![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I'm about done with this scene, but before I do the final high-quality render I
thought I'd post this version to see if there are any suggestions. This took
about 10 hours to render; when I jack up the anti-aliasing and the radiosity
settings it will take 2-4x that, so I'm planning to start it before leaving for
the Thanksgiving holidays.
Nothing terribly new here in terms of techniques. I used some procedures I had
previously played with for stained glass windows to do the nativity set and the
"Merry Christmas" wall hanging. A bunch of the models are reused from earlier
renders, but updated with the latest techniques.
Enjoy, comment soon, and I'll post the final render next week.
-- Chris R.
Download 'scene-v1.1-hd-mq-rad11-2023-11-21.png' (1614 KB)
Preview of image 'scene-v1.1-hd-mq-rad11-2023-11-21.png'
![scene-v1.1-hd-mq-rad11-2023-11-21.png](/povray.binaries.images/attachment/%3Cweb.655cb30c9d766280c2a6235cc1b6e%40news.povray.org%3E/scene-v1.1-hd-mq-rad11-2023-11-21.png?preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
hi,
"Chris R" <car### [at] comcast net> wrote:
> I'm about done with this scene, ...
am not big on Xmas and things but "enjoy", yes. the "jigsawed" crib is simply
very beautiful.
fwiw, the moon needs shifting a little to the left (I think), and, perhaps, to
appear a fraction less "luminous".
regards, jr.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> -- Chris R.
Looking good, the tree especially is really nice and detailed! The only
suggestion I have is that the "Peace" bauble maybe looks a bit flat and might
benefit from being being shinier and more reflective. Looking forward to the
final render!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> -- Chris R.
I love it...very well done.
Mike.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> -- Chris R.
Nice scene composition.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"jr" <cre### [at] gmail com> wrote:
> hi,
> very beautiful.
> regards, jr.
Thanks!
The jigsaw was done by taking a png-file of a black-and-white pattern actually
used for creating a real jigsaw cutout. I used gimp to color each "piece" a
distinct color, and then in POV-Ray I wrote a function that compares the color
of a pixel in the image-map to the color of the piece I am rendering. If it is
close enough, the point is in the piece, if not, then it is excluded. This
became the isosurface shape function.
One issue I ran into is that the black cutting lines were fairly thick, so I had
to decide which "piece" each one belonged to and color them in. Since the lines
from the original were anti-aliased, I had to go back after doing a fill and
paint by hand over the anti-aliased sections to make them solid. There are
still artifacts from this that a real wood-cut, especially if you sanded it,
wouldn't show. I added some turbulence to the image-map pigment I was using and
that helped a little.
To get rid of the squarish edges and make them softer, I would like to figure
out how to do a gradient fill in gimp that would start with the color of the
piece, and when it gets near the black line edges start fading to black. I
could then use the distance to change the "thickness" of the wood near the
edges. My freehand drawing in gimp is terrible, and I don't know enough about
all of the tools to figure out how to do it in a neat and consistent manner,
though.
-- Chris R
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> This became the isosurface shape function.
That's an isosurface? :O
Have you tried just changing the threshold that you're evaluating the isosurface
at?
At 0, it should be crisp, as you increase the threshold, you should start to
round over any corners.
So what you eventually do is determine how much you need to "inflate" your shape
by, scale it down by that much, and then re-inflate to the original size by
increasing the threshold. Then you have a rounded version of the same size.
- BW
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> at?
> - BW
surface texture beyond what normals provide. To be clear, here, each piece of
the nativity is an isosurface, but they all use the same image map, just picking
different colors to determine which piece to create from it.
I generally leave the threshold at 0, and subtract off fudge factors or noise
functions from the actual shape function instead. It has the same effect.
Here, because my image map currently has a single solid color for each piece,
the color distance function essentially returns a fixed negative number if the
thickness/2 and add in noise for scratches and varnish strokes. If I could find
a way to get the image map to bleed the colors at the edges of the pieces, I
could have gradation in the color distance function and that would modify the
thickness of the wood at that point so I could bevel or round the edges.
#local imgpfn = function {
#local Color_match = function(r1,g1,b1,r2,g2,b2) {
max(
abs(r1-r2),
abs(g1-g2),
abs(b1-b2)
function {
max(
Color_match(imgpfn(x,y,0).red,imgpfn(x,y,0).blue,imgpfn(x,y,0).green,R,G,B),
abs(z) - thickness/2
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
If I could find
That's very impressive, and clever.
I was trying to figure out a way to use the object pattern to do something
similar, maybe this might give me some ideas.
Attached, please find a simple convolution kernel scene I was playing with a
while back.
Try applying the box blur filter, and only modifying the color channel of
interest.
- BW
Download 'edgedetectionmatrix.pov.txt' (4 KB)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Nice, I too think the bauble with Peace on it looks a bit flat/too matte a
finish.
The other two on the table look great though and the tree is really good.
The other point I would add is the lights on the fireplace, they are too dull
and don't appear to be emitting any light onto the surface right next to them. I
would try either a dim light source for each (will slow things down) or union
each fairy light with a sphere with emitting media. Something like below:
sphere{ 0,1
pigment { rgbt 1 } hollow
interior
{ media
emission colour rgb <1,0.8, 0.6> samples 20,100
density
{ spherical turbulence 0.05 omega 0.7 density_map
[0.0 rgb <0, 0, 0> ]
[0.8 rgb <0.2, 0.2, .1>]
[1 rgb <1.5, 1.2 0.8> ]
The above media is incredibly quick to render so shouldn't slow things down.
Sean
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
