POV-Ray : Newsgroups : povray.binaries.programming : An updated povr tarball for Unix/Linux. f6b1c13e Server Time
28 Mar 2026 19:42:19 EDT (-0400)
  An updated povr tarball for Unix/Linux. f6b1c13e (Message 1 to 10 of 45)
Subject: An updated povr tarball for Unix/Linux. f6b1c13e
Date: 20 Jul 2020 06:00:17
Message: <5f156b31@news.povray.org>
Please find attached an updated tarball.
Attempting no lower case #declare, #local identifier idea. Hope is
user's function and macro arguments made _<lower case> form will be
immune to name collisions.
With a thought toward eventual real time modeling, continuous real time
rendering enabled as it has been in window's versions since v37. Added a
rtr_kla.pov sample scene for the feature.
The rtr_kla.pov scene implements an alternative to the persistent
keyword marking idea of uberpov. While the continuous / real time
rendering only supports multiple camera positions today, multiple frames
can be rendered with one scene parse where more than the camera changes.
The idea is to create multiple fixed sets in which changes are made and
where a camera is appropriately placed in each. Mentally one must, of
course, still keep track of what is persistent and what is not, but we'd
not need a new keyword and the code infrastructure behind it - supposing
eventual frame capture capability. Simpler, perhaps, to look at the
sample scene to get the idea.
Corrections to the DOINGMAKECHECK=YES build implementation - thanks jr.
I've not seen an x11 display issue in the week since adding the
XInitThreads() call - thanks jr. Thinking of making x11 the default as
it's windowing behavior is more consistent with my Ubuntu environment.
Added an inbuilt f_toupie() function supporting 1-15 as integer
exponents where f_toupie() usually uses 3. Provides for a range of
shapes lemon like, torus like (exactly the torus at 2), toupie like and
button-ish shapes.
Bill P.
Download 'povray2_f6b1c13e.tar.gz' (1636 KB)
Subject: Re: An updated povr tarball for Unix/Linux. f6b1c13e
Date: 20 Jul 2020 09:00:08
Message: <web.5f159418f6dfcecf4d00143e0@news.povray.org>
hi,
thanks.  compiles.  will properly make + install sometime later this week.
one thing I noticed, 'povr' links against an older version of libpng, unlike the
"stock" POV-Ray.
jr@swift:13:~$ ldd /usr/local/bin/povray-3.8.0-alpha.10064268
    libpng16.so.16 => /usr/lib64/libpng16.so.16 (0x00007f6cc19c5000)
jr@swift:14:~$ ldd POVr/bin/povray2
    libpng12.so.0 => /usr/lib64/libpng12.so.0 (0x00007fb50195f000)
jr@swift:15:~$
the updated version too links to 1.2.50, when 1.6.37 is available.
(crestfallen..)  hope 'a_' will be as acceptable as '_a'.
+1.  :-)
regards, jr.
Date: 20 Jul 2020 20:52:57
Message: <5f163c69$1@news.povray.org>
On 7/20/20 8:54 AM, jr wrote:
> hi,
> "stock" POV-Ray.
> jr@swift:15:~$
Interesting find. :-) Unsure why you see a difference in library used.
It's my understanding when there are multiple versions of a library in
place on a system there is usually a sym link established from a generic
name to the 'official' one for the particular linux distribution. It
would be normal then for the official distribution version to be picked
up first. This is not necessarily the newest (or oldest) one if you have
multiple development library versions on a system(1).
(1) - Not all that common, but certainly happens. I have only one libpng
version on my Ubuntu 18.04 system.
There are certainly ways to override which library gets picked up
explicitly. Hmm, wonder, if you've got multiple libraries and no symlink
to a version-less name like libpng.so.1 I'm unsure how one library would
be picked over another? Do you have the common sym link name given you
have two libpngs?
Sure. You can continue to use any names you want for function and macro
parameters. The _<lower> is the suggestion because it won't collide with
future SDL keywords where some other lower case string might eventually
- though probably not a_ :-).
Bill P.
Date: 21 Jul 2020 07:05:01
Message: <web.5f16cadaf6dfcecf4d00143e0@news.povray.org>
hi,
> > "stock" POV-Ray.
> ... Hmm, wonder, if you've got multiple libraries and no symlink
> have two libpngs?
bingo.  yes, the "version-less" names ('libpng.{la,so}') were pointing to the
old(est) version; guess must have happened when I re-compiled/re-installed
1.6.37.  cheers.
regards, jr.
Date: 21 Jul 2020 10:35:08
Message: <web.5f16fc0df6dfcecf4d00143e0@news.povray.org>
> > have two libpngs?
> 1.6.37.  cheers.
right, and now we're getting to the bit where it gets .. strange.  :-)
built the new version of 'povray2', checked libpng link - ok, and 'make check'
ran fine, so installed.  went back into the scenes directory, and all three
scenes now fail with:
  Trace Time:       0 hours  0 minutes  0 seconds (0.354 seconds)
              using 4 thread(s) with 1.388 CPU-seconds total
Cannot allocate PNG data structures
Render failed
:-)  everything works as normal until it needs to write the disk file.
unfortunately cannot try those scenes with alpha.10064268, but checked that, and
other programs linking to 'libpng16', still work.  and 'povray2' output to, say,
jpeg, is ok.
'make check' succeeded because it doesn't actually try to write to disk?
regards, jr.
Date: 21 Jul 2020 11:50:00
Message: <web.5f170d79f6dfcecf4d00143e0@news.povray.org>
hi,
ignore.  the problem was the symlinks in /usr/include not pointing to the
correct headers.  :-(  re-built 'povray2' and all three test scenes ok.
regards, jr.
Date: 29 Jul 2020 14:20:00
Message: <web.5f21bcf7f6dfcecf4d00143e0@news.povray.org>
hi,
I find I'm not .. getting on with the forced uppercase stuff (sorry), and would
prefer to go back to the first version you posted.  regarding that, I did a
'diff' on the respective 'vfe/unix/unixconsole.cpp' files, is the 'XInitThreads'
call (including surrounding conditional) the only thing that would need to be
added to allow the _f9bc4ef7 version to function safely wrt X11?
regards, jr.
Date: 30 Jul 2020 19:31:19
Message: <5f235847$1@news.povray.org>
On 7/29/20 2:16 PM, jr wrote:
Just back from a few days at real life. Back at povr for real tomorrow -
or the day after. Ahead of me getting back...
Could you be more specific?
Povr breaks compatibility with as little as possible - but still quite a
lot. My aim is to keep behavior near v3.8, but there is certainly more
compatibility breakage to come. Is it more than wanting to continue to
use lower case and/or includes which already have lower case?
Are there actual conflicts/problems with the approach; or examples where
it's very inconvenient?
The functionality is still hacked in - because I'm trying it too. :-)
But, thus far, I'm liking the behavior. In fact, I recently fixed a miss
with command line declares letting lower case declare IDs still happen.
That said, I've not run much old stuff with it as yet. Plus, suppose I
wasn't in the habit of using lower case locals/declares to begin with.
Our SDL usage is different. I've not much jumped on the newer array,
dictionary stuff, for example, mostly because it came well after my tcl
wrapper - which already had that functionality.
As safely as the newer release, yes.
There are other fixes and improvements relative to the prior release
you'll be missing in using the first, but stuff should work except where
there was already incompatible change - ie fog, inbuilt functions,...
Bill P.
Date: 30 Jul 2020 20:45:00
Message: <web.5f236956f6dfcecf1f9dae300@news.povray.org>
Is it possible, and is there a security issue related to providing a means to
create a subdirectory in a write-permitted directory?
#write creates a file.  Can we create a directory by a similar means?
Just something to think about.
Date: 31 Jul 2020 04:25:00
Message: <web.5f23d42df6dfcecf4d00143e0@news.povray.org>
hi,
no, for me it's just[*] the lower/uppercase stuff.  basically, each of my old
scenes I tried, failed.  I thought about modifying scene code, but since they
work I'll find it easier not to use (the new version of) 'povr'.
[*] at present.
just inconvenient.  eg, to "fix" the scene I used when I ran into the X11
animation issue, would be a lot of work, made worse by the fact that I got that
scene from the web, ie it's not even my code.
cannot say the same.  guess I'm "allergic" to uppercase.  :-)
(could this behaviour be enabled/disabled via a 'povray.conf' setting instead?)
thanks, I'll try that then, sometime this weekend.
regards, jr.
