POV-Ray : Newsgroups : povray.binaries.images : Secret Passage WIP (TINA CHeP) Server Time
13 Mar 2026 21:35:59 EDT (-0400)
  Secret Passage WIP (TINA CHeP) (Message 101 to 106 of 106)
Subject: Re: Secret Passage WIP (TINA CHeP)
Date: 6 Nov 2014 07:40:00
Message: <web.545b6bfecbb3d815a47478650@news.povray.org>
Looks like you have pretty much fixed the issue then, I think you could improve
the lighting by using light_fading and area lights though see attached all I
changed is the light_source to be:
#declare Bulb =
light_source {<0, 3.5, 0> rgb <1, 1, 1>*1
 looks_like {
  Round_Cone2( <0, -2.4, 0>, 0.95, <0, 0.7, 0>, 1.80, 1 )
  texture {LightBulb_Glass}
  double_illuminate
  //light_source {<0, 3.5, 0> rgb <1, 1, 1>*0.4}
  scale 0.8
                                  area_light
                                  <-0.5, 0, -0.5> <0.5 0, 0.5> // lights spread
out across this distance (x * z)
                                  4, 4                // total number of lights
in grid (4x*4z = 16 lights)
                                  area_illumination on
                                  adaptive 0          // 0,1,2,3...
                                  jitter              // adds random softening
of light
                                  circular            // make the shape of the
light circular
                                  orient              // orient light
                                  fade_distance 50
                                  fade_power 2
Rendered with radiosity on using the basic settings from the insert menu.
have you also thought about using media to make a glow effect where the bulb is,
will slow things down a bit but is a nice effect.
Sean
Download 'lightbulb2.png' (401 KB)
Preview of image 'lightbulb2.png'
Date: 7 Nov 2014 11:10:01
Message: <web.545cee09cbb3d8155e7df57c0@news.povray.org>
Yes, I might look into that, though given my struggle with a simple light
source, I'm gonna wait until after I finish crafting the rest of the scene
before I pop open another can of hairy media worms...
I tried the area lights, and they look really nice - though 4x4 was too much I
thought, in terms of render time and shadow-removal.  Goldilocks seems to like
3x3.  :)
I did the following render at 1751 x 1347, (3 times the pixels of 1024x768) no
aa to be able get some detail and zoom in on certain areas of interest.
So now I have the bulbs, the area lights, a decorative border to the hardwood
floor, a true 3D carpet which is parse-time hog (40 sec rather than 15 - I know,
I know - weep for me), and some (not enough) minor fixes.
One of my poplars decided to peek in and give the scene a bit of Art Nouveau
flavor...
I have some more items to craft, textures to add or fix, details to ponder, and
scene elements to pull into perceivable view.
All of the furniture is surely going to take me a few pots of coffee to
decorate.
Sean - could you school me on how to add all of that decoration?
I'm also having a mental block on all of TOK's copious examples of linearly
progressing along a spline.  Crayons and sock puppets, please.
Overall, it looks good to ME, but I haven't yet decided to play with the
radiosity settings, or know why I would.  Maybe I'll see what I can get let this
chug on over the weekend.
http://postimg.org/image/dj3r5v5np/
Date: 8 Nov 2014 13:47:59
Message: <545e655f$1@news.povray.org>
> #declare Bulb =
>   looks_like {
>    double_illuminate
>    scale 0.8
>                                    area_light
> of light
> light circular
>                                    fade_distance 50
>                                    fade_power 2
> Sean
A small advice on using fading lights:
It's usualy recomended to set fade_distance to the width of the
area_light and adjust the intensity of the light as needed.
In your case, the area_light is 0.5 unit whide, you adjust as follow:
light_source {<0, 3.5, 0> rgb <1, 1, 1>*100*100
  area_light 0.5*x 0.5*y
  5 5 // prefer to use 5, 9, 17, 33, 65, ...
  adaptive 0
  circular orient
  fade_power 2
  fade_distance 1
If you use a 33 by 33 array for the area_light, with adaptive 0, it's
not realy slower than 4 by4 and may not require the use of jitter.
Using a small area_light jittered array with antialiasing can slow you
down as the noise caused by the jittering will force antialiasing in
area where it's not otherwise needed.
Date: 10 Dec 2014 15:50:01
Message: <web.5488b0c5cbb3d8155e7df57c0@news.povray.org>
Here's my final entry for the contest.
(I'm up against a lot of very talented competition!  :)  )
I rendered it at 1751 x 1347 with 2-pass radiosity, first with "simple" textures
and at 640 x 480 no aa, then at the large size with real textures and aa 0.3.
The larger size seems to make the fit-to-screen image look MUCH better in my
experience.
I am a bit concerned that the image need to be so small to weigh-in under 350
kB, and the jpg format seems to give it a bit of indistinctness as compared to
the original png.  I used Paint.NET  to format my image to jpg.
*** Does anyone have any suggestions for maximizing the image size while keeping
it under 350 kB?
Download 'final_copy.jpg' (257 KB)
Preview of image 'final_copy.jpg'
Date: 11 Dec 2014 03:20:20
Message: <548953c4$1@news.povray.org>
> experience.
> it under 350 kB?
I am not an expert on this but I always use Yve's IC for conversion.
Sometimes I have to reduce the size a little bit - 70 or 80 percent -
but that is all and most times without any visible loss. I don't know
about Paint.NET but you should give IC a try as it is the best
application around (and free).
Good work indeed. You have come a long way from the first wips and I was
a bit worried at first but I like this very much. Well done!
Date: 11 Dec 2014 16:30:00
Message: <web.548a0c1dcbb3d8155e7df57c0@news.povray.org>
I look it up.  I fiddled some, and got IrfanView to get a jpg under the
requisite file size.  Much happier now.
> Thomas
Thanks, Thomas.
I was worried too, since I did a lot of things "the hard way" - hopefully I'll
learn more efficient ways to construct complex scene elements with less time &
effort.
Yes, the first wips sort of amount to no more than napkin scribbles...  :O
I'm surprised that I got so far, but also have gained the "eyes" to see how much
farther I could go.
Thanks for all of the assistance and encouragement along the way!  :)
