POV-Ray : Newsgroups : povray.binaries.images : waste of time! Server Time
16 Mar 2026 21:18:39 EDT (-0400)
  waste of time! (Message 11 to 20 of 66)
Subject: Re: waste of time!
Date: 28 Jan 2008 10:55:41
Message: <479dfafd@news.povray.org>
> z*2.6-y/3+x*.1 instead of <0.1, -1/3, 2.6>? This isn't the obfuscated
code contest, you know :)
it's what happens when you begin with just one dimension and then add
another, and then, a last one as well... :P
> I'm trying to modify the scene so that the camera gets rotated, instead
> of the whole scene. And taking that lightsource outside the union. My
> final goal is a camera rotate y*360*clock that looks good. It's not
> turning out so easy...
not really needed camera rotation for that.
just before rotate -x*amount
add:
rotate y*360*clock
Download 'us-ascii' (2 KB)
Date: 28 Jan 2008 10:56:57
Message: <479dfb49@news.povray.org>
Nicolas Alvarez napsal(a):
>> seemingly, yes.  It gives a "suspicious" warning at the console
>> output.  It's rgbft.  I think I should've put some more transmit and a
>> little less filter.  Hmm, I suppose 1 filter and 1 transmit do not
>> work right:  the color became quite bizarre when I tried...  I also
>> think the original image had a lot more diffuse and ambient as well...
> I heard (filter + transmit) should be <= 1 for things to look correctly.
f+t <= 1
f   >  0
t   >  0
Did I forget something?
Date: 28 Jan 2008 10:58:03
Message: <479dfb8b@news.povray.org>
I think he used basically the same setup, but only too late I realized the
light should be closer and be directional.  Also, I think he used some
specular on the floor.  It's much too bright.
BTW, my bezier curve drawing skills suck. :P
Download 'us-ascii' (1 KB)
Date: 28 Jan 2008 11:01:19
Message: <479dfc4f@news.povray.org>
> add:
> rotate y*360*clock
I tweaked lots of settings. I think the camera position doesn't look
exactly as before, but good enough. Rotating the whole scene in the way
you say didn't look right, for some strange reason. I also had to tweak
the z position to make the 'rotation center' better.
[global settings, background, cup, and tex unmodified from original,
snipping to make post shorter]
light_source {
   1.6*(4-z*8)+y*8
   1.2
   area_light
   x,y,4,4
   circular orient jitter
translate -z*0.8
union {
plane { y 0 pigment { rgb 1 } finish { ambient .2 diffuse .6 } }
object { cup translate 0 tex( <.7,.8,1,.8,.1> ) }
object { cup translate z*.7 tex( <.9,.86,.4,.8,.1> ) }
object { cup translate z*(.7+1.3) tex( <1,.96,.84,.8,.1> ) }
object { cup translate x*.7 tex(<1,1,1,.8,.1> ) }
object { cup translate x*.7+z*.7 tex(<.96,1,.67,.8,.1> )}
object { cup translate x*.7+z*.7*2 tex(<.7,1,.7,.8,.1> ) }
object { cup translate -x*.7 tex(<1,.6,.6,.1,.8> ) }
object { cup translate -x*.7+z*(.0+1.3) tex(<.5,.5,.8,.1,.8> ) }
object { cup translate -x*.7*2+z*(-.7+1.3) tex(<.7,1,.94,.1,.8> ) }
translate -z*0.8
light_source { <0,1,-8> .7 shadowless }
   location <0,1.5, -3>
   look_at 0
   angle 55
   //yes, I actually tried focal blur for the final render
   aperture .04 blur_samples 60 confidence 1 focal_point y/3+z*2
   rotate y*360*clock
Date: 28 Jan 2008 11:01:56
Message: <479dfc74$1@news.povray.org>
Well, I did change rgb with rgbft on the texture :)
PS: you're posting in HTML again.
Date: 28 Jan 2008 11:06:01
Message: <479dfd69@news.povray.org>
> You have multiple reflections and refractions. That mean that you have
tons of
> rays to compute. Add the aa and the small bumps, you need lot of
subsampling =
> lot of time.
yes, but looking at the original scene for the first time, I'd never have
guessed it!
but you're right, there are rays passing through 3 cups with IOR and
normals, as well
as reflecting off the other cups in the scene.  It's insanity squared!
> Try adding adc_bailout 0.01 in the global_settings.
I'll try that.  As well as some no_image, no_shadow trickery...
> It will cause a small decrease in quality that can go unnoticed, but
will
> accelerate things as the ray tracing will often stop much earlier.
And I didn't even go with media for blurry shadows, area_lights, radiosity
and caustics!
I wonder how much time it'd take in an unbiased renderer such as Indigo or
Luxrender...
Date: 28 Jan 2008 11:11:54
Message: <479dfeca@news.povray.org>
How much time would it need, when these cups would be filled with
different
juices?
Le'mme see:  subsurface scattering with scattering media... hmmm, about 3
months? ;)
> The final result isn't a waste of time!!
thanks.  you're very kind, but it really is:  the shadows are too sharp
and there are no caustics
to feel realistic.
And no, I'm not trying those... :P
Date: 28 Jan 2008 11:39:06
Message: <479e052a$1@news.povray.org>
> It all began with a challenge in a brazilian forum, when some guy claimed this
> scene:
> http://200.213.105.41/greysilica/exemplos/cjcopojateado.png
> took him 48 hours to render with Blender internal renderer.
> Surely something was wrong, or so I thought.  Well, in the region between the
> bottom of second row cups and the top of first row cups, render time was about
> 11 minutes a line!  It is all about refractions, normals and fresnel
> reflections.  40 hours total on a P4 2.66 with povray 3.6.1...
I forgot to mention: I definitely prefer your image than the original :)
Date: 28 Jan 2008 11:40:44
Message: <479e058c$1@news.povray.org>
> radiosity and caustics!
I'm trying a render with area_light and focal blur right now.
Date: 28 Jan 2008 11:45:00
Message: <web.479e05cbb082306e773c9a3e0@news.povray.org>
Nicolas Alvarez <nic### [at] gmailisthebestcom> wrote:
> light_source {
>    1.6*(4-z*8)+y*8
>    1.2
>    area_light
>    x,y,4,4
oh, my!  do I spot an area_light?  I envy your renderfarm! ;)
