![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Insufficient coffee made me forget to ask about scaling and repeating the image
mapping by omitting once and perhaps doing other clever things...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 10-10-2014 15:45, Bald Eagle wrote:
> I might see if I can mesh model something, but I haven't really ever used a mesh
> modeler. Not looking forward to making all those acanthus leaves and
> scrollwork...
Both methods (sdl or modeller) have their pro and cons. With both you
need only to model a small part of the object and then copy
>mirror>paste that to obtain the final result, with the better
alternative being: doing those last actions in POV-Ray. . I think that
sdl would take a little more time to get there but the basic workflow is
the same. For really complex models mesh2 models are to be preferred to
sdl models as they can be significantly faster to render. However, that
is less of an issue nowadays with faster PC's.
> A heightfield might give me something I could image map just to see if I like
> one particular design more than another. Though a nicely shaded planar image
> map would likely serve the same purpose.
Yes, but you need a good quality height map for your height_field and
that is a bit more difficult to achieve imo.
> Lastly, I was toying with cobbling together an SDL object that would mimic the
> gross contours of the object and then image map over that to quickly give a
> textured object with an actual 3D shape. Worth doing?
Yes, worth the try if the object is not too prominent in the camera view.
> {"No, you dolt - use a modeler, or perform another blood sacrifice and be
> inculcated with the sacred power of POV SDL....")
I would do both, which means /two/ blood sacrifices of course as you
need the infernal modeller powers too... ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hmm. If considering your image, which is circular, I guess you will need
'once'...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> 'once'...
I was thinking that since it's circular, if I had it repeat across the surface
so that I had 2 full images, each hemispherical, then I could map it onto an
oblate spheroid and then bury it halfway into the ceiling.
So there.
With regard to blood sacrifice, clipka has slayed the Gamma Dragon, so now
THAT's not an option. Somehow Spline Ducks don't quite have the same sense of
grandeur. But then.. wait ... yes! The Stanford Chocolate Bunny!!!
Bring out the Holy Hand Grenade!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
And the LORD spake, saying, "First shalt thou take out the Holy Pin,
then shalt thou count to three, no more, no less.
Three shall be the number thou shalt count, and the number of the
counting shall be three.
Four shalt thou not count, neither count thou two, excepting that thou
then proceed to three.
Five is right out.
Once the number three, being the third number, be reached, then lobbest
thou thy Holy Hand Grenade of Antioch towards thy foe, who being naughty
in My sight, shall snuff it.
John (Bishop of Antioch)
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 10.10.2014 15:45, schrieb Bald Eagle:
> The counting still seems weird, like the way ACLU or Microsoft counts. 0, 1, 2,
> 5. Who do I need to have induct me into the inner circle, what blood sacrifice
> needs to be made for me to pierce the veil of the Inner Mysteries of POV-Ray
> mapping codes? Are those missing constants are only known to the 3&4th Degree
> Master Masons? I'm guessing they map a _pyramidal_ sweep, or the obverse of
> worthless Federal Reserve Notes...
Well, the truth about those missing values is more along the profane
Microsoft lines: They have been reserved for /some/ other fancy mappings
since so long ago - without ever actually being implemented - that even
the memory of /what/ mappings those were supposed to be is lost in the
absorbing and scattering media of time.
Worth trying at least.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yes, I've had a number of "This Space Reserved" issues.
Now if only I'd taken that 2 seconds to add the comment in the code...
This also makes me wonder of you can map things onto media.... :O
Touche'.
I've hand coded my ceiling lamps out of spheres, cylinders, cones, and sphere
sweeps, so now I'm going to take a whack at the medallion. I might see if I
have enough interconnecting brain cells to plot pixels varying in grayscale
value with the sine of the distance from the origin, make that a heightfield,
and then slap my image map onto that...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 10.10.2014 22:04, schrieb Bald Eagle:
Well, you can use patterns to control the density.
> Touche'.
Function image, maybe? (You can generate an internal greyscale image
from a function, and use that as input for a height field.)
Isosurface?
Parametric?
Lathe?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
http://www.povray.org/documentation/view/3.6.0/379/
That was an option I was unaware of. Too much cool stuff to play with! :)
> Isosurface?
That could totally be a very cool option considering what I've seen people do
with isosurfaces. Especially since it's a small scene element and so might not
be a huge bottleneck.
> Parametric?
> Lathe?
Both good suggestions I'll have to explore.
With regard to the complex topology of some of the furniture, I'm wondering if
something like a sphere sweep would get me the bulk of what I was aiming for
quickly - especially in the case of the scroll work. IIRC, there's a "cone
sweep" - is there a cylinder sweep? blob sweep?
I suppose those are all just specific instances of "follow this spline and plot
this object{X} at the current point", so I could try and code that generalized
case by hand...
Thanks for the suggestions as always. There are few threads I fail to profit
from in some way.
{Have a great weekend everyone!}
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> 'once'...
> So there.
Take a simple sphere, unevently scalled, and simply apply your image to
it as an image_map.
Something like this:
sphere{0, 1 scale <1,1, 0.2>
pigment{
image_map{ png "Medaillon1.png" translate -0.5 scale 2}
rotate 90*x
rotate y*Light_source_Fudge_Angle
translate Final_Location
As the image is scaled to the same dimention as the sphere, you don't
need to use once.
Now, you only need to make sure that it's correctly oriented relative
the dominent light source so that the shadowings are coherent.
A beter way would be to create a hightfield of your medaillon and use
water_level to cut out the base. That way, the shadows will always be
correct.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
