POV-Ray : Newsgroups : povray.general : Helix, spiral Server Time
27 Apr 2026 06:15:31 EDT (-0400)
  Helix, spiral (Message 1 to 10 of 10)
Subject: Helix, spiral
Date: 3 Sep 1999 17:34:01
Message: <37D03D36.120A767@isd.net>
Is there any way to get a spiral or helical object without merging (or
blobbing) a bunch of primitives? And is there a way to get a helical
texture without an image map? I know there's a spiral pattern, but no
helical one...
Subject: Re: Helix, spiral
Date: 3 Sep 1999 17:51:11
Message: <37D0430E.AA158CC2@compuserve.com>
You could approximate a helix with triangles, but I don't think a true
helix is possible without the isosurface patch.
And I think the spiral pattern will do what you want, it isn't really a
spiral but a kind of helix.
Date: 3 Sep 1999 18:13:10
Message: <37d047f6@news.povray.org>
Think Larry's son  : )  means a spiral texture lacking in a center or
continuation beyond a certain radius.  Try a 'wood' 'texture_map' with
a clear (or otherwise plain) pigment as both beginning and end
indecies, the 'spiral1 2'texture at index 0.25 and 0.75, for example.
 Far as the object itself goes perhaps torus slices, rotated and
translated. Well you did ask  ; )
Chris Huff <Chr### [at] compuservecom> wrote in message
news:37D0430E.AA158CC2@compuserve.com...
true
really a
Date: 3 Sep 1999 19:02:42
Message: <37D051F9.2ABE8147@isd.net>
> Bob
> true
> really a
I used half-torus for the springs in my LEGO auto chassis. The problem is,
unless you skew them, you can only use halves and no smaller or the end
surfaces won't be vertical. And with half-torus, you get close to a helix,
but it's up-close noticible that it's not. However, you can skew in POV,
so maybe that's the way to go.
Also, what about other kinds of helixes/spirals? I mean, you gave a method
for a spring-type of shape, but there's many ways to make a helix, for
example like rotating long boxes to get a spiral-staircase effect. What if
it was a ramp, not stairs, though? Anyways, the math (I'm assuming) should
be fairly easy for any helix, maybe they should put it in the next POV
release as a primitive.
Date: 3 Sep 1999 21:42:42
Message: <q4bQN7pOJqAG5IvUxA0IBFh6lHkw@4ax.com>
On Fri, 03 Sep 1999 16:27:18 -0500, Larry Fontaine <lfo### [at] isdnet>
>helical one...
For a helix shape check out the Helix object in shapesq.inc that comes
in all POV distributions.
For a helix pattern, you can approximate it using a density_file. See
the demo scenes that come with POV. If you need additional help with
density_files, don't hesitate to ask.
Peter Popov
ICQ: 15002700
Date: 4 Sep 1999 18:51:39
Message: <a3fRNynw=m+7LmbLWut3JvbF4WV8@4ax.com>
>>helical one...
You could also use Striscia  http://members.xoom.com/dvarrazzo/epov.htm
Look in povray.text.scene-files for "Kandy for Ken" on 28 June 99.  This is an example
of
wrapping a spiral pattern around a curve using Varrazzo's "Striscia" macro. The image
is
KandyCane.jpg in povray.binaries.images on the same date.
David
dav### [at] cwcomnet
http://www.hamiltonite.mcmail.com
Date: 7 Sep 1999 10:32:02
Message: <37d521e2@news.povray.org>
Why do the ends have to be vertical, exactly?
Try my spring include file or my torspline include file at
http://www2.fwi.com/~parkerr/traces.html for a couple examples of
interesting things you can do with lots of toruses.  The spring
include file is old (POV 3.0) so you'll need to make a few small
syntax changes, but it uses four toruses per revolution.  If you feed
the torspline file a series of points in a helical shape, it will
obligingly generate the corresponding helix.  It can even do a
conical spring if that's what you need.  You *might* have to
calculate an appropriate starting direction to smooth out the
"wrinkles" though.
Date: 7 Sep 1999 17:26:55
Message: <37D5817C.6E986CD3@isd.net>
> "wrinkles" though.
I meant shear, not skew.
Vetical assuming your spring goes along the Y axis.
If you have a 90 degree section of a torus, and you scale and rotate it to be
part of a helix, if one end were along the x-y plane the other would not be
along the y-z plane. Which is what you would need for two to evenly meet up.
(And simply reversing the ends on the second one would give the same result as
a half-torus.) However, with shearing, I can take any degree section I want and
shear it along Y to keep both ends vertical.
Date: 7 Sep 1999 18:57:42
Message: <37D597AD.A9292FE6@t-online.de>
I recently made a variation of this (using macros, i.e. needing
POV 3.1) which solves some equations numerically, so it can't
break apart even for steep helices.
I'll try to post it on povray.binaries.utilities.
Ralf
Date: 7 Sep 1999 21:57:57
Message: <37d5c1e2.45869520@news.povray.org>
On Tue, 07 Sep 1999 16:19:56 -0500, Larry Fontaine <lfo### [at] isdnet>
Not true.  For proof, check the include file on my web site.  (hint:
drop the requirement that one end be coplanar with the x-y plane)
