POV-Ray : Newsgroups : povray.general : inclined Prism ? Server Time
23 Jun 2026 11:20:57 EDT (-0400)
  inclined Prism ? (Message 1 to 10 of 11)
Subject: inclined Prism ?
Date: 24 Aug 1999 17:50:39
Message: <37c313af@news.povray.org>
How to make an incline prism with POVray ?
I can find in User's guide how to make a prism with a base in a plan, and
going 'upward' (i.e if the base is in x,z plan, the moving axis of the prism
is along the y vector.
Buit how can I do a prism inclined like the Pise tower ? (with, for instance
a moving vector incline with 20 degrees to an axis..).
Is my only choice is to use a mesh or a straight prism cut by 'inclined
boxes' ? That would be very long and tedious compared to my simple polygonal
base and prism shape...
I could use SPatch, but I need a rigorous definition of the polygonal base,
and in SPatch I can't define coordinates other than by moving the cursor and
counting the grid marks....
Thanks you for your help.
Subject: Re: inclined Prism ?
Date: 24 Aug 1999 19:16:18
Message: <37C327F8.F7FE8E00@compuserve.com>
What is wrong with simply rotating the prism?
Date: 24 Aug 1999 20:09:40
Message: <37C33439.EE780E0@peak.edu.ee>
You can shear the prism with a matrix transformation. Something like:
matrix < 1, 1, 0,
         0, 1, 0,
         0, 0, 1,
         0, 0, 0 >
Margus
Date: 25 Aug 1999 14:08:52
Message: <37C430DA.D842CA59@t-online.de>
> and
> prism
> instance
> 'inclined
> polygonal
matrix transformation should do the job.
ReVerSi
Date: 25 Aug 1999 17:03:18
Message: <37c45a16@news.povray.org>
I need bevelled prisms...
To explain what I mean:If you have a regular cube, it's a kind of prism with
orthogonal edges. If I rotate it, it still have orthogonal edges.
What I need is an extrusion  with non-orthogonal to base vector. (See my
beautiful picture.. I need (2), and not (1) ..)
Perhaps there is a simple way to achieve this lkind of frame... ?
Of course, I could use CSG Differences to cut a regular prism with a rotated
cube to obtain a bevelled prism.. but well, it would be very fastidious in
my case...
Chris Huff wrote in message <37C327F8.F7FE8E00@compuserve.com>...
Download 'Image1.gif' (4 KB)
Preview of image 'Image1.gif'
Date: 25 Aug 1999 17:20:13
Message: <37C45DD8.2D7F817C@pacbell.net>
> my case...
A rotational sheering operation make this a snap:
camera{location<-0.75,0,-3> look_at 0}
light_source{<-100,10,-200>rgb 1}
     box { -.5,.5
           rotate 20*-z
           scale<1,.5,1>
           rotate 10*z
 pigment { rgb 1 }
Ken Tyler
See my 850+ Povray and 3D Rendering and Raytracing Links at:
Date: 25 Aug 1999 17:26:04
Message: <37c4ece6.6385853@204.213.191.228>
You have two choices if you want a prism with a well-defined interior:
(easier) Use the matrix keyword to shear the prism. You can find
specific info on how to achieve this on John VanSickle's page, whose
url you can certainly find on Unkle Ken's page.
Peter Popov
ICQ: 15002700
Date: 26 Aug 1999 16:23:01
Message: <37C5A245.F9782956@spiritone.com>
Everyone is suggesting the Matrix transformation, but I assume you mean the
"leaning tower" of Pisa, Italy? That tower was built straight up, only a huge
architectural screw up caused it ot lean as it's foundation began to sink on one
side, so a standard prism rotated should do the trick.... but to get the effects
of the diagram, yeah, go for matrix
Joshua English
eng### [at] spiritonecom
IQC: 1946299
"It's a thankless job, but I've got a lot of Karma to burn off."
Date: 26 Aug 1999 17:13:24
Message: <37C5B11E.26B96FEA@erols.com>
Or you can find it right here!
  http://www.users.erols.com/vansickl/matrix.htm
John
Date: 26 Aug 1999 20:38:47
Message: <37C5DE0D.C0E08916@peak.edu.ee>
You forget that the tower is also bent...
Margus
