POV-Ray : Newsgroups : povray.binaries.utilities : Texture Editor Server Time
10 Jun 2026 11:00:20 EDT (-0400)
  Texture Editor (Message 11 to 18 of 18)
Subject: Re: Texture Editor
Date: 17 Jul 1998 10:53:30
Message: <35af575a.0@news.povray.org>
Morpheus Dreamlord <mor### [at] mailexcitecom> wrote:
: Ok, so who cares about 1 person not using a program....but I won't be
: changing my mind about this....
  There are 2 persons not using the program. My reason is that the original
author is going to make it a win95-only program.
                                                              - Warp. -
Date: 17 Jul 1998 11:52:06
Message: <35af6516.0@news.povray.org>
If you write the program in c/c++ it is fairly easy to port to other
machines.  If you really want portability then write the program in java.
If you write it in java (which is a language similar to c++) then just the
one copy of the prog will run on any java capable machine or os.
Date: 17 Jul 1998 13:59:53
Message: <35AF7A35.8BEA55F6@nermail.ups.com>
HeHe, I noticed that soon afterwards..  Seems by battries are going on the blink..
    Thomas Charron
Alain CULOS wrote:
> This message is really intended for Thomas Charron :
> Could you please set up your computer date to be near reality (1998, not 1997) as
> my automatic newsgroup reader will not download 'old' messages (20 days) and I do
> not really want to be searching for each such message manually or set the date span
> to more than 20 days.
> Regards,
> Al.
> ANTI SPAM / ANTI ARROSAGE COMMERCIAL :
> To answer me, please take out the Z from my address.
Date: 21 Jul 1998 22:05:16
Message: <35B54938.9B66194E@chisp.net>
the feature that i'd most like in a texture editor for povray is one that
can import textures from povray code.   From any pov source file or include
file.    Another feature i'd like to see is the ability to save a library of
thumbnails associated with textures. it would just save any render of a
texture in the library as a seperate image file.   this would make it easy
to browse through textures you've already made without having to wait for
each one to render to see what it looks like.
Tim Burton wrote:
> I have been humoring the possibility of creating a texture editor for
> Pov and am wondering if it would be worthwhile and what features people
> would like.  I have been using TextureMagic 0.95 and find it to be sadly
> out of date.
> Is there a demand for this type of utility, and if so what would people
> like it to have?
> Tim Burton
> TBu### [at] ThrtCom
Date: 31 Jul 1998 12:31:50
Message: <35c1e1c7.16902486@news.povray.org>
On Tue, 21 Jul 1998 19:06:49 -0700, in povray.binaries.utilities you
if you only want to get thumbnails of all POV-Ray textures located on
your harddisk, perhaps my program TextureView (freeware for Windows
95) could help you... take a look at
  http://www.rz.fhtw-berlin.de/~s0049669/software.html
Bye,
Friedemann
Friedemann Schmidt
Fri### [at] Stonescom
Raytracing-Gallery: http://www.rz.fhtw-berlin.de/~s0049669
Date: 1 Aug 1998 07:16:33
Message: <35C2EB17.DEB37703@flash.net>
> file.
I don't think this is at all easy to implement.  With the possibility of
includes, file i/o, macros, and texture assignments to variables and
arrays,  it would be extremely difficult to extract textures without basically
parsing the entire source.
Dan
http://www.flash.net/~djconnel/
Date: 1 Aug 1998 07:54:52
Message: <35C2E5BD.3551F37A@pacbell.net>
> > file.
> Dan
TextureView by Friedemann Schmidt does an excellent job on any
#declared texture in any standard pov file. Although it doesn't preview
textures inside of the body of an object statement it does a great job of
allowing you to search entire directories for #decalred textures and gives
you a choice to render each texture into a thumbnail view with pov as the
rendering engine. This ensures that what you see is what you get. As far as
the difficulty of texture extraction when it does it's directory search for
textures
it searches only for declarations of textures and ignores the rest of the pov
code.
After doing a search of my main include directory which is very extinsive by the
way it came back in about 4 min. with 1200 textures. Pretty impressive if you ask
me.
K.Tyler
Date: 11 Dec 1998 04:38:27
Message: <3670e813.0@news.povray.org>
I can see the problem though, I often use calculated values in colour_maps
for example to animate textures. This would be a bit of a trick to parse.
Also which texture do you render, the one at clock=0.0 or clock=0.5 or....
Gordon
<gbe### [at] birdcameroncomau>
K. Tyler wrote in message <35C2E5BD.3551F37A@pacbell.net>...
>Dan Connelly wrote:
that
include
>> > file.
basically
>> Dan
>textures
pov
>code.
by the
you ask
>me.
>K.Tyler
