POV-Ray : Newsgroups : povray.binaries.images : More materials based on proximity patterns Server Time
18 Nov 2025 20:31:23 EST (-0500)
  More materials based on proximity patterns (Message 1 to 10 of 12)
Subject: More materials based on proximity patterns
Date: 3 Oct 2017 09:15:01
Message: <web.59d38d1358cfc649f2ea585a0@news.povray.org>
Recent posts here renewed my interest in proximity patterns.
After trying some methods, the best (in this setup) was that from ABX / Michael
Andrews (Death of a Cliche ...
http://news.povray.org/povray.binaries.scene-files/attachment/%3C3CC3D3E5.38B9F487@reading.ac.uk%3E/).
Some others are good in other situations (e.g. Samuel T. Benge
http://news.povray.org/povray.binaries.images/message/%3Cweb.4ed596b125fc27e89341ac0a0%40news.povray.org%3E/#%3Cweb.4ed
or Jim Charter  Ruined
http://news.povray.org/povray.binaries.images/message/%3C46808234%40news.povray.org%3E/#%3C46808234%40news.povray.org%3
E)
- of course I didn't forget mesh camera of JVP or the DF3 method of Edouard.
Here I used Rune's Illusion code with a pregenerated "proximity map".
A file with more than 20 "prox mats" will be published after some cleanup.
Norbert
Download 'proximity mats.jpg' (695 KB)
Preview of image 'proximity mats.jpg'
Subject: Re: More materials based on proximity patterns
Date: 4 Oct 2017 02:53:35
Message: <59d4856f$1@news.povray.org>
Excellent! It is good to have a choice according to the initial
conditions, or so I have learned. An overview of the different methods
is important too.
Date: 4 Oct 2017 07:47:57
Message: <59d4ca6d$1@news.povray.org>
Aside: I have been playing a bit with object patterns but I must confess
that I do not understand them... :-/
Date: 4 Oct 2017 10:10:01
Message: <web.59d4eb5df661679fc437ac910@news.povray.org>
> Thomas
One would assume that you've checked out FM's pages:
http://www.f-lohmueller.de/pov_tut/tex/tex_560e.htm
http://www.f-lohmueller.de/pov_tut/tex/tex_561e.htm
http://www.f-lohmueller.de/pov_tut/tex/tex_562e.htm
It looks like it's analagous to texture vs inside_texture in that it chooses one
texture or another. With this, it's not what "side" it on, it's whether or not
the point is any part of the object or not at all.
So presumably a[nother] good test scene would be a small object inside a
transmissive sphere - with the sphere representing the outside environment of
the object, and the object the inside.
[As with the rest of life] I find the pictures very helpful in understanding
what's going on.  When it's all text and I have to sound it out, people think
I'm talking to myself in some made up language...
Date: 4 Oct 2017 11:46:27
Message: <59d50253$1@news.povray.org>
Am 04.10.2017 um 13:47 schrieb Thomas de Groot:
They're pretty simple:
- Just like the `brick` or `checker` patterns, the `object` pattern is a
"choose one of two" pattern (as opposed to a "choose from a map" pattern
like `gradient`).
- You specify an arbitrary solid shape (may be CSG) to govern the actual
pattern, and every point in pattern 3D coordinate space is textured
according to whether it would be inside that shape or outside.
Think of this pattern as follows:
- Take the object specified in the pattern.
- Using vacuum forming, create a template from the pattern object.
- Discard the pattern object.
- Pour material A into the template.
- Pour material B around the template.
This creates a solid block, partially made from material A, and
partially made from material B, which is now your texture (or pigment).
- From the resulting block, carve an entirely different shape (the
actual object that uses the `object` pattern)
Date: 4 Oct 2017 19:20:00
Message: <web.59d56c16f661679f9c5d6c810@news.povray.org>
That's some wild stuff there. Brings a whole new dimension to that one object.
Going to those past messages about this sort of thing shows what I was missing
out on when I decided to do more RL things (sightseeing motorcycle rides for
one).
I must make more of my own (even if feeble) attempts at this proximity pattern
thing too!
Thanks for the look!
Date: 5 Oct 2017 03:00:07
Message: <59d5d877$1@news.povray.org>
Thanks Clipka and Bald Eagle; I indeed forgot to consult FL ;-)
I fully understand now.
Date: 6 Oct 2017 13:05:08
Message: <web.59d7b701f661679f473ac47e0@news.povray.org>
Thank you for the comments.
I just downloaded the demo file with 25 proximity materials on
(http://news.povray.org/povray.binaries.scene-files/thread/%3Cweb.59d7a90b58cfc649473ac47e0%40news.povray.org%3E/).
It's a 4 part download because of mesh size.
By the way - here is another render with 2 extremely large meshes (600 MB for
the Napoleon statue and 400 MB for the dragon figure in mesh2 formate).
It took several trials with different PoseRay versions to transform the basic
obj files (coming from Artec 3D -
https://www.artec3d.com/3d-models/art-and-design).
What are your experiences with large models - are there ways to improve
stability of the mesh conversion?
Regards
Norbert
Download 'napoleon & dragon_prox.jpg' (446 KB)
Preview of image 'napoleon & dragon_prox.jpg'
Date: 7 Oct 2017 02:49:43
Message: <59d87907$1@news.povray.org>
Thanks for this Norbert.
Concerning conversion of very large models/meshes (from obj to mesh2), I
seem to remember issues with them in Poseray. However - now that I think
about it - they mainly concerned using subdivision levels and thus
crashing Poseray. It may be something to talk about with FlyerX. With
meshes becoming more complex alongside faster hardware and more memory,
there might come a moment when Poseray will need an upgrade (rather than
an update?).
Date: 7 Oct 2017 07:47:27
Message: <59d8becf$1@news.povray.org>
Am 10/6/2017 um 19:01 schrieb Norbert Kern:
PoseRay is a 32bit Application and as such can't handle huge meshes.
Disabling it's OpenGL preview (within the Preview pane) helps and allows
for converting meshes that would otherwise crash it - up to some point.
Personally I prefer Blender (64bit) for converting meshes to POV-Ray
format - if needed.
-Ive
