POV-Ray : Newsgroups : povray.binaries.images : An artifact when rendering torus(negative major_r) Server Time
31 Mar 2026 16:37:53 EDT (-0400)
  An artifact when rendering torus(negative major_r) (Message 10 to 19 of 19)
<<< Previous 9 Messages Goto Initial 10 Messages
Subject: Re: An artifact when rendering torus(negative major_r)
Date: 9 Apr 2015 02:45:01
Message: <web.55261ed188bb499a5335aca40@news.povray.org>
And the polynomial version:
It is still there, but not so visible.
Download 'torus test2 1 poly.png' (182 KB)
Preview of image 'torus test2 1 poly.png'
Date: 9 Apr 2015 06:33:02
Message: <5526555e$1@news.povray.org>
On 09/04/2015 07:33, And wrote:
> ... this is what I rendered.
That is the pattern I got when I used your original code. But something
looks wrong with the shading and shadows. So I did a series of renders
with a simpler material that is matt. I orbited the light around your
shape and included a couple of primitives (two spheres and a lathe)
using the same texture, for comparison. The Blue arrow points to the light.
Unless someone can explain it by the shape of the object. It looks like
a bug to me.
Light orbiting horizontally
https://youtu.be/iOffuoxXjYo
Light orbiting horizontally at 45 deg
https://youtu.be/rz9dS-cCHAs
Light orbiting in vertical plane
https://youtu.be/X1EUq1VCXgY
Regards
Date: 9 Apr 2015 12:17:24
Message: <5526a614@news.povray.org>
Am 09.04.2015 um 12:33 schrieb Stephen:
> a bug to me.
Thanks for experimenting with this.
Yes, this certainly is a bug. I haven't looked at the code yet, but
judging from the effect I would assume that the surface normal at a
given intersection point is computed as the (normalized) vector from the
closest point on the "centroid circle" to the surface point; obviously
this breaks down for the inner spindle of a spindle torus.
Is this the Poly_Torus or the inbuilt torus primitive?
Date: 9 Apr 2015 12:48:59
Message: <5526ad7b$1@news.povray.org>
No problem. It was bugging me.
Interesting effect.
https://youtu.be/IMu4EEgtbdU
One of the other tests.
The arrow is pointing at the parallel light source.
Obviously.
The inbuilt torus primitive. Rendered in Ver 3.62
Regards
Date: 9 Apr 2015 15:01:04
Message: <5526cc70$1@news.povray.org>
Am 09.04.2015 um 18:17 schrieb clipka:
And that's exactly what's happening.
I've just submitted a fix to GitHub
(https://github.com/POV-Ray/povray/commit/c3551f249c89ffc817a4deb2acea0412a0b9913f).
Date: 9 Apr 2015 15:30:01
Message: <5526d339$1@news.povray.org>
Am 09.04.2015 um 21:01 schrieb clipka:
BTW, the intention of the new implementation is that a spindle torus
(one that intersects itself) behaves like a union, i.e.:
- the spindle volume (the volume of self-intersection) is considered to
be inside the torus
- the spindle surface is visible (provided you find a way to look
through the regular torus surface), and textured as a straightforward
continuation of the regular torus surface; most notably, when using an
interior_texture, the spindle surface's side facing the coordinate
origin uses the interior_texture, while the other side uses the regular
texture.
(If someone wants to do me a favor, can you please test whether the UV
mapping on the spindle surface makes sense.)
Also, specifying either a negative major or minor radius now has the
same effect as using the "inverse" keyword, but prompts a parse warning.
(Specifying both a negative major and minor radius negates the effect,
but will prompt two warnings.)
Date: 10 Apr 2015 04:35:48
Message: <55278b64$1@news.povray.org>
Nice one Clipka. :-D
I had better leave the compiling to someone who can do it.
Regards
Date: 10 Apr 2015 12:05:01
Message: <web.5527f3c088bb499a5335aca40@news.povray.org>
> be inside the torus
> texture.
Hum! Thank you very much. But from the point of view of equation, a negative
major or minor radius should produce the same geometry as the positive one.
I can't compile it, too.
Date: 11 Apr 2015 22:00:01
Message: <web.5529d14e88bb499a71b41f500@news.povray.org>
> > a bug to me.
This ancient thread might be relevant:
Newsgroup: povray.binaries.images
Subject: Torus problem (69KB)
Date: 21st April 2000
http://news.povray.org/povray.binaries.images/thread/%3C38FFC5BF.757B1EBB%40hotmail.com%3E
Tor Olav
http://subcube.com
Date: 12 Apr 2015 01:58:28
Message: <552a0984$1@news.povray.org>
Am 12.04.2015 um 03:58 schrieb Tor Olav Kristensen:
> From: Tor Olav Kristensen
It's pretty irrelevant insofar as I don't need it to debug or fix the
issue reported by And - I've already done that by now :)
But yes, the issue you reported back then might be related indeed.
