POV-Ray : Newsgroups : povray.binaries.images : Victorian House Server Time
23 May 2024 02:43:08 EDT (-0400)
  Victorian House (Message 11 to 20 of 25)
<<< Previous 10 Messages Goto Latest 10 Messages Next 5 Messages >>>
Subject: Re: Victorian House
Date: 11 Oct 2017 10:20:01
Message: <web.59de280694b98191c9f2b0270@news.povray.org>
"And" <49341109@ntnu.edu.tw> wrote:
> I downloaded a sketchup 3d model on the 3d warehouse. Last week I processed it
> to a section view, and output to povray, then rendered this picture.
> I put the dissection model with an original model(not cut) with "no_image" in
> the scene to give an indoor lighting, so it can..., you see
> The model itself is good.
> The original imagine of mine is playing small dolls in the house...
In my point of view Povray is nice to render such an image. I feel it is a good
tool. I original thought that placing a repeat object(one with syntax
"no_image") is a bad idea. I assumed it will take very long time to render. But
just... in the range that can be.
But there are some bugs in the image. Why the small wardrobe is not completely
dark, it should be black but instead it appears dark red? Because I have checked
that there is no any open or window to the outside, and the only major light
source in the scene is the sunlight and the sky_sphere light.
Download 'strange point.png' (922 KB)
Preview of image 'strange point.png'
Date: 11 Oct 2017 10:36:50
Message: <59de2c82$1@news.povray.org>
Am 11.10.2017 um 16:19 schrieb And:
Maybe `ambient` is to blame?
Also, radiosity sometimes leaks light in places where it shouldn't.
Careful tuning of the parameters might help.
Date: 11 Oct 2017 10:40:00
Message: <web.59de2c3794b98191c9f2b0270@news.povray.org>
> Am 11.10.2017 um 15:19 schrieb And:
> > clipka <ano### [at] anonymousorg> wrote:
> >> Am 11.10.2017 um 09:53 schrieb omniverse:
> >>> I got the STL file too, and converted to OBJ then exported to POV but that won't
> >>> show the interior via CSG difference.
> >> You'll have to add an `inside_vector` statement (unless your converter
> >> software already does that for you).
> > So I see that it states an "inside_vector <0,0,1> "(from poseray) in the last
> > item in each mesh2 object. It does not contain sufficient information.
> With that statement, the mesh should work fine in CSG difference (or
> intersection or union, for that matter).
> Not sure what you mean by "it does not contain sufficient information".
Because there is just one vector <0,0,1> at the end, I suppose that it should
be a lot of vectors. Maybe each face have one vector, and should vary from face
to face, I don't know。。。 I suppose it should look like
that.
Date: 11 Oct 2017 12:21:12
Message: <59de44f8$1@news.povray.org>
Am 11.10.2017 um 16:35 schrieb And:
> that.
No; there is only one `inside_vector` per mesh; it tells POV-Ray that in
order to test whether a given point is inside the mesh or not, it should
shoot a ray in the direction specified by that parameter, and count the
number of surfaces encountered in that direction. If the count is odd,
the point must be inside the mesh; if the count is even, the point must
be outside.
Date: 11 Oct 2017 12:30:00
Message: <web.59de45fa94b98191c9f2b0270@news.povray.org>
One of view. 3f master suit.
Download 'home scene 15 1h8m39s.png' (488 KB)
Preview of image 'home scene 15 1h8m39s.png'
Date: 11 Oct 2017 19:41:32
Message: <59deac2c@news.povray.org>
> that.
There is never more than a single inside_vector par mesh.
I think that, if you have several vectors, then, only the last will be
used, each new one replacing the previous one.
You may need to slightly change it if there are triangles that are
parallel to it. But nothing else.
Date: 12 Oct 2017 02:40:00
Message: <web.59df0d7894b981917abd256f0@news.povray.org>
> > that.
> be outside.
Well, that it seems poseray adds a symbolic vector, because <0,0,1> does not
inside my model in fact. And it shouldn't get such an information because the
mesh was output from sketchup it does not contain that, moreover most of the
mesh 3d model does not have a well construct that contain a inside/ outside
distinction.
Date: 12 Oct 2017 02:59:27
Message: <59df12cf@news.povray.org>
Nice!! Didn't know the site, but I am sure to visit in future
Date: 12 Oct 2017 03:48:30
Message: <59df1e4e$1@news.povray.org>
>> be outside.
That is probably because PoseRay was designed to create mesh2's for
PovRay. So when things change in PovRay FlyerX updates PoseRay to
reflect that.
> distinction.
Which is probably because Sketchup was designed to upload content to
Google Earth. Not to a quality renderer.
Which is not a criticism of Sketchup. It produces good results as your
images show.
Regards
Date: 12 Oct 2017 05:05:01
Message: <web.59df2f2894b981917abd256f0@news.povray.org>
> images show.
> Regards
>      Stephen
> Thomas
By the way, many models of 3d warehouse were made for google earth in the past.
So its models lack details. But there are still many authors upload detailed
models.
