POV-Ray : Newsgroups : povray.binaries.images : A Planetary Journey Server Time
20 Apr 2026 11:31:25 EDT (-0400)
  A Planetary Journey (Message 4 to 13 of 23)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: A Planetary Journey
Date: 9 Aug 2015 14:25:00
Message: <web.55c79a9f52ac8b06a45e3d720@news.povray.org>
"LanuHum" <Lan### [at] yandexru> wrote:
> "MichaelJF" <mi-### [at] t-onlinede> wrote:
> > Playing around with media to model a sunrise I came up with the following image
> > finally.
> > And yes, there are people trying to walk a rope between hot air balloons. They
> > rely on their parachutes.
> > For the balloons I took an IRTC-Entry by Neil Alexander as starting point.
> > Image_maps of Earth and Mars are from NASA of course.
> > Enjoy and best regards,
> > Michael
> Beauty!!! Sun! Very Beauty!!!
Many thanks from Germany to Russia!
Best regards,
Michael
Date: 9 Aug 2015 14:35:01
Message: <web.55c79d2252ac8b06a45e3d720@news.povray.org>
> Am 09.08.2015 um 19:06 schrieb MichaelJF:
> > finally.
> The media, trees and far-off balloons look gorgeous!
> I think the tightrope walker is a bit too large; maybe 70% of its size
> should be a better fit.
> I'm not so happy with the Earth, Mars, red-white striped, and
> yellow-orange banded balloons; they look as if they didn't receive any
> sunlight, while instead glowing on their surface.
> If this is supposed to be glow from the propane burners, it should be
> (1) darker, (2) more coloured, and (3) be more intense near the bottom
> of each balloon. One way to achieve this might be to place light sources
> at the propane burner locations with proper distance-based falloff, and
> use arse... um, I mean, backside illumination on the balloon skins
> ("diffuse X,Y" or, better yet, "diffuse albedo X,Y", where X+Y < 1).
Many thanks for your comments.
One has to make compromises in CG. The walker is 2.10 m in height. Huge but not
impossible. The main problem I saw was the rope and the balance pole. They are
/* very */ much thicker as they should be. But invisible otherwise. And still
the anti-aliasing has problems with them. But increasing the the anti-aliasing
recursion depth yielded problems with the general lighting. So I had to meet a
compromise.
For your suggestion of arse illumination I have to study a little bit more. But
not with this image. I like it, and it will be as it is.
Best regards,
Michael
Date: 9 Aug 2015 14:44:22
Message: <55c79f86$1@news.povray.org>
Am 09.08.2015 um 20:34 schrieb MichaelJF:
> compromise.
You might give UberPOV's stochastic anti-aliasing mode a try.
Date: 9 Aug 2015 14:56:04
Message: <55c7a244$1@news.povray.org>
> Michael
That is no bad, Michael
Might go as far as saying it is AWESUM
Regards
Date: 9 Aug 2015 15:05:01
Message: <web.55c7a45052ac8b06a45e3d720@news.povray.org>
> > Michael
> Regards
>      Stephen
Thank you very much, Sir ;-)
Michael
Date: 9 Aug 2015 15:17:42
Message: <55c7a756$1@news.povray.org>
>>> Michael
>> Regards
>>       Stephen
My pleasure. :-)
Regards
Date: 9 Aug 2015 16:25:57
Message: <55c7b755$1@news.povray.org>
On 8/9/2015 6:26 PM, clipka wrote:
> and use arse... um, I mean, backside illumination
I see what you did.
Alternative spelling: erse :-)
Regards
Date: 10 Aug 2015 15:40:00
Message: <web.55c8fd0452ac8b06b426f96a0@news.povray.org>
> finally.
> Michael
Good metaphor, although some would say a moon-textured balloon needs to go
between the others :P
The lighting is nice and moody, too, especially near the middle of the image.
Date: 10 Aug 2015 15:45:01
Message: <web.55c8fe2d52ac8b06279604b00@news.povray.org>
I'm not quiet sure if I can enter the image into the actual TC-RTC competition.
First the link to the topic is only the connection about a journey which is a
bit weak.
But a weak link to a topic is not really my problem. Ian has a very constructed
link this round as well IMO. But Normand still has the Earth as a Balloon.
Otherwise there are only three entries so far.
What to do? Suggestions are welcome!
Best regards,
Michael
Date: 10 Aug 2015 16:16:53
Message: <55c906b5$1@news.povray.org>
> bit weak.
Without discussing it. Go for it.
Discussing it:
It would be a shame if you did not enter the image as it is so good.
It is a mistake to think that similar images are not wanted. They are,
it makes comparison easier. If the topic was Balloons everyone would
have a balloon image.
You have carte blanche to use your imagination.
Regards
