POV-Ray : Newsgroups : povray.binaries.scene-files : How to render 3d smoke using exisiting particle data Server Time
18 Dec 2025 08:16:26 EST (-0500)
   How to render 3d smoke using exisiting particle data (Message 1 to 8 of 8)
Subject: How to render 3d smoke using exisiting particle data
Date: 16 Apr 2013 04:50:01
Message: <web.516d1029e6ae6c84c2a18ad0@news.povray.org>
Dear all,
I want to render a nice 3d smoke figure on to my screen using the measured
experimental data (which is a 3d array of smoke density values in different
position and different time). I have checked Rune's particle system and learned
the particle system of pov-ray might be the way to obtain my goal.
It may be an easier job compared to Rune's work, because there is no need to
calculate new positions and velocities of particles. In Rune's work, when the
rendering completed, there was a particle data file generated. And my question
is how to render a 3d picture using the existing particle data?
simple example or give me a direction in this.
Best regards,
Ray
Subject: Re: How to render 3d smoke using exisiting particle data
Date: 16 Apr 2013 16:52:30
Message: <516dba0e$1@news.povray.org>
> Dear all,
> Best regards,
> Ray
You may not need to use particles. Have you tried using media?
If your smoke density data is composed of integers encoded as 1, 2 or 3
bytes integers, it could be trivial to convert it into a .DF3 file and
use it directly to controll the media density. Just remove the header
and replace it by the X, Y and Z dimentions. It's also possible to read
the data and output the DF3 file from POV-Ray.
Next, make a relatively tight container, a box, sphere or cylinder as
appropriate, add hollow and a media block.
Date: 19 Apr 2013 05:45:01
Message: <web.5171108b98296338379ee910@news.povray.org>
Dear Alain,
Thanks a lot! Your suggestion gave me the direction to obtain my 3D image.
But, after googled around, I still have no idea how to convert my 3D matrices
data into a .DF3 file. Could you please give me some more details or examples
for that?
My data are organized as a three-dimension matrix in MatLab, with the first
dimension being x, second dimension y, and third dimension z. The grid size on
all three dimensions is the same. A non-zero value means the existence of smoke
at the corresponding spatial location and a larger value means more intense
smoke.
A data format example: a(:,:,1)=[0.11 0.21 0; 0.22 0.31 0; 0.61 0
0];a(:,:,2)=[0.27 0 0; 0.31 0.42 0; 0.55 0 0];a(:,:,3)=[0.18 0 0.19; 0 0.72 0;
0.21 0.38 0]
I'd really appreciate your kind help.
Ray
Date: 19 Apr 2013 06:26:05
Message: <51711bbd$1@news.povray.org>
> for that?
Does this help? (From the 3.7 Help File)
3.4.7.1.8.1 df3 file format
Header:
The df3 format consists of a 6 byte header of three 16-bit integers with
high order byte first. These three values give the x,y,z size of the
data in pixels (or more appropriately called voxels ).
Data:
The header is followed by x*y*z unsigned integer bytes of data with a
resolution of 8, 16 or 32 bit. The data are written with high order byte
first (big-endian). The resolution of the data is determined by the size
of the df3-file. That is, if the file is twice (minus header, of course)
as long as an 8 bit file then it is assumed to contain 16 bit ints and
if it is four times as long 32 bit ints.
Again from the help files
3.3.2.3.4 The write Directive
Note: See the sample macro ARRAYS_WriteDF3 in arrays.inc to see how this
feature may be used.
Also somewhere on the net there is a utility called tga2df3.exe will
convert a tga file to df3.
Regards
Date: 25 Apr 2013 23:55:01
Message: <web.5179fa33982963345d4cf1e0@news.povray.org>
I have done this: I extracted each slice of data from the 3D matrix (that is
each slice is a 2D array and all such slices combined to give a 3D matrix). Then
I output each slice of data as a gray level picture and converted all of those
images into TGA format. Next, I combined all my tga images into a .df3 file
format and rendered it with following code:
background { rgb 1 }
camera {direction z*8 location <0,0,-10>}
light_source { <20,40,10>, 1 }
sphere // transparent sphere containing media
{ 0,1 pigment { rgbt 1 } hollow
interior
{ media
{ absorption 5
density
{ density_file df3 "a1.df3" interpolate 1
   color_map{ [0 rgb 0]
     [0.4 rgb <1,0,0>]
     [0.8 rgb <1,1,0>]
     [1 rgb 1]
But the result showed a very strange shape. I changed the camera location, still
no smoke shape displayed. I really have no idea what's wrong with that. The TGA
image seems correct. I attached one of the TGA images and two images of result
with different camera location. Any ideas what my problem might be?
Thank you,
Ray
Download 'attachment.rar.dat' (8 KB)
Date: 26 Apr 2013 07:32:27
Message: <517a65cb@news.povray.org>
> interior
> { media
> { absorption 5
> density
>       [0.4 rgb <1,0,0>]
>       [0.8 rgb <1,1,0>]
>       [1 rgb 1]
> Thank you,
> Ray
I don't see light_source enabled to support media_interaction ... also
wondering why you used absorption media. Try scattering instead. Perhaps
background should be something other than pure white ... for a little
contrast (make the smoke easier to see)
Date: 26 Apr 2013 07:37:27
Message: <517a66f7$1@news.povray.org>
>> (that is
>> matrix). Then
>> of those
>> file
>> interior
>> { media
>> { absorption 5
>> density
>>       [0.4 rgb <1,0,0>]
>>       [0.8 rgb <1,1,0>]
>>       [1 rgb 1]
>> location, still
>> that. The TGA
>> of result
>> Thank you,
>> Ray
oops ... should have checked before posting media_interaction is on by
default
Date: 26 Apr 2013 22:10:01
Message: <web.517b32659829633d20616960@news.povray.org>
I guess there is something wrong with .df3 file. The shape in it seems not
correct. Is the process of making .df3 file incorrect? Any other ideas what my
problem might be?
