Le 31/03/2014 18:13, LanuHum nous fit lire :
> Le Forgeron!
> My Blender already is able tessel and tesselate. See the picture below.
> If to turn object, distortions, bad transformation turn out:
I do not get it.
The tesselation use the bounding box, so turning the object before
tesselating is expected to provide a different result.
The rotated box is indeed occupying less volume (in %) of its bounding
box, hence a different tesselation.
If you want the same mesh, tesselate at origin and apply the deformation
on the mesh instead of the original object.
> > Le Forgeron!
> I do not get it.
Thanks!
> > > Le Forgeron!
> > I do not get it.
> Thanks!
Le Forgeron!!!
I very much liked your ideas.
I will connect assembly with Blender and to acquaint users of a new site.
Big to you thanks!!!
Hi!
Sorry!
Mr Le Forgeron, you removed source codes, or moved to other place?
It would be desirable to have your version always.
Thanks.
Le 31/08/2014 19:25, LanuHum a écrit :
> Hi!
> Sorry!
> Thanks.
I finally made my source a fork of the official tree.
(from git point of view. It has always been a fork, but due to the
original being a mercurial fork from the perforce repository, it took a
bit of time and effort to reattach the whole thing to the official git
repository).
To avoid conflicts with previously advertised repository, I had to crash
it and create a new one.
https://github.com/LeForgeron/povray
Now, beware of the branches, experiments are in Hgpovray branch.
Just because nobody complains does not mean all parachutes are perfect.
> repository).
Thank you! :)
Problem with array :(
For some reason there are white not smoothed lines.
The more the number of hair, the appears white lines more.
Array - sphere_sweep with uv_mapping
Download 'uv_sphere_sweep.jpg' (31 KB)
Preview of image 'uv_sphere_sweep.jpg'
Looks like AA was not active or the color is far above 1.
Any sources ?
> Any sources ?
No! In sources 14 sphere_sweep with one material, but output image has 13
objects with a material, and one error: white color
Look attachment:
Download 'error.zip' (15 KB)
50 sphere_sweep with one material:
44 - good, AA - good
6 - error: color white, AA off
Download 'scene.jpg' (58 KB)
Preview of image 'scene.jpg'
