POV-Ray : Newsgroups : povray.binaries.images : Set of old renders 5/10 - Water cup Server Time
19 Jun 2025 23:08:45 EDT (-0400)
  Set of old renders 5/10 - Water cup (Message 1 to 9 of 9)
Subject: Set of old renders 5/10 - Water cup
Date: 22 Jan 2018 17:45:01
Message: <web.5a6668b54e1984a03e9f57b0@news.povray.org>
Height field is used to mimick the waves
Download 'cup.jpg' (148 KB)
Preview of image 'cup.jpg'
Subject: Re: Set of old renders 5/10 - Water cup
Date: 24 Jan 2018 03:15:00
Message: <web.5a683f82c399a6d1a47873e10@news.povray.org>
A clever use of a height_field.
I like this; the 'embossed' shapes on the cup look to be actual geometry, not
just some fancy normals(?).
I wonder how this would look with POV-Ray's newer subsurface scattering effect
added?
Date: 24 Jan 2018 17:19:59
Message: <5a69068f@news.povray.org>
> added?
Those are normal perturbations. Look at the gold stripe going across the
flowers. It's flat. Also, the shape don't show any indentation on the edge.
Date: 24 Jan 2018 18:50:01
Message: <web.5a691b30c399a6d1a47873e10@news.povray.org>
As I look more closely at it, I think you're correct. It does appear to be a
'better-than-normals' appearance though... perhaps because of the slight dark
outlines around the flowery artwork. An optical illusion -- and an interesting
one to make note of for the future ;-)
Date: 24 Jan 2018 21:10:00
Message: <web.5a693c52c399a6d15cafe28e0@news.povray.org>
It does appear that way, doesn't it?  I was wondering how he achieved such a
beautiful effect, and you prompted me to unzip the source files he provided and
look.
It's just a bump map.
Alain pointed out the gold stripe, but that I suppose could be due to almost
anything, depending upon how the cup is "built".
> added?
Yes, that would be something to see, wouldn't it?
Perhaps add a thin layer of clear glaze with some crazing as well - perhaps do
an old/new comparison...
Really beautiful work.  This and the watch are my favorites.  Maybe I'll get the
time to peek at the source of that as well.  :)
Date: 25 Jan 2018 16:20:00
Message: <web.5a6a4942c399a6d13e9f57b0@news.povray.org>
> look.
> > added?
Thanks for your comments.
Yes it's just a bump map.
If you remove the area_light from the scene, it gets ugply : the bump effect
disappears
Povray 3.7 does not render POV 3.0 well.
I rendered the scene again but with povwin 3.0 (as orginially) and this time
the gold line  is now gone, and the bumps are reversed
Date: 27 Jan 2018 04:50:01
Message: <web.5a6c4a81c399a6d13e9f57b0@news.povray.org>
> > look.
> > > added?
> Hi,
> disappears
With the render, that's better..
Download 'cup_povwin3.0.jpg' (74 KB)
Preview of image 'cup_povwin3.0.jpg'
Date: 28 Jan 2018 15:20:01
Message: <web.5a6e2f63c399a6d13e9f57b0@news.povray.org>
> > > look.
> > > > added?
> > Hi,
> > disappears
I just wonder why the golden line appear once at the top in povray 3.0 (as it
should) and twice on povray 3.7.
To me it's a bug. I included the code in the middle.
Has the texture gradient handling changed ?
Download 'bug_povwin3.7.jpg' (341 KB)
Preview of image 'bug_povwin3.7.jpg'
Date: 28 Jan 2018 18:07:05
Message: <5a6e5799$1@news.povray.org>
>>>> look.
>>>>> added?
>>> Hi,
>>> disappears
Prior to version 3.5, the gradient pattern was reversed in the negative
region. Now, it's direction stay the same everywhere.
It incorrectly was:
It's now as it should always have been:
This can introduce some glitches with some older scenes that made use of
the inverted grade.
You can add "triangle_wave" to get alternated up and down slopes with a
period of 2. In your case, that would be a viable solution.
