of the
use in
> -John VanZwieten
Date: 16 Sep 1999 15:19:54
Message: <37e142da@news.povray.org>
Bob Hughes <inv### [at] aolcom> wrote in message
news:37e14074@news.povray.org...
So parsing is view angle-dependent, rather than just scene-dependent.
My situation is a "fly through" where the camera location/angle change but the
scenes objects do not.
Thanks for the info,
-John VanZwieten
Date: 16 Sep 1999 15:24:24
Message: <37e143e8@news.povray.org>
I'm not totally inner workings savy, but yes, from what I understand
the visible scene is calculated so the other stuff can be dropped out.
That makes for a change in parse I believe even when just viewpoint
changes.
news:37e142da@news.povray.org...
the
going
scene-dependent.
think
any
objects,
change but the
> -John VanZwieten
Date: 16 Sep 1999 15:27:20
Message: <37e14498@news.povray.org>
>changes.
Nope.  But vista buffers are view-angle dependent.  Still, there's not
currently any way to save the results of the parse.  My understanding
is that it wouldn't save as much time as it might seem anyway.
Date: 16 Sep 1999 15:34:52
Message: <37E1465A.55670386@uni-paderborn.de>
> -John VanZwieten
There is no simple way how to do this.
POV-Ray is an offline program which reads
its input, computes a pretty output and
terminates. There is an animation loop,
but it is based on reparsing the scene.
I noticed some debates on a binary format
(this is probably what you mean) but it
was never implemented (binary triangle
meshes are the only exception). Anyway,
a binary format would not lead to a
significant parsing speedup.
You asked for "any way". OK, there is a
way how to do a camera animation without
reparsing the scene. This requires some
programming. You have to write a program
which mimicks POV-Ray but keeps running
unless told to terminate. Such an
interactive POV-Ray must have an option
to parse a new file after rendering a
frame, without destroying the original
scene which is still in memory. The new
file will contain just the new camera.
That's it.
	y.
Date: 16 Sep 1999 15:35:47
Message: <37e14693@news.povray.org>
Ron Parker <par### [at] fwicom> wrote in message news:37e14498@news.povray.org...
> >changes.
Why not?  Parsing on a scene I'm working with takes >1.5 hours.
-John Van
Date: 16 Sep 1999 15:50:22
Message: <37e149fe@news.povray.org>
>> >changes.
The reason that was given the last time this came up was that profiling
shows that most of the time parsing is actually spent allocating and
shuffling memory around.  Of course this isn't true for all scenes, but
that's what "they" said.
Now that I have access to a copy of vTune for Windows, maybe I'll find
a big scene to parse and see for myself.
Date: 16 Sep 1999 16:42:29
Message: <37e15635@news.povray.org>
In article <37e149fe@news.povray.org> , par### [at] fwicom (Ron Parker) wrote:
You can try pyramid.pov in the sample scenes. Just increase the recursion
level if you need a scene taking even longer to parse.
    Thorsten
Date: 16 Sep 1999 16:46:53
Message: <37e1573d@news.povray.org>
But what when you render exactly the same scene at a different resolution?
Then it seems a pity that you have to render again.....
Sander
Bob Hughes <inv### [at] aolcom> schreef in berichtnieuws
37e143e8@news.povray.org...
> changes.
> Bob
