POV-Ray : Newsgroups : povray.binaries.images : Fractured Destination Server Time
9 Jun 2024 04:59:24 EDT (-0400)
  Fractured Destination (Message 21 to 30 of 37)
<<< Previous 10 Messages Goto Latest 10 Messages Next 7 Messages >>>
Subject: Re: Fractured Destination
Date: 5 Jun 2017 07:45:01
Message: <web.593543ad6befef94c437ac910@news.povray.org>
> To get the topic back to POV-Ray... there are in fact some electronic
> pieces in my collection which I really would like to translate into
> POV-Ray images or animations...
Currently, I'd have to cast my vote for:
"Phobos and Deimos go to Mars"
Date: 6 Jun 2017 03:05:01
Message: <web.5936516a6befef94ed9f7b990@news.povray.org>
> Good to see you making more scenes for your world :)
Cheers! :) There are plenty of ideas popping up constantly and already planned
stuff on my to-do list as well, so more scenes coming up for sure. :)
> This latest series of images would be a good basis for a weird animation.
Hehe, still trying to wrap my head around animation in POV, but perhaps some
day. :D
"Simon J. Cambridge" <nomail@nomail> wrote:
> Are these images composites or a single rendering?
All my images are single renders, and I tend to keep the resolution of 1280 x
720 in the final POV output.
To open my planetary scenes a bit, they're somewhat minimalistic in structure
and code. Eg. this latest one is an f_wrinkles isosurface with scattering media
around it and camera zoomed in (or zoomed out as in the image from the orbit).
No light_source as separate object this time, but emission on the media and
reflection on the object texture. Then the usual stuff with radiosity and focal
blur. The 3 images close to surface are actually the one and same scene, but
with different camera angles and blur values, and a bit of rotation here and
there. =)
As for some music things, while POVing I often find myself listening to the
older games music stream at: http://www.kohina.com/
Tunes my brain nicely for some "weird" things, hehe. :D
Date: 6 Jun 2017 08:05:01
Message: <web.593699946befef94c437ac910@news.povray.org>
Indeed!  "A creative man is motivated by the desire to achieve..."
> day. :D
Until you actually do it, it seems a little intimidating.
But all it is, a separate "scene file" (the .ini file) that performs the
equivalent of a for/next loop:
#for (clock, 0, 1, STEP)
     // render your scene file for all clock values
.... only this takes place OUTSIDE of the scene file, so for every clock value,
the scene gets rendered, and then the clock increments - whereas, obviously, a
#for-next loop INSIDE the scene file runs the full range and THEN the scene gets
rendered.
That's pretty much all there is to it.
(just copy the scene and the .ini to a separate directory to keep all of those
rendered frames easy to manage)
Then you just pop open something like VideoMach, highlight all of the frames,
select the video file type, and hit GO.   And you're done.
So you just use clock just like any other variable in your scene.
Add it to anything, multiply things by it, divide things by it....
clock * 360 will give you 360 degrees
clock * tau will give you 2*pi radians
translate <X+clock, 0, 0> will make something move to the right
scale 1-clock will make it shrink away to nothing
you can use it in isosurface functions, as the amplitude for noise, as an rgb
component, as a light source strength, a camera location or look_at attribute
Just give it a go - you'll like it   :)
> there. =)
Date: 6 Jun 2017 09:05:01
Message: <5936a87d$1@news.povray.org>
>> day. :D
> #end
An alternative view.
I prefer to use frame_number rather than the clock variable.
For a start you will want to know how long your animation to last and
the framerate of your animation. This will give you the total number of
frames needed. I find it easier to work with integers as when working
with complicated animations it is useful to define key frames where
changes occur. The arithmetic* is not really harder than using decimals
and reduces the chances of rounding errors. It also makes it easier to
have cyclic functions within your animations using mod(A,B).
> ..... only this takes place OUTSIDE of the scene file, so for every clock value,
> rendered.
Or you can define where the image files are to be saved in the ini file.
Alternatively there is an option to define the output directory in
povray.ini. (But I cannot remember what it is as it has been years since
I used it. :-(  )
Which reminds me that you can have your clock running from A to B not
just 0 to 1
And it is fascinating watching your animation render frame by frame.
So don't let the multiple ways of doing things put you off. It is
certainly easier using the clock variable to start off.
* I've given up on the maths Vs math controversy. I'm now going to
concentrate in correcting the world when it uses maths for something
that is only arithmetic. ;)
Regards
Date: 6 Jun 2017 10:10:00
Message: <web.5936b7586befef94c437ac910@news.povray.org>
> changes occur.
I have not learned the method doing animations through KeyFrames (yet), but it
seems to be the way a lot of people do things.
You certainly are a ... polymath.  :D
> I used it. :-(  )
Noted.  Thanks!
> just 0 to 1
Well, sure.
I also have learned not to use the clock variable directly, as I have often run
into the situation where I want to modify something halfway in.
So rather than having to hunt down all of the instances of clock, I usually
start off with
#declare Clock = clock;
And then all I have to do is edit my single function.
#declare Clock = clock*2;
#declare Clock = clock*360;
#declare Clock = (clock*9)+1;
Fascinating .... and sometimes dismaying, when you've totally miscalculated
something in a long train of ... maths.
Date: 6 Jun 2017 11:24:29
Message: <5936c92d$1@news.povray.org>
>> changes occur.
It is the way to go when your scene starts getting complex. Break things
down to the lowest common denominator. Then put them back together
again. That is why (for me) using frame_number with initial_frame &
final_frame is better than plain simple clock.
For instance, in this animation. The chain drive between two of the
drive gears is only a quarter of a full revolution of the drive,
repeated ad infinitum.
https://www.youtube.com/watch?v=VfVRnAHu4JI
But then I came to PovRay because I wanted to make a fly through a
Fractint plasma heightfield almost 20 years ago. (Still not done it.)
Here is what I did instead.
https://www.youtube.com/watch?v=RP4BMrfMLSk
https://www.youtube.com/watch?v=d-OPfs25aRM
Most of my animations are cyclic.
Wrong word. I am more of an autodidact. You can't teach me anything. ;)
I've got to learn from my mistakes. Of which I make many. :(
>> I used it. :-(  )
> Noted.  Thanks!
It was a "FYI". I use your method. :)
>> just 0 to 1
> Well, sure.
> start off with
Whichever way you do it. Sums are involved. :)
Wrong attitude. ;) It gives you an opportunity to restart before the end.
https://www.youtube.com/watch?v=jHPOzQzk9Qo
Regards
Date: 6 Jun 2017 12:15:01
Message: <web.5936d4bc6befef94c437ac910@news.povray.org>
This may be of interest:
"This file may help, if you want to create a POV-Ray-animation, which is
splitted in to many parts (all parts take the same amount of time).
For example: The clock value should run from 0 to 1 in the 3rd part of a total
amount of 7 parts. Then "Sclock_01(3,7)" will exactly do that for you."
http://flex.phys.tohoku.ac.jp/public_html/simon/povray/GIF/Clock_Splitting.txt
Date: 6 Jun 2017 14:02:34
Message: <5936ee3a@news.povray.org>
I thought it was pretty simple: in the USA (and Canada?), you say
"math"; in the rest of the world, it's "maths."  Same idea as with
colo(u)r and alumin(i)um.  It's not a controversy unless you choose to
make it one.
(With Canada, I'm never sure.  They are linked to the UK, yet are so
much like USAmericans.)
Date: 6 Jun 2017 14:26:14
Message: <5936f3c6$1@news.povray.org>
> make it one.
But I do, I do :)
Actually it hurts my ears and offends my sensibilities to hear it. I
know that it is irrational but...
You won't make any friends with Canadians with that statement. ;)
And you know what you can do with your elected president over his
comments about London Bridge. Nothing personal but he has really, really
annoyed us as a nation. </aside
Regards
Date: 6 Jun 2017 14:36:29
Message: <5936f62d$1@news.povray.org>
Go ahead, make it personal.  I'll understand.
