POV-Ray : Newsgroups : povray.binaries.images : Le Forgeron: experiments Server Time
20 Apr 2026 19:12:29 EDT (-0400)
  Le Forgeron: experiments (Message 21 to 30 of 71)
Subject: Re: Le Forgeron: experiments
Date: 2 Sep 2014 12:29:16
Message: <5405f05c$1@news.povray.org>
Am 02.09.2014 18:11, schrieb LanuHum:
> 50 sphere_sweep with one material:
> 44 - good, AA - good
> 6 - error: color white, AA off
The AA problem is certainly just a side effect of the underlying bug.
Most likely the texture computations for the respective sphere sweeps
yield a result that is "Not a Number" (NaN, e.g. due to an attempt to
take the square root of a negative number or the like) or infinity;
anti-aliasing can't digest these values, and comes up with NaN or
infinity for the entire pixels.
It is only after anti-aliasing, when the value is converted to the 8-bit
integer range, that it turns into a sane value (and only because
integers don't have values to represent NaN or infinity); on some
platforms this value is zero, yielding black, while on other systems it
is the maximum possible integer value, yielding white.
Date: 2 Sep 2014 13:30:01
Message: <web.5405fe1c1d798e7f7a3e03fe0@news.povray.org>
Sorry, I at all didn't understand, what to do to me? :( :( :(
Date: 2 Sep 2014 13:45:00
Message: <web.5406015e1d798e7f7a3e03fe0@news.povray.org>
If I don't use UV of a problem isn't present.
Download 'scene2.jpg' (25 KB)
Preview of image 'scene2.jpg'
Date: 2 Sep 2014 14:15:00
Message: <web.5406086e1d798e7f5e7df57c0@news.povray.org>
Maybe something like
#debug concat("<", vstr (5, ColorImage_Material_001, ",", 0, 3), ">\n")
would help identify the problem, except I don't know how to convert a UV pigment
identifier to a vector(?) so that you can monitor the results.
Christoph or someone else may know how to output the values/format of these
internal values to the debug stream.  If you're doing some sort of animation
with the .ini file, then I've found it useful to output the changing values to
screen.inc so that I can follow what's going on without having to use the
Message pane.  It also preserves that data in the rendered image, which might be
more useful than writing to a file, though you could certainly do both.
Date: 2 Sep 2014 16:13:08
Message: <540624d4$1@news.povray.org>
Am 02.09.2014 19:28, schrieb LanuHum:
Don't worry, there's probably nothing /you/ can do about it anyway;
apparently there's a bug in Jerome's sphere sweep UV mapping code.
Date: 3 Sep 2014 00:06:42
Message: <540693d2@news.povray.org>
Probably right.
The interesting part is that my rendering is black, not white, when
using the gcc compiled version while the icc one shocked on assert about
povray: backend/support/imageutil.cpp:935: int pov::map_pos(const double
*, const pov::Pattern_Struct *, double *, double *): Assertion `(*ycoor
>= 0.0) && (*ycoor < (double)image->iheight)' failed.
Will have to get a set of freshly compiled binaries to go further, so do
not hold your breath today.
IQ of crossposters with FU: 100 / (number of groups)
IQ of crossposters without FU: 100 / (1 + number of groups)
IQ of multiposters: 100 / ( (number of groups) * (number of groups))
Download 'scene.png' (33 KB)
Preview of image 'scene.png'
Date: 3 Sep 2014 12:45:00
Message: <web.5407445e1d798e7f7a3e03fe0@news.povray.org>
Great!
The mistake disappeared.
Thanks a lot!
Download 'scene3.jpg' (33 KB)
Preview of image 'scene3.jpg'
Date: 3 Sep 2014 14:34:45
Message: <54075f45$1@news.povray.org>
> Great!
> Thanks a lot!
I have not yet changed anything... so it's probably just luck and some
non-initialised memory... or something else.
The bug-hunt is scheduled for this week-end.
Date: 3 Sep 2014 15:20:01
Message: <web.540769c41d798e7f7a3e03fe0@news.povray.org>
Till this day I used the version which was to the old address:
(github.com/LeForgeron/Hgpovray.git)
Only today, I make & make install a binary package, using your new link:
github.com/LeForgeron/povray
Perhaps, already something was changed?
But, if you were convinced that the error takes place, that, then is a fantasy
Oh.
Date: 3 Sep 2014 15:55:01
Message: <web.5407714a1d798e7f7a3e03fe0@news.povray.org>
Sorry.
Old version configure with --disable-optimiz (standard (official) Mageia
specfile)
Today I edited the specfile and removed an option --disable-optimiz
%configure2_5x --with-x COMPILED_BY="LanuHum" LIBS="-lboost_system
-lboost_thread -lboost_date_time"
