POV-Ray : Newsgroups : povray.general : Media again? Server Time
28 May 2026 02:48:01 EDT (-0400)
  Media again? (Message 1 to 8 of 8)
Subject: Media again?
Date: 20 Aug 1999 09:57:06
Message: <37bd5eb2@news.povray.org>
I am making a lightsabre using media and it looks great until I get it in a
scene. Then it becomes transparent. Unless the background id dark, you can't
see it. I am using emitting and scattering in a multiple density media. I've
tested a lot of variations. Anyone know what I am missing? My media looks
like this...
cylinder { < 0.0, 1.0, 0.0 >, < 0.0,-1.0, 0.0 > 0.2
                pigment { rgbt 1.0 }
erior{
                media {
                        intervals 5
                        samples 12, 48
                        emission  rgbt  1
                        /// absorption rgbf < 0.0, 0.0, 5.0, 0.0 >
                        /// scattering { 1, rgb < 0.0, 0.0, 3.0 > }
     density { cylindrical
                     color_map {
                                [ 0.00 rgb < 0.0, 0.0, 0.0 > ]
                                [ 0.50 rgb < 0.0, 0.0, 0.5 > ]
                                [ 1.00 rgb < 0.0, 0.0, 3.0 > ]
                               scale < 0.2, 1.25, 0.2 >
                               translate < 0.0, 0.0, 0.0 >
              } /// end den
     density { gradient y
                     color_map {
                                [ 0.20 rgb < 0.0, 0.0, 1.0 > ]
                                [ 1.00 rgb < 0.0, 0.0, 1.0 > ]
                               scale < 0.05, 2.0, 0.05 >
                               translate < 0.0, 1.25, 0.0 >
              } /// end den
            } ///end media
          }///end sphere
      hollow
    }///end
Subject: Re: Media again?
Date: 20 Aug 1999 10:50:37
Message: <37BD6B6A.C6F22EE0@compuserve.com>
First, are you scaling it to a different size? Media is affected by
scale, if you make it smaller you will see the media less, if you make
it larger, you will see a denser media.
Second, are you using a black or dark background to model it against?
You will have to increase the density to see it against a lighter color.
This is the method I use to adjust density:
emission  rgb < 1, 1, 1>*density
Date: 20 Aug 1999 15:19:38
Message: <37bdaa4a@news.povray.org>
Chris Huff <Chr### [at] compuservecom> wrote in message
news:37BD6B6A.C6F22EE0@compuserve.com...
    Even scaling the density by 100 I get the same results. See images in
p.b.i
Date: 20 Aug 1999 16:08:52
Message: <37BDB603.65E82BFF@compuserve.com>
Have you tried eliminating the transparency from the colors? The
transmit in the emission color, specifically.
Date: 20 Aug 1999 17:00:00
Message: <37bdc1d0@news.povray.org>
Yes, but good Idea... I've really tried so many things that I had to go and
try it again to be sure, but it seemed to make no difference.
I've now rebuilt the media from scratch to make sure I didn't have something
stupid that I couldn't spot, but still can't see it in a bright scene.
BTW, I've reposted the images at about 1/20 the file size...
news:37BDB603.65E82BFF@compuserve.com...
Date: 20 Aug 1999 21:55:44
Message: <37bf077c.25241982@204.213.191.228>
Add an absorbing media using the same density but inverse colors.
Where you have emitting blue put absorbing yellow, same with red and
cyan etc. Leave black as is (do not make it white) because it (black)
serves as transparency in media.
Peter Popov
ICQ: 15002700
Date: 20 Aug 1999 22:56:29
Message: <37be155d@news.povray.org>
If you meant what I just found out, you are right. (See p.b.i.)
It is in the rgb values of the emission and scattering statements that you
need to balance the numbers, not in the densities. I had been using...
emission rgb 1
scattering rgb < 1,1,0 >
density     [ rgb <0.0,1>]
when it should have been...
emission rgb <0.0,1>
density     [ rgb 1 ]
I still have some adjusting to do but at least now I can see it...
Peter Popov <pet### [at] usanet> wrote in message
news:37bf077c.25241982@204.213.191.228...
> Peter Popov
> ICQ: 15002700
Date: 21 Aug 1999 15:25:39
Message: <37befd33@news.povray.org>
You stated a multiplication of emission rgb by a "density". Hope you
aren't thinking this produces denser media. Looks like you may be
getting yourself on the right track though. Try raising the 'density'
rgb to compensate for lighter backgrounds while lowering the
scattering and emission (absorption also), you might even be able to
comment out 'scattering' completely, it's awfully slow anyway. The
variations of media environments is not easy to control from what I've
seen of it so far (nooooo :)  Good luck to you anyhow.
Bill DeWitt <the### [at] earthlinknet> wrote in message
news:37be155d@news.povray.org...
that you
using...
> emission rgb 1
> density     [ rgb 1 ]
and
(black)
> > Peter Popov
> > ICQ: 15002700
