![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thomas de Groot <tho### [at] degroot org> wrote:
> Very interesting indeed. You might consider slicing off the polygonal
> buildings when the angle gets too sharp. There are rooms there which are
> impossible to furnish ;-)
I think I already do, but the threshold angle is quite small.
Just get sharper furniture!
Bill
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Kenneth" <kdw### [at] gmail com> wrote:
> Wow, that is looking really cool. Your method looks more 'organic'/natural than
> my attempts so far, regarding street layout, non-square buildings etc.
> Currently, I'm wrapped up in the minutia of making more building height_field
> faces, for more variety in the city-- which gives me time to figure out the best
> way to tackle these other (more important) considerations, and how to code it
> all ;-) My SDL scene is likewise getting quite complex. Your non-SDL approach
> appears to be very sophisticated! Kudos. I'm looking forward to seeing how it
> progresses.
The very first thing I did was to parametrise buildings so they could be made
randomly with a degree of variety. And then I got bogged down with making them
polygonal, then with streets, then how to get those streets, then the various
edge cases that crop up...!
Since most of the groundwork is now laid, I can concentrate on colour, texture
and detail. Window sills via repeat object textures, roof styles and furniture
(aircon, water towers, masts etc), and some more building styles and sub-types.
I also really want to do some more work on the height selection, to get some
interesting cityscapes with 'hills' and 'valleys'. It's been a bottom-up
approach, so it's only recently started to all come together :)
Bill
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> On 20-3-2018 0:27, Bill Pragnell wrote:
>> So, inspired by Kenneth's recent forays into city building, I've
>> returned to a
>> project that I started over 3 years ago.
>> This started as a set of SDL macros, but unfortunately it was getting
>> dog-slow
>> and impossible to maintain so I started over in C++. I'm using SVG
>> files as
>> input, reading straight-line paths to define streets, intersecting
>> them to make
>> block polygons, then splitting the blocks to get building polygons. The
>> buildings are constructed as triangle blocks and exported as mesh2
>> objects in
>> ...inc files.
>> In the images here, the building data is a few MB in size, generated
>> in several
>> seconds by my program and rendered in several minutes by POV-Ray.
>> I have a huge to-do list, and progress is sporadic because real life,
>> but I am
>> getting some nice results at last!
You probably did not see the World's narrowest house...
It's 5 stories high, and have only a single window on each top floors.
The ground floor have only a single door and a narrow window. Go inside,
and you can easily touch the opposing walls, everywhere.
It's to narrow for a double bed.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
....and a different city from a more 'real' viewpoint.
Download 'city_low_view.jpg' (225 KB)
Preview of image 'city_low_view.jpg'
![city_low_view.jpg](/povray.binaries.images/attachment/%3Cweb.5ab2d872653a98a11b6c6b3a0%40news.povray.org%3E/city_low_view.jpg?ttop=426068&toff=100&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 21/03/2018 22:10, Bill Pragnell wrote:
> .....and a different city from a more 'real' viewpoint.
Looking good.
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
It's looking better and better <*sigh*> You've also solved the need for
'recessed' building sections on top of the 'main' buildings. I still haven't
tackled that (well, with my newer 'buildings as height_field faces' scheme,
anyway.)
Your approach is well worth the effort!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>> returned to a
>>> dog-slow
>>> files as
>>> them to make
>>> objects in
>>> ...inc files.
>>> in several
>>> but I am
>> are impossible to furnish ;-)
Well, I know Amsterdam has one at least. ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Do you mean the 'compound' buildings with the decreasing sizes? Those are
basically a specialised building type that just creates two or three
sub-buildings with different versions of the base polygon. Since the building
construction already offsets polygons extensively, it wasn't a lot of work to
add this.
So far so good. But I think your buildings are much more detailed and realistic
on an individual basis, which I'm going to struggle with later on. It's
interesting to compare approaches on similar but unrelated projects - there are
indeed many ways to skin a cat!
Bill
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 22-3-2018 9:51, Bill Pragnell wrote:
[...] there are
Ouch! I hope no cats have been hurt in this project! ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> [...] there are
I can confirm that no cats were hurt during the development of this project, and
that all skinning incidents have been metaphorical in nature :)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
