POV-Ray : Newsgroups : povray.binaries.images : Saving PovRay objects as geometry Server Time
23 Mar 2026 18:14:04 EDT (-0400)
  Saving PovRay objects as geometry (Message 11 to 20 of 40)
Subject: Re: Saving PovRay objects as geometry
Date: 21 Oct 2011 18:45:00
Message: <web.4ea1f4c8dc71d3eca3bfeb720@news.povray.org>
Le_Forgeron <jgr### [at] freefr> wrote:
> Le 21/10/2011 21:15, H. Karsten nous fit lire :
> > Ok, I changed the concept:
> > Creating a surface is based in two parts, and to realise both within the PovRay
> > language is slow, complicate and not necessary.
> > Only the first part will run insight of PovRay, and it will be MUCH faster!
> > It will create a file, I call .qvx (quick voxel). This file will be taken by a
> > external App, to convert it to a mesh.
> Make it a mesh2 syntax, as parsing mesh syntax get slower as bigger the
> mesh is (and it is not with mesh2)
> I'm sad you did not read my previous post.
The problem is, that a mesh2 file would need to be optimised, just like a .obj
file.
Optimising means usage of a lot of memory.
Better is, to save it as raw and convert it later. Converter are well optimised
to handle those problems. As well there are lots of apps available that can
build UVs on your meshes.
To do an optimisation on the mesh, is not a task at the moment. The most
important steps for now are speed, and High-res results.
We'll see later if there is more need for adds, for example build a mesh-camera
automatically for baking textures or something.
Best rgds,
Holger
Date: 25 Oct 2011 15:55:00
Message: <web.4ea71341dc71d3eca3bfeb720@news.povray.org>
> Le 15/10/2011 04:29, H. Karsten nous fit lire :
> > Here's another one, heaving 100 scans in each axis.
> Remind me of my 3.1g version (as a patch, not an inc)
> http://jgrimbert.free.fr/pov/patch/tessel/index.html
Would it be very complicate, to compile this into a new version of PovRay?
I tried to compile this, but I'm not a C++ user and with no makefile, I'm
lost...
A lot of people continuously asking for a "converter" from PovRay to other
apps...
I'm wondering that your code did not find it's way into the regular PovRay! As
well, I was asking for micro-poly-displacement in PovRay already long time ago,
and nobody could get me some help..
A lot of good Ideas are still not part of PovRay. Only available as patches.
This is one of the most disadvantages of PovRay ever!
I have installed a big bunch of PovRay versions, only to let run all the
patches...
so I have MegaPov 0.7 & Megapov 1.21. MC-Pov, PovMan SlimePov, ML-Pov,
DensityPov. And now your patch will become another, very good one two.
Ps.: If its to much work for you to put this into a new version ov PovRay, I
like to ask you to do a little howto of the compiling for this. I would like to
have a version, running within cygwin.
Thanx a lot!
Best rgds, Holger
Date: 25 Oct 2011 16:42:23
Message: <4ea71f2f$1@news.povray.org>
Am 25.10.2011 21:51, schrieb H. Karsten:
There are a few reasons contributing to this:
* Including a 3rd-party patch into POV-Ray proper requires the patch to
be fairly stable, and play well with POV-Ray's traditional features.
(MC-Pov, for instance, doesn't; for example you can't use both MC-Pov's
features and conventional light sources at the same time, and MC-Pov's
diffuse illumination gives significantly different results than
radiosity due to an error in MC-Pov's math.)
* Including a 3rd-party patch into POV-Ray proper requires some member
of the dev team to "adopt" the feature for future maintenance (or the
3rd-party author to credibly commit themselves to future maintenance of
the feature as part of POV-Ray proper).
be compatible with the internal architecture of whatever POV-Ray version
is currently "in the making"; this is especially a problem with the
transition from 3.6 to 3.7, which not only changed major portions of the
architecture, but also took quite a lot of time.
* Including a 3rd-party patch into POV-Ray proper requires the dev team
to feel that the patch would make a good addition to POV-Ray's portfolio
of features, without adding too much overhead in case the feature isn't
used.
Date: 25 Oct 2011 17:20:01
Message: <web.4ea727dddc71d3eca3bfeb720@news.povray.org>
> used.
OK that makes sense!
tnx,
Holger
Date: 25 Oct 2011 17:25:00
Message: <web.4ea728f8dc71d3eca3bfeb720@news.povray.org>
Not working...
I tried to run e view examples. Sometimes I get segmentation faults and the
examples are not working:
File: http://jgrimbert.free.fr/pov/patch/deform/deform.pov
error:
Parsing...roll
#break
cristal <----ERROR
test.pov:22: error: Object expected.
Files: http://jgrimbert.free.fr/pov/patch/deform/deformb.pov
       http://jgrimbert.free.fr/pov/patch/deform/select.pov
Error:
Parsing...#default { pigment { rgb <1,.8,.6> } finish { specular .5 } }
#declare Objiii =  mesh {
cubicle { box <----ERROR
test.pov:6: error: Object expected.
any idea?
Best rgds,
Holger
Date: 25 Oct 2011 18:00:54
Message: <4ea73196@news.povray.org>
Hi Holger,
This is great news!
I had originally asked about this kind of functionality last year - see
this post:
http://news.povray.org/povray.general/thread/%3C4b69e9ce$1@news.povray.org%3E/
This potentially opens up lots of opportunities...see this link for more
information:
http://forums.ldraw.org/read.php?19,1144
Keep up the good work
Reuben
Download 3D Lego models and other resources from:
http://www.pearse.co.uk/lego
On 15/10/2011 02:44, H. Karsten wrote:
> Hi people,
> I've just started to write a PovRay -.inc file that saves any object, defined in
> PovRay as a mesh -.raw file.
> It can save almost everything, include .d3f files (when being used in an
> iso-surface), blobs, meshes, whatever. And can be used in any PovRay or
> PovPatch, supporting the trace() function.
> The raw-formate does not have any mesh-optimisation needed. That means, you can
> free chose the resolution, without heaving special high memory installed. It's
> only a matter of time, running the macro.
> The only thing (for sure) it can not store "fake-deformations", like coming from
> normal maps on surfaces, or deformed lenses in the camera.
> It is still extreme slow, but has very good potential to become optimised.
> Here is a simple sphere, having 40 tracking-points in each dimension.
> I hope I can release the first version after the weekend :)
> Best rgds,
> Holger
Date: 25 Oct 2011 20:30:01
Message: <web.4ea7537fdc71d3eca3bfeb720@news.povray.org>
Hi Reuben,
funny enough! Because of the Lego-lib, I started all this :)
At the moment, I'm writing the second part in rebol.
The script will take the .qvx file and do the Polys.
My concept for the Lego-animation is, to do the animation in 3d-Studio-Max, then
export the matrix only and PovRay will take the Lego-lib and the matrix and do
the rendering.
It is likely, that we do the same thing, using Blender next and maybe cinema4d
later. Likely as well is Houdini.
The Script on the PovRay-side is all most done. I've used this technique
already, using mesh2 objects insight PovRay.
See: http://lightspeed.byethost24.com/ for some examples.
The only difference in the PovRay-script in the future is that some objects can
be completely missing, or off in the matrix and that's just a very little thing
to do.
I hope the Rebol-script is done in a view days.
The example-script I've posted before is to slow. The new thing can be more then
1000 times faster. So better for you to wait a view more days :)
Best rgds,
Holger
Date: 25 Oct 2011 23:16:30
Message: <4ea77b8e$1@news.povray.org>
>> PovRay! As
>> time ago,
>> patches.
> used.
Still, its the only case I have seen of something that kind of manages
something I wish I could do. I am looking at a situation where:
1. I am not too good at texture, but OK at building, so a lot of the
"detail" would be easier to do by adding parts, rather than texturing.
2. I need it to be in a form that can be imported to something that
isn't POV-Ray.
3. Some sort of "level of detail" trick would be nice to have.
The perfect way to do this, as I see it, would be to have something like
this trace. You generate 3 levels of detail, limiting the amount of
geometry you create. You use object patterns, or the like, to generate
the texture. I.e., you convert geometry that falls outside the bounds of
the level of detail you want into object pattern, so you still get the
same "detail", but its mapped to the object texture, not actual mesh detail.
You can "sort of" get LOD in other applications, you have to do it
manually, and you can't "map" the missing geometry onto the simpler
model. And, for course, the smallest levels of detail have to be an
image, since you can't project those tiny details into a UV mapped image
directly (or even, if supported, shadow maps, plus image). For someone
like me, it would be brilliant if this sort of thing was more direct.
But, even without it, it would still be bloody nice to build using
primitives, and have the program generate a final mesh, which removes
all the bits I don't need. Easy to do, automatically, via POV-Ray, since
it uses CSG. A bloody pain in the ass in all those "super duper powerful
mesh editors". lol And, as far as I know, no one has even attempted what
I describe above.
I am not looking forward to trying to do it the harder way. :p
Date: 26 Oct 2011 03:45:03
Message: <4ea7ba7f$1@news.povray.org>
I think that an answer to that would be a new version of Moray: Build in
csg then convert to mesh. The current version does already that but
could be improved, for instance with the techniques shown here.
Date: 26 Oct 2011 03:47:25
Message: <4ea7bb0d$1@news.povray.org>
You forget Moray, which basically can convert csg to mesh, although the
technique could be much improved imo.
