POV-Ray : Newsgroups : povray.general : Far objects are pruned???!!! Server Time
10 Jul 2026 10:26:33 EDT (-0400)
  Far objects are pruned???!!! (Message 1 to 10 of 17)
Subject: Far objects are pruned???!!!
Date: 27 Dec 1998 15:49:39
Message: <36869D1C.366BFAB@iro.umontreal.ca>
I have this small problem... I have a very large object
that is very far from the center ( <0,0,0>), but it seems
that pov prunes objects that are not inside <+-1000000,
+-1000000,+-1000000>... Is there a way of settings this?
Best,
    S.
Steven Pigeon                     Ph. D. Student.
University of Montreal.
pig### [at] iroumontrealca           Topics: data compression,
pig### [at] jspumontrealca          signal processing,
ste### [at] researchattcom           non stationnary signals
                                  and wavelets.
         http://www.iro.umontreal.ca/~pigeon
Subject: Re: Far objects are pruned???!!!
Date: 27 Dec 1998 16:01:20
Message: <36869FD8.580A407A@iro.umontreal.ca>
> Best,
>     S.
Oh, yeah, I use version 3.1a for windows.
It seems in fact that the bug is much more perverse...
#declare EarthMoonDistance =    469928448; // Earth-Moon distance
#declare EarthRadius       =      6379439.6; // in meters (thus, 1 pov unit =~=
1 m)
#declare MoonRadius        =      3476183; // for now
box
  0, MoonRadius
  translate <0,-EarthRadius,0> + EarthMoonDistance*vnormalize(<0,0.5,1>)
  pigment { Green }
Yields a visible box, but:
sphere
  0, MoonRadius
  pigment { Green }
does not yield a visible sphere... the object doesn't even exist!
suggestions?
Best,
    S.
                                  and wavelets.
Date: 27 Dec 1998 16:36:15
Message: <3686A88F.45376E95@flash.net>
> suggestions?
1. Fix the source.
or....
2. Scale your distances to fit within POV's current bounds.  If your moon is 100x
closer and
   100x smaller, the error in parellax will be well under one pixel.
Dan
Date: 29 Dec 1998 22:30:37
Message: <36899EDF.3678CBC5@mindspring.com>
Due to prescion limitations of Float math, Povray is compiled
by default with the following:
Anything below 0.001 is considered 0.0
Anythung beyond +/- 1e7 is non exsistant
Don't try to be 100% accurate. Povray isn;t a physics real
world modeler. its an Artistic Program. As long as it looks
right to you then its accurate =}
"fixing" the source will give prescion errors.
Dan Connelly wrote:
> > suggestions?
> 1. Fix the source.
> or....
closer and
> Dan
Date: 30 Dec 1998 01:38:30
Message: <3689CAA4.708CC439@flash.net>
POV sets its limits rather conservatively, and in some cases
does calculations in a fashion which make it more susceptible
to precision limits than it needs be.... doing things like taking
squares and squareroots in nonoptimal sequence.
I agree, though -- there often isn't a need to use such large numbers,
as I pointed out.
Dan
Date: 30 Dec 1998 02:37:36
Message: <3689D7DE.3D451C83@iro.umontreal.ca>
Well, pov uses DOUBLEs, and not FLOATs, and the epsilonis 1e-6...
not 1e-3.  I've checked the source.
Besides, I could show you a couple of pictures where a difference
of 0.001 is visible as a thin line.
However, after toying with objects, I've discovered that
the bug is related to spheres and ellipsoids. A cube a couple
of thousand miles wide set at a quarter millon miles is visible
(as a pixel, granted, but still visible). A sphere, 6 k miles wide,
(assuming a pov unit is 1 meter) at 292 000 miles is not visible.
Why?
I have not been able to pinpoint the bug in the source. It
seems OK to me... still, it is not. My guess is that the epsilon
is used in an additive way instead of multiplicative way in
the sphere intersection routine (should be something like
eps * dist rather than just eps).
Best,
     S.
closer and
That's the best fix, but I dont like it
> > Dan
                                  and wavelets.
Date: 30 Dec 1998 14:30:12
Message: <368a7f44.0@news.povray.org>
<snip>
<snip>
Rather than a bug that only effects these shapes, could it not just be that
a sphere's image is less clear than a squares from the same distance?  For
example, looking straight at at, a cube will show up as a solid, pretty much
evenly shaded square.  A sphere will however be more of a brighter point
with dimmer edges around it.  Perhaps, at these distances, it is the less
visible properties of the sphere that makes POV decide there's not enough
light to plot a pixel - unlike the cube, which may just have enough light
from it's apparently brighter side to appear as one.
Just my 2 pence :)
Matt
Date: 30 Dec 1998 18:39:01
Message: <368AB92E.BB92D7FC@iro.umontreal.ca>
Matthew Bennett wrote:
> <snip>
> <snip>
NO, I _did_ check for that. That was my first thought... then I set
the sphere's color to Yellow*2 on a black background... That should have
been enough...
> Just my 2 pence :)
> Matt
                                  and wavelets.
Date: 31 Dec 1998 02:14:00
Message: <368B249E.800ECB51@randolph.spa.edu>
Strangely enough, I can confirm this... I started with a sphere at the origin,
which I expanded appropriately as I moved it further out along the z-axis, and
when numbers got into the millions, it disappeared. A box, slightly further
out, remained visible...
-Mark R.
Date: 1 Jan 1999 04:20:35
Message: <368C934E.1F21D27D@aol.com>
Yep, the scale of things (distance, size) in POV-Ray is not infinite.
Others have brought this up before, one person in particular I can't
recollect since its been a year or more. But I tried my own scale
testing too and apparently the cone primitive is a very sturdy piece of
pov script. The sphere is one of the weakest, it changes size and
disappears altogether rather easily if scaled too large or small. The
box primitive tends to distort quite a bit before suffering the same
fate. This happens regardless of camera being scaled to view objects.
I could put my scale test file at the scene-files.text group if I can
locate it here.
> -Mark R.
=Bob
