POV-Ray : Newsgroups : povray.binaries.images : Triplanar Mapping Server Time
5 Oct 2024 03:19:09 EDT (-0400)
  Triplanar Mapping (Message 14 to 23 of 33)
Subject: Re: Triplanar Mapping
Date: 16 Jan 2024 20:15:00
Message: <web.65a7291c93092b9916bed5696e741498@news.povray.org>
> Op 16-1-2024 om 16:02 schreef Bald Eagle:
> > I gave it a go, since I had to visualize the rotations, lest it bother me for
> > the rest of the day. [...]
> Thanks Bill! I gave it a go and I noted the following:
> 1) [..]
> 2) [..]
> 3) so it appears (to me) that the texture does not follow the object
> rotation. Why this is is a mystery to me and it is the first time I
> witness such behaviour indeed.
> Thomas
About your parallel lines result: have you tried the new macro with a sharpness
value above 0.5?
Regarding your third bullet point... The texture not following the object's
rotation is an issue I predicted, but was unsure if it would manifest or not. My
guess is that the slope inputs (x, y, z) need to be rotated independently of the
object, which probably means using vrotate() for the slope inputs to match the
object.
I'll need to test that...
Sam
Date: 16 Jan 2024 21:10:00
Message: <web.65a736bb93092b9916bed5696e741498@news.povray.org>
> object [...]
(To everyone: I'm sorry for not replying to everything right now.)
As you've seen, rotating an object using a slope pattern doesn't give the result
one would hope for. Whether the rotation is placed before or after the triplanar
pattern matters a /bit/, but not enough: in either case the result will be
wrong. The answer seems to be to rotate the slope vectors /independently/ of the
object.
In the attached image, the left object is rotated in a naive manner. The right
object uses a new macro that rotates the slope vectors in tandem with the
object. It can be a hassle to do it this way, but it would appear that if you
wish to rotate your object it's what you have to put up with ;)
Here's the scene code:
 triplanar-debug.pov
 2024 stb
 +fn +f +a0.3 +am2 +r2 +w1024 +h512
#version 3.7;
global_settings{assumed_gamma 1.0}
camera{
 orthographic
 right x*2 up y
 location <0, 5, -10>
 look_at 0
 angle 33
// sunlight
#if(true)
 light_source{
  <1, .5, 0>*1e5, srgb <1.5, 1.4, 1.3>
  shadowless
// starry background
#if(true)
 background{rgb .5}
// input image for triplanar color and normal
#declare PImg =
 pigment{
  image_map{
   png "craters.png"
   interpolate 2
  scale 2
#declare ObjRotate = <0, 37, 0>;
 Triplanar macro
  Pigment: a pigment oriented in the z-direction
  Sharpness: a value between 0 and 1
  Rotate: the object's rotation
#macro TriplanarR(Pigment, Sharpness, Rotate)
 pigment_pattern{
  slope vrotate(x, Rotate)
  triangle_wave
 pigment_map{
  [0+.5*Sharpness Pigment rotate y*90]
  [1-.5*Sharpness
   pigment_pattern{
    slope vrotate(y, Rotate)
    triangle_wave
   pigment_map{
    [0+.5*Sharpness Pigment rotate x*90]
    [1-.5*Sharpness Pigment rotate z*165]
// don't use this if you want to rotate your object
#macro Triplanar(Pigment, Sharpness)
 pigment_pattern{
  slope x
  triangle_wave
 pigment_map{
  [1-.5*Sharpness
   pigment_pattern{
    slope y
    triangle_wave
   pigment_map{
// object on left (naive rotation)
superellipsoid{
 <.2, .2>
 texture{
  pigment{pigment_pattern{Triplanar(PImg, .5)}}
  normal{
   poly_wave .5
   bump_size .75
   accuracy .01
 rotate ObjRotate
 translate -x*1.5
// object on right (corrected rotation)
superellipsoid{
 <.2, .2>
 texture{
  pigment{pigment_pattern{TriplanarR(PImg, .5, ObjRotate)}}
  normal{
   poly_wave .5
   bump_size .75
   accuracy .01
 rotate ObjRotate
 translate x*1.5
Sam
Download 'triplanar-debug.jpg' (59 KB)
Preview of image 'triplanar-debug.jpg'
Date: 16 Jan 2024 21:50:00
Message: <web.65a73f4d93092b9916bed5696e741498@news.povray.org>
> it would appear that if you wish to rotate your object it's what you have to put up
with
After more testing, I think the best and most general way to handle this is to
not use the most recent macro after all. Just simply rotate all your objects
/before/ using the original Triplanar macro like so:
 superellipsoid{
  <.2, .2>
  rotate ObjRotate
  texture{
   normal{
    poly_wave .5
    bump_size .75
    accuracy .01
The left image again uses naive rotation, but with the rotation applied before
the Triplanar macro. There will still be some warping but hopefully no parallel
lines. (Some artifacts are unavoidable when applying such an experimental
feature on many different;y oriented objects :))
Sam
Download 'triplanar-debug-2.jpg' (59 KB)
Preview of image 'triplanar-debug-2.jpg'
Date: 16 Jan 2024 22:45:00
Message: <web.65a74c3993092b9916bed5696e741498@news.povray.org>
> it would appear that if you wish to rotate your objects you have to put up with
some issues.
There will always be some stretching, since not all objects will be boxes or
superellipsoids aligned to one sole direction. You have to do your
transformations before applying the triplanar mapping.
Here's the code used to make the attached image:
 triplanar-debugB.pov
 2024 stb
 +fn +f +w960 +h540
#version 3.7;
global_settings{
 assumed_gamma 1.0
 #if(1)
  radiosity{
   count 1
   error_bound .05
   recursion_limit 1
   nearest_count 10
   normal on
camera{
 orthographic
 right x*1.77 up y
 look_at 0
 angle 33
 aperture .28 focal_point 0 blur_samples 10 variance 0
// sunlight
#if(true)
 light_source{
  <1, .5, 0>*1e5, srgb <1.5, 1.25, 1>
  #if(1)
   #declare ALRes = 2;
   #declare ALSize = .1*1e5;
   area_light x*ALSize, z*ALSize, ALRes, ALRes
   jitter
   adaptive 1
   //area_illumination
// background
#if(true)
 background{rgb <.3, .5, .7>}
#declare PImg =
 pigment{
  image_map{
   png "craters.png"
   interpolate 2
  scale 2
 pigment_pattern{
  slope x
  triangle_wave
 pigment_map{
  [1-.5*Sharpness
   pigment_pattern{
    slope y
    triangle_wave
   pigment_map{
// random objects
union{
 plane{y, 0}
 #local Seed = seed(1002);
 #for(I, 0, 20)
  superellipsoid{
   <.2, .2>
   scale .2+.8*rand(Seed)
   rotate 360*<rand(Seed), rand(Seed), rand(Seed)>
   translate 12*(<.5-rand(Seed), 0, .5-rand(Seed)>)
  torus{
   .5, .2
  sphere{
   12*(<.5-rand(Seed), 0, .5-rand(Seed)>), .2+.8*rand(Seed)
  cone{
   0, .5, y, 0
 // triplanar mapping after all transformations
 texture{
  pigment{
   pigment_pattern{Triplanar(PImg, .75)}
   color_map{
    [0 rgb <.05, .1, .15>]
    [1 rgb <.9, .85, .8>]
  normal{
   bump_size 1
   accuracy .01
Download 'triplanar-debugb2m_17s.jpg' (123 KB)
Preview of image 'triplanar-debugb2m_17s.jpg'
Subject: Re: Triplanar Mapping - to: Bald Eagle, Sam, and Kenneth
Date: 17 Jan 2024 02:25:02
Message: <65a780ce$1@news.povray.org>
Living in different time zones have their advantages! ;-)
While I was sleeping you seem to have really tackled the issues with
triplanar mapping. With my early morning cup of hot coffee beside me, I
have been reading your posts. Thanks for all that good work, gentlemen!
No opportunity now to answer in detail, but I am going to seriously
apply the latest codes to my test range.
Again, my deeply felt appreciation for all your creative thinking and
coding. This really is a great community!
Date: 17 Jan 2024 06:45:00
Message: <web.65a7bd6193092b991f9dae3025979125@news.povray.org>
Nice work - that's looking really good!  :)
So now here's a question - while trying to hunt down an answer to WFP's default
importance question, I stumbled upon a thread where clipka discusses
pleochromism.
https://en.wikipedia.org/wiki/Pleochroism
I know that I've brought up the topic of wet paper in the past in this regard.
It seems that this approach might also make for a good anisotropic effect if we
roll some layered texturing + filter/transmit into it?
What do you think?
- BW
(You wouldn't believe how hard it is to find an example image of this effect)
Date: 17 Jan 2024 07:49:14
Message: <65a7ccca@news.povray.org>
Op 16-1-2024 om 17:51 schreef Bald Eagle:
> I think it might be more of an issue of how the image_map is oriented with
> regard to the slope, (+90 vs -90 deg).
Yes, I guess you are right.
> I also don't think I have a complete pattern definition, since I was unsatisfied
> with how the slope controlled 100% pigment when perfectly aligned with an axis
> vs rgbt 1 when perpendicular to it.
> I would suggest looking at the method of creating a normal map by user "NPC"
> used in this thread:
https://news.povray.org/povray.binaries.images/thread/%3Cweb.5d978f0b44e99bc84eec112d0%40news.povray.org%3E/
> The key being:
> sine_wave frequency 0.5 phase -0.25
I need to plunge into this... it does not seem to improve /that/ much
(at least for the sine_wave option).
> which, indeed, when I add that frequency and phase correction in my WaveType
> macro, seems to get rid of what you might be seeing.
> (left: pigment applied before -90*y rotation, right: pigment applied after -90*y
> rotation)
> Try and experiment.
To date, what works best with your code, is using triangle_wave or
scallop_wave as WaveType, as those show least artefacts it seems on the
superellipsoid (see attachment: use of triangle_wave). Still, I have not
yet fully experimented your code in comparison with Sam's but I intend
to do so.
Download 'be_triplanar mapping.jpg' (250 KB)
Preview of image 'be_triplanar mapping.jpg'
Date: 17 Jan 2024 08:20:34
Message: <65a7d422@news.povray.org>
Op 17-1-2024 om 04:40 schreef Samuel B.:
Sam, I am very happy with this final development, thank you very much
for your efforts!
I think the time has come to apply this to my Logo Planet scene. Stay tuned!
Download 'sb_triplanar mapping.jpg' (336 KB)
Preview of image 'sb_triplanar mapping.jpg'
Date: 17 Jan 2024 08:25:44
Message: <65a7d558$1@news.povray.org>
Op 17-1-2024 om 00:58 schreef Kenneth:
> To me, those parallel lines look similar to the typical behavior of an image_map
> applied to a 1X1X1-unit box-- where the edge pixels 'wrap around the sides' (as
> an analogy only.) I haven't examined the code examples here or run them yet--
> I'm currently testing other things-- but I wonder if a small scaling factor
> needs to be used *somewhere*, to try and eliminate that effect. Something like
> scale <0.9999,0.9999,1>. Sorry if this proposal seems simplistic, but it's the
> first thing that popped into my head.
Thanks for thinking along, Kenneth!
> As for the textures etc not following the rotation of the whole object, that's a
> strange mystery...perhaps a hidden problem with the 'slope' pattern itself?
Yes, that is really strange, isn't it?
Date: 17 Jan 2024 08:29:38
Message: <65a7d642$1@news.povray.org>
Op 17-1-2024 om 12:43 schreef Bald Eagle:
> pleochromism.
Ha! Next fascinating problem! Excellent! :-)
