"LanuHum" <Lan### [at] yandex ru> wrote:
> "And" <49341109@ntnu.edu.tw> wrote:
> > Another picture:
> It gives to hope!
Oh, this is just like Cousin Ricky's sphere sweep macro. I spend some time
studying it. Thanks to him.
This is not the 'sphere_sweep' object of povray, it just a union. The union
contains some spheres and cylinders.
If you want to add to your scene:
#include "bezier_spheresweep.inc"
#declare my_bezier_points =
array[8]{
<0, 0, 0>, <0.2, 0.3, 0.1>, <0.6, 0.1, 0>, <1, 0, 0>,
<1, 0, 0>, <1, -0.5, 0>, <1.2, -0.5, 0.5>, <1.6, -0.6, 0.8>
object{
Shape_Bezierpoints_Sphere_Sweep(20, my_bezier_points, 0.02)
pigment{rgb<0.1,0.2,0.2>}
Something doesn't coincide.:(
#version 3.7;
#include "shapes.inc"
#include "functions.inc"
global_settings {
assumed_gamma 1.000000
sky_sphere {
pigment {rgb<0.050, 0.050, 0.050>}
#declare Default_texture = texture{pigment {rgb 0.8}}
#declare Material = texture{
pigment{color rgbft <0.8000,0.0127,0.0332,0.0000,0.0000>}
#declare Material_001 = texture{
pigment{color rgbft <0.0123,0.0084,0.8000,0.0000,0.0000>}
#declare Material_002 = texture{
pigment{color rgbft <0.0803,0.8000,0.0184,0.0000,0.0000>}
#declare Material_003 = texture{
pigment{color rgbft <0.6392,0.8000,0.5126,0.0000,0.0000>}
#declare data_Cylinder_shape_002_ob = cylinder { <0,0,1>,<0,0,-1>,1
#declare data_Cylinder_shape_001_ob = cylinder { <0,0,1>,<0,0,-1>,1
#declare data_Cylinder_shape_ob = cylinder { <0,0,1>,<0,0,-1>,1
union {
#declare BezierCurve_bezier_points = array[8]{
<-1,0><-0.5,0.5><0,0><1,0>
<1,0><2,0><-0.2001,0.2996><0.7999,0.2996>
#declare data_BezierCurve_ob = object{Shape_Bezierpoints_Sphere_Sweep(20,
BezierCurve_bezier_points, 0.02)
texture {Material_003}
object {data_Cylinder_shape_002_ob
texture {Material}
matrix <-0.000000, -0.000000, -0.034897, 0.000000, 0.034897, -0.000000,
14.249066, -0.000001, -0.000001, 0.000000, 0.000000, 0.000000>
object {data_Cylinder_shape_001_ob
texture {Material_002}
matrix <0.034897, 0.000000, 0.000000, 0.000000, 0.034897, 0.000000,
0.000000, 0.000000, 10.180943, 0.000000, 0.000000, 0.000000>
object {data_Cylinder_shape_ob
texture {Material_001}
matrix <0.034897, 0.000000, 0.000000, 0.000000, -0.000000, -0.034897,
0.000000, 3.339409, -0.000000, 0.000000, 0.000000, 0.000000>
object {data_BezierCurve_ob
matrix <4.031789, 0.000000, 0.000000, 0.000000, 2.190180, -3.385031,
0.000000, 3.385031, 2.190180, 0.000000, 0.000000, 0.000000>
light_source {
<5.07,5.58,4.28>
color rgb<1, 1, 1>
fade_distance 25.0000000000
fade_power 1
perspective
location <0,0,0>
look_at <0,0,-1>
right <-1.7777777777777777, 0, 0>
up <0, 1, 0>
angle 49.134343
rotate <-27.098163, 46.688390, -0.903519>
translate <7.481132, 5.343666, 6.507640>
Download 'bezier_sweep.blend.jpg' (80 KB)
Preview of image 'bezier_sweep.blend.jpg'
> #version 3.7;
> global_settings {
> sky_sphere {
> union {
> texture {Material}
> light_source {
> <5.07,5.58,4.28>
> color rgb<1, 1, 1>
> fade_power 1
> camera {
> perspective
> location <0,0,0>
> look_at <0,0,-1>
> up <0, 1, 0>
> angle 49.134343
union{
sphere{
<-1,0>, 0.05
sphere{
<1,0>, 0.05
sphere{
<1,0>, 0.05
sphere{
<0.7999,0.2996>, 0.05
pigment{rgb 0.5}
-3.385031,0.000000, 3.385031, 2.190180, 0.000000, 0.000000, 0.000000>
I'm not sure what causes this, but I drew some spheres in addition, it fits the
terminals of the curve. Or you actually drew three dimension coordinates but you
output just two dimension coordinate data?
Download 'bezier_sweep_test2.png' (78 KB)
Preview of image 'bezier_sweep_test2.png'
I don't understand.
Two spheres coincide with coordinates.
The third sphere doesn't coincide.
#version 3.7;
global_settings {
sky_sphere {
pigment{color rgbft <0.0485,0.8000,0.0262,0.0000,0.0000>}
pigment{color rgbft <0.8000,0.0068,0.1947,0.0000,0.0000>}
pigment{color rgbft <0.0107,0.0259,0.8000,0.0000,0.0000>}
pigment{color rgbft <0.0227,0.8000,0.0175,0.0000,0.0000>}
#declare Material_004 = texture{
pigment{color rgbft <0.8000,0.0196,0.0155,0.0000,0.0000>}
#declare data_Sphere_shape_002_ob = sphere { 0,1
#declare data_Sphere_shape_001_ob = sphere { 0,1
#declare data_Sphere_shape_ob = sphere { 0,1
union {
<1,0><2,0><1.025,2.45><2.025,2.45>
texture {Material_004}
matrix <-0.000000, -0.035411, 0.000000, 0.000000, -0.000000, -0.035411,
17.995750, -0.000001, 0.000000, 0.000000, 0.000000, 0.000000>
matrix <0.035411, 0.000000, 0.000000, 0.000000, 0.035411, 0.000000,
0.000000, 0.000000, 19.020086, 0.000000, 0.000000, 0.000000>
matrix <0.035411, 0.000000, 0.000000, 0.000000, -0.000000, -0.035411,
0.000000, 13.345572, -0.000001, 0.000000, 0.000000, 0.000000>
object {data_Sphere_shape_002_ob
texture {Material}
matrix <0.203845, 0.000000, 0.000000, 0.000000, -0.000000, -0.203845,
0.000000, 0.203845, -0.000000, 2.025354, 1.852481, -2.450227>
object {data_Sphere_shape_001_ob
texture {Material}
0.000000, 0.203845, -0.000000, 1.000000, 0.000000, 0.000000>
object {data_Sphere_shape_ob
texture {Material}
0.000000, 0.203845, -0.000000, -1.000000, 0.000000, 0.000000>
matrix <1.000000, 0.000000, 0.000000, 0.000000, -0.000000, -1.000000,
0.000000, 1.000000, -0.000000, 0.000000, 0.000000, 0.000000>
light_source {
<5.07,5.58,4.28>
color rgb<1, 1, 1>
fade_power 1
perspective
location <0,0,0>
look_at <0,0,-1>
up <0, 1, 0>
angle 49.134343
Download 'bezier_sweep.jpg' (188 KB)
Preview of image 'bezier_sweep.jpg'
Oh,I forgot to bind the third coordinate Z!
Sorry! Sorry! Sorry!
It is good to change thickness in each control point, as in official
sphere_sweep,
Download 'good_bezier_sweep.jpg' (28 KB)
Preview of image 'good_bezier_sweep.jpg'
> union {
The problem is: Your bezier curve points in Blender is three dimension, but when
you export them, you only output x and y, in other word 2d points.
A 3D point in pov-ray should be like this: <1.0, 0.2, 1.0>
A 2D point in pov-ray is like this: <1.0, 0.2>
> sphere_sweep,
Good.
I would like to sleep now.
Good night! :)
Thank you!
Now I can create CSG:
difference{
object {Bezier_prism}
object {Bezier_sweep}
Download 'diff.jpg' (31 KB)
Preview of image 'diff.jpg'
> Good night! :)
> Thank you!
> difference{
Ok! The sky is dark again.
