POV-Ray : Newsgroups : povray.binaries.utilities : Rebuilt pose2pov Server Time
24 Jun 2026 01:50:53 EDT (-0400)
  Rebuilt pose2pov (Message 19 to 28 of 28)
Subject: Re: Rebuilt pose2pov
Date: 22 Aug 2000 14:20:10
Message: <39a2c45a$1@news.povray.org>
"Halbert" <hha### [at] capitalnet> wrote in message
news:39a1b217@news.povray.org...
> Yes. I'd be willing to give it a try. I'm just too damn lazy to continue
> working on that code that someone else wrote. Mood has to be juuuuust
right
> before I will even fire up Visual C++. I assume that your program is
located
> at the web address indicated by your signature. Yes?
Yup - and now I've just uploaded the latest (second) update too. You can get
to it slightly faster by going straight to
http://www.geocities.com/who3d/Models.html rather than going through the
opening page rigmarole.
If you have any problems with it, fell free to e-mail me (preferably with as
much info as possible as to what's wrong - full error messages are good!).
Meanwhile, I guess I'd better check out Christophe's comment on the Camera
location.
Cheers,
Cliff Bowman
Date: 22 Aug 2000 14:37:46
Message: <39a2c87a@news.povray.org>
"Christophe Bouffartigue" <Chr### [at] nanterremarellifr>
wrote in message news:39A25B91.889955E5@nanterre.marelli.fr...
> Cliff Bowman wrote:
> > I haven't uploaded the update due to assuming there was a lack of
interest,
> > but if people want my little Visual Basic 5 effort then it's free.
Limited,
> > but free.
> Yes, I want... ;)
> I often use OBJuvPOV in conjonction with UVMapper, and it works
> perfectly for me
> (except that the camera and light location are generated with ','
> instead of '.'
> in the numbers (am I clear ??)...)
Possibly. It attempts to calculate reasonable light and camera positions
based on the model. so, for example, for the Poser4 lo-resolution casual
female (with no hair) exported as box.obj (for reasons too silly to go into)
it produces the following .POV file (but without the annotations which I've
added manually).
In addition I should mention that to select mesh2 format you should first
select "Tools...Options...POV Export" and select uvPOV mesh2. That will
become the default from thereon in. I've had trouble with the Trimap version
if including more than 1 mesh, or moving the mesh, so I haven't even tested
that option in this latest version (however last time I tested it with just
1 copy of an untranslated mesh mesh it worked beautifully with Chris
Colefax's Trimap mesh macro).
#version unofficial MegaPOV 0.5; // Quick hack added to produce this,
regardless of export type. Naughty of me, but I'm concentrating on a C++
version called "OBJuvMOD".
//First off we get the extents of the .OBJ file.
#declare OBJuvPOVmaxX =  .317443;
#declare OBJuvPOVminX = -.31757;
#declare OBJuvPOVmaxY =  .700764;
#declare OBJuvPOVminY = -.00158505;
#declare OBJuvPOVmaxZ =  .0488173;
#declare OBJuvPOVminZ = -.0713547;
//Then the camera position. Is this what you mean about using "."'s?
    location <-6.35000000000496E-05 , 0.349589475 ,-1.4159668 >
    look_at <-6.35000000000496E-05 , 0.349589475 ,-0.0112687 >
//Again, light source positions are rather daft.
light_source { <-1.58785 , 3.50382 ,-0.3567735 > rgb<1,1,1>}
light_source { < 1.587215 , 3.50382 ,-0.3567735 > rgb<1,1,1>}
background {rgb<0.5,0.5,0.5>}
//Now I set up a default texture - obviously you can (indeed should) change
// the bitmap to the one you wish to use as the default texture (e.g. the
texture
// file for a low-res casual female in this example).
#declare OBJuvPOV_Texture = texture
    pigment
        image_map
            tga "OBJuvPOV.tga"
//Each texture thereafter is, by default, simply a copy of the "default"
one. Change the
// definition of the texture to something else for any halfway decent model
// (for example, to set a different finish to eyes, nails, hair etc. -
and/or different UV
// texture bitmaps).
// The name of each texture is calculated from the texture/material name in
the .OBJ
// file (appaended to "OBJuvPOV_Texture_OBJuvPOV" because I couldn't
imageine
// THAT as *ever* being a name used in a real model).
#declare OBJuvPOV_Texture_OBJuvPOVcolor2 = texture {OBJuvPOV_Texture}
#declare OBJuvPOV_Texture_OBJuvPOVcolor1 = texture {OBJuvPOV_Texture}
#declare OBJuvPOV_Texture_OBJuvPOVcolor5 = texture {OBJuvPOV_Texture}
#declare OBJuvPOV_Texture_OBJuvPOVcolor3 = texture {OBJuvPOV_Texture}
#declare OBJuvPOV_Texture_OBJuvPOVcolor4 = texture {OBJuvPOV_Texture}
#declare ConvObject =
union
// When the include file below is called, the textures listed above are
applied to the mesh.
// I did it this way because I have limited memory (RAM) and patience so I
hate wading
// through large .inc files looking for textures to replace.
    #include "Box.inc"
object {ConvObject}
Hope this helps,
Cheers,
Cliff Bowman
Date: 22 Aug 2000 14:42:52
Message: <39a2c9ac$1@news.povray.org>
Oh - a quick note. Win98 seems to have all the runtime stuff for VB5
already. So if you're using Win98 then all you need is the ~100K .ZIP file
and perhaps the documentation (there's a link to an online copy of that).
Win2000 may well have the runtime too. Worth a try, at least (although since
there's only the .exe in the update file, you'll have to select a location
on your hard drive to store it, and possibly create a shortcut to the dektop
and/or start menu yourself).
Cheers,
Cliff Bowman
Subject: OBJuvPOV
Date: 23 Aug 2000 03:12:44
Message: <39A3796C.3E6CE5A5@nanterre.marelli.fr>
> > perfectly for me
> > instead of '.'
> added manually).
What I was talking about is the separator used between the int part and
decimal part of the floats int camera locations. On a french system,
this separator is a ',', not a '.'. I think that VB use the default
separator of the system to print floats, so my camera declaration was
somethong like that:
 location < 0,32145, 0,7521, -0,4582> // 5 ',' in a vector, POV doesn't
like that :)
 look_at < 0,32145, 0,7521, -0,00321>
and the same for light source locations....
For all the rest, it's a great program, and works almost perfectly. I
had a problem, once, with a mesh without normals, it generated a bad
mesh2, but using a conversion program to add normal information was the
solution....
So far, I've used OBJuvPOV to convert OBJ mesh that comes from various
3D software (Lightwave esentially, after conversion in OBJ), but last
night, I've converted my first real Poser OBJ file, and all was OK, so,
one more time: IT'S A GREAT PROG !!!!
I'll get the zip without VB runtime, and I'll try this tonight.
Thanks a lot.
Bouf.
Subject: Re: OBJuvPOV
Date: 23 Aug 2000 06:21:06
Message: <39a3a592@news.povray.org>
wrote in message news:39A3796C.3E6CE5A5@nanterre.marelli.fr...
> > > perfectly for me
> > > instead of '.'
into)
I've
> > added manually).
> camera {
> like that :)
Doh! Sudden dawning <light bulb flashes on and as in a like a cheap SF
program>
Hmmm... Do you think it's worth my addressing, or is it easy enough to
change the .POV files? For that matter - how well are the meshes coming out?
If they're getting some "," characters instead of "." characters I cans see
that messing up big time (potentially, at least). I hadn't even though about
countries not using "." as the decimal place operator (though more and more
I see figures presented that way on paper - annoys the biggins out of me).
The "completely new lots of wonderful new features written all in C++"
version (OBJuvMOD) is still a *long* way away even if I get it to do
everything I want (for example, adding normals to .OBJ meshes without
normals, editing normals semi-visually so that meshes with normal errors can
be corrected, possibly other features that I'd *like* to do, like UV Map
co-ordinate editing) so don't be expecting the new program to replace
OBJuvPOV this side of Christmas (at least). I expect my health to be good
enough to return to work soon (with luck) so I'll have even less time for
development work too :(
> solution....
It's a simple hack knocked up by someone who needed it himself. Given all
I've had out of the POV-Ray community (by way of scene source, helpful
comments etc.) I'd be a bit rude not to offer it around. IMO :)
The next effort will, I hope, be much more worthy of the accolade "program"
and less prone to the term "hack". But we'll see...
Cheers,
Cliff Bowman
Date: 23 Aug 2000 06:42:00
Message: <39A3AA77.670E16BC@nanterre.marelli.fr>
> program>
beautiful metaphor... ;)
It is easy enough to change (but surprising the first time...). Maybe
you can point it in some docs... So I can wait for your OBJuvMOD....
OBJuvPOV have all the fonctionalities I need for the moment...
The meshes are OK (if I understand right your question...).
I's better worth to have a good health instead of plenty of time for
development. Believe me... Hope you'll be better...
Bouf.
Date: 23 Aug 2000 11:11:19
Message: <39a3e997@news.povray.org>
wrote in message news:39A3AA77.670E16BC@nanterre.marelli.fr...
> Cliff Bowman wrote:
> > Doh! Sudden dawning <light bulb flashes on and [Ed - and off] as in a
cheap SF
> > program>
I'm a Doctor Who fan (as if you couldn't guess) and also a fan of Terry
Pratchett. SF and humour are both things I appreciate :)
You do indeed - and I'm afraid I was a little impatient. Once I knew what
the problem was, I had a quick glance at the code to see if I could easily
do anything about it (it may be a small problem, but I hate software that
I've written that has niggly "issues" even more than I hate having to deal
with other people's "niggly" software). So I've produced a possible fix for
the comma/decimal point problem. I'd be most appreciative if you could test
it and let me know how this new version (0.0.13!) performs.
<looks to the newsgroup name> Hmmm... I ought to be able to attach the "no
libraries" version here easily enough...
good
for
Absolutely. I may even be able to *buy* stuff that at the moment I write or
do without instead! (looking forward to getting back to work).
Pls let me know if this new version is an improvement - if it is I'll update
the history documentation and upload it to the web site.
Cheers,
Cliff Bowman
Download 'OUP0013.zip' (92 KB)
Date: 24 Aug 2000 04:37:54
Message: <39A4DEE1.3165AFB0@nanterre.marelli.fr>
Waoh, I'm a TPratchett fan too. But I only read the french translations
Nop !! Not OK. There's always tge problem with camera and light sources,
but now, also with the OBJuvPOVmaxX variable...
If you can't find a quick fix to it, then don't bother. I'll continue to
use your soft "as is"... The "#version" evolution is already a good
thing, I dont' need anymore to modify the inc file...
Thanks for all.
Bouf.
Date: 24 Aug 2000 08:39:13
Message: <39a51771@news.povray.org>
wrote in message news:39A4DEE1.3165AFB0@nanterre.marelli.fr...
I'll try not to let slip what happens in "The Truth" then :)
for
test
Darn - OK, I've spotted my flaw (which was to let other people do the
testing rather than reproduce the fault myself and then work on it. Bad me).
While I was tidying up I've also made the #version less of a hack (it now
only includes the line if you've selected one of the MegaPOV formats to
export to) and made mesh and trimap exports use the same technique (they'd
have failed in France too!). Curiously MegaPOV 0.5A seems to parse even the
Trimap version faster than the official 3.1g does - and unlike 3.1g you can
place multiple copies of a single UV mesh (Trimap, mesh, or mesh2) object in
a scene without the UV mapping going haywire. I guess that means it's a
problem with 3.1g...
...still, even with the official 3.1g you can load a UV-mapped mesh and
translate it around the scene (oh - I didn't try scaling it, I only tried
rotating and translating it) thanks to Chris Colefax's Trimap macro. Cool.
God that must have been a pain! Especially if you're using large meshes.
People really should, IMO, complain more often. I hope this is the best
version you've seen, I plan to update the documentation and the web site,
oh, "sometime soon now" (probably sometime in the next few days).
Cheers,
Cliff Bowman
Download 'OUP0014.zip' (94 KB)
Date: 25 Aug 2000 05:27:33
Message: <39A63C04.6E510F20@nanterre.marelli.fr>
Bingo !!! That's it !!! I keep this one.  :))
Thanks a lot.
And now, let's render (probably some discworld related pictures.... I
hope).
Bouf.
