POV-Ray : Newsgroups : povray.binaries.scene-files : Filling a bottle with fluid Server Time
24 Jun 2026 01:54:37 EDT (-0400)
  Filling a bottle with fluid (Message 1 to 5 of 5)
Subject: Filling a bottle with fluid
Date: 22 Aug 2012 08:30:02
Message: <5034d0ca@news.povray.org>
The used scene (see p.b.i.)
Download 'windows-1252' (7 KB)
Subject: Re: Filling a bottle with fluid
Date: 22 Aug 2012 17:42:16
Message: <50355238$1@news.povray.org>
Le 22/08/2012 14:29, Thomas de Groot nous fit lire :
> Thomas
Thanks. I found back CIE.inc in some archive, but Gilles Tran include I
hope I do not need, because I do not have.
Adaptation went well, till I get hit by the media, as changing the
container of course changed its distribution (getting both media in the
liquid was not good).
Should be solved with the object pattern in the distribution.
Yet, the liquid is not the same red. Media seems a domain that's doom to
escape me.
Picture in p.b.i once rendered (trace limited to 5 might have an effect
on the reality of the scene)
Download 'fluid_test2.pov.txt' (7 KB)
Date: 23 Aug 2012 03:28:22
Message: <5035db96$1@news.povray.org>
Yeah, I could have trimmed the scene down but was too lazy ;-) Gille's
include is not important in this kind of scenes; only used to test the
presence of objects within the camera field.
> escape me.
The two media are looking best (?) when they are completely separate of
course, i.e. when the liquid is slightly smaller than the container,
which is the standard procedure. But we are talking here about
alternatives :-) and I think it is a minor problem which only needs some
more tweaking to get the desired result.
Of course.
Thanks for this code. I had also started experimenting with ellipsoids
but had not yet got satisfying results.
In your code, I was surprised by the use of object{} within the density
block. I never thought of that, and I think it is not described as
option in the Docs (at least I cannot find it). It is comparable to
object pattern apparently; logical when considering it.
Yet learned another lesson :-)
Date: 23 Aug 2012 08:38:10
Message: <50362432$1@news.povray.org>
Well, it is indeed the object pattern. syntax is a bit ambiguous
regarding if "object { Foo ..." is actually :
 1. a new instance of the object Foo
 2. a pattern: object pattern using Foo
It's context sensitive. Density wants a pattern and then a map.
Excepted that a discontinuous pattern have no map, but a list:
http://wiki.povray.org/content/Reference:Object_Pattern
http://wiki.povray.org/content/Reference:Media#Density_with_color_map
Even if it does not cite object, the reference does:
http://wiki.povray.org/content/Reference:Pigment#Color_List_Pigments
PS: I had a little fight with cutaway_textures and the bug of 3.7
regarding it. Hence it's not the obvious:
difference {
 union { A with texture
         B with texture
  C with or without texture
  cutaway_texture
Date: 23 Aug 2012 10:32:52
Message: <50363f14$1@news.povray.org>
OK.
This is fairly clear, although I had to think twice before understanding
what is meant by /list/. I am not as smart as I used to be ;-)
Again, for the less smart amongst us, using the term /Density List/
elsewhere than only in the title would help understanding. I think it
would be wise also to add /object/ to the list of (four!) list patterns
where they can be used in density. I would suggest the following
amendment to the relevant text:
Instead of:
[quote]Entire densities may also be used with the block patterns such as
checker, hexagon and brick.[/quote]
I would read:
[quote] Density lists may also be used with block patterns such as
checkers, hexagon and bricks, as well as the object pattern object.[/quote]
...or something equivalent if this is not strictly correct.
Indeed.
> difference {
>           B with texture
>    cutaway_texture
right.
