POV-Ray : Newsgroups : povray.general : 3D Math (Reply to Spider) Server Time
23 Jul 2026 18:16:48 EDT (-0400)
  3D Math (Reply to Spider) (Message 1 to 9 of 9)
Subject: 3D Math (Reply to Spider)
Date: 15 Dec 1998 01:22:05
Message: <3676016C.47DB0D4E@virginia.edu>
I tweaked your code a bit... First thing I did was actually translate
the spheres (which I made larger at a radius of 0.25.  Then I changed
your random functions to rand(s)*(Radius * 2) - Radius so that the
values could be positive or negative.  Now, I expected I would be
treated to a roughly spherical shape made up of spheres.  Wrong.  I got
a roughly cubical shape made up of spheres.  This is baffling me,
because your test should eliminate the corners (The corners would occur
when all of vd's vector components were 11s (positive and negative) but
that should end up having a distance greater than 11.  I guess you could
revert to the trig.  (triangles and all...but damned if the distance
formula shouldn't have worked...)
Steve
(I'll be messing with this, email me if you like and we'll figure this
sucker out)
Subject: Re: 3D Math (Reply to Spider)
Date: 15 Dec 1998 01:35:05
Message: <36760478.25A7DA72@virginia.edu>
GOT IT!  (You needed an Or instead of an AND for the test...)  As part
of my testing, I replaced vlength with the distance formula, for
simplicity, I would suggest returning it to normal.  Also, to see the
spheres better, I changed the finish.  Hope this helps
Steve
#declare Radius = 11;
#declare N = 2500;
#declare C = <0,8,0>;
#declare s = seed(pi);
#while (N>0)
   sphere {
    C
    0.25
    pigment { rgb <1,1,1>} finish { ambient 0.2 diffuse 0.6 }
    #local vd=<rand(s)*(Radius * 2) - Radius,rand(s)*(Radius * 2) -
Radius,rand(s)*(Radius * 2) - Radius>;
    #local vld = sqrt(vd.x*vd.x + vd.y*vd.y + vd.z*vd.z);
    #while((vld>Radius) | (vld<-Radius))
    translate vd
  #declare N=N-1;
> Steve
> sucker out)
Date: 15 Dec 1998 11:33:36
Message: <36768EAE.76B544C9@bahnhof.se>
Thanx...
This was in my own code, but I added it after posting... *smile* Thanx.
You too.... It really is baffeling...
I think it should, and it is mentioned in the manual as to work... (Yeah, I ripped
it...)
I could return to trig, but I'm not that good at the math...
> Steve
> sucker out)
I'll keep looking at it...
//Spider
Date: 15 Dec 1998 11:34:47
Message: <36768EF7.4457459D@bahnhof.se>
Yeee... Thanx  (Booting up POV)!
It sure helps....
//Spider
> Steve
> #declare N = 2500;
> #while (N>0)
>    sphere {
>     C
>     0.25
>     #end
>     translate vd
>   #declare N=N-1;
> #end
> > Steve
> > sucker out)
Date: 15 Dec 1998 13:05:40
Message: <3676A52D.8F5B6F13@atmos.albany.edu>
Pardon me for being intrusive . . . but I wanted to share an alternate
solution to this problem which occured to me. It is a bit cheaper in parsing
time (though not much) and loop cycles.
#declare N = 2500;
#while (N>0)
  sphere {
    <0, 0, 0>
    0.25
    #local D =  pow(rand(s), 1/3)*Radius;        // cube root accounts for
increase in rad. wrt vol. Changing this can change the radial distr. of
spheres.
    #local R = < rand(s)*360, rand(s)*360, rand(s)*360,>;
    translate x*D
    rotate 45
    rotate R
    translate C
   #declare N=N-1;
. . . for what it's worth. :-)
Abe
Date: 15 Dec 1998 13:55:06
Message: <3676AFD9.3AEDCA9C@bahnhof.se>
Thanx, I'll test it... And, it comes in under the original topic :-)
THe question was "how" and then my guess that didn't work :-)
//Spider
> #declare N = 2500;
> #while (N>0)
>   sphere {
>     <0, 0, 0>
>     0.25
> spheres.
>     translate x*D
>     rotate 45
>     rotate R
>     translate C
>    #declare N=N-1;
>  #end
> Abe
Date: 15 Dec 1998 17:27:19
Message: <3676E392.7BF3E941@virginia.edu>
I like this method a lot better.  It allows for easier adaptation into
spirals, tori and cylinders.  (While I was modifying your code Spider, I
was thinking.. this would be easier in a polar or spherical system)  I
will be playing some games with this now... Thanks Abe.
Steve
> #declare N = 2500;
> #while (N>0)
>   sphere {
>     <0, 0, 0>
>     0.25
> spheres.
>     translate x*D
>     rotate 45
>     rotate R
>     translate C
>    #declare N=N-1;
>  #end
> Abe
Date: 15 Dec 1998 18:04:55
Message: <3676EC63.51882DC9@virginia.edu>
If there is any interest, I've written a couple of modifications to
allow for Tori and Spirals... Email me and I'll send them out unless
everyone wants them, then I'll post them (They are both roughly this
length, so I'm wondering if posting them here as text would be rude).
I guess I could post them in Scene files, but I don't normally check
that area.  Let me know.
Steve
> #declare N = 2500;
> #while (N>0)
>   sphere {
>     <0, 0, 0>
>     0.25
> spheres.
>     translate x*D
>     rotate 45
>     rotate R
>     translate C
>    #declare N=N-1;
>  #end
> Abe
Date: 15 Dec 1998 19:36:39
Message: <3676FFE6.CF56D6B1@bahnhof.se>
I'm always interested....
Anything I can learn from is good. :-)
//Spider
> Steve
