POV-Ray : Newsgroups : povray.binaries.images : diffuse map + specular map Server Time
15 Mar 2026 10:18:24 EDT (-0400)
  diffuse map + specular map (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: diffuse map + specular map
Date: 11 Jan 2007 19:10:31
Message: <45a6d1f7@news.povray.org>
JSR nous apporta ses lumieres en ce 11-01-2007 07:09:
> Hi,
> I tried to create a floor with diffuse map + specular map with the source
> code:
Try randomysing the ends of the planks in your maps. In real life, you try to
avoid any lining up like those you have. Also, when you buy wood for your
hardwood floor, the individual planks do show some large variation in lenght.
They can range from about a feet to some 12 feet in lenght!
Sometimes my love of the arcane combines with my askew humor to make me
unintelligible!!
Date: 12 Jan 2007 03:50:00
Message: <web.45a74b27f617fe167d55e4a40@news.povray.org>
> code:
To me, the specular map looks like it doesn't contain any particularly dark
areas,  so not all of the range of specular you've set will be used - the
edges of the boards will still be quite bright in specular. You might try
adjusting the contrast of the specular map in the paint package of your
choice. If you don't like the contrast in the result you can then adjust
the positions of the texture map entries in your code, without being
limited so much by the contrast of the specular map itself.
Tom
Date: 13 Jan 2007 05:58:35
Message: <70lm74-f4q.ln1@badulaque.unex.es>
Among other things, Tom York saw fit to write:
> dark
I agree. You should probably make the edges particularly dark in the
specular map, and maybe even a specific entry in the texture map for them.
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Date: 15 Jan 2007 09:50:01
Message: <web.45ab9351f617fe16d8ef73430@news.povray.org>
Thanks to everybody, but I can obtain the result I look for.
I post a challenge in povray.international.binaries
This is the code of my last attempt:
#declare mat_TEX_PARQUET11_pigment =
  pigment { image_map { jpeg "diffuse.jpg" } }
#declare mat_TEX_PARQUET11_normal =
  normal { uv_mapping bump_map { jpeg "bump.jpg" bump_size 2 } }
#declare mat_0_89_0_0_0_TEX_PARQUET11 =
    uv_mapping pigment_pattern { image_map { jpeg "specular.jpg" } }
    texture_map {
      [0.0 pigment { mat_TEX_PARQUET11_pigment }
        normal { mat_TEX_PARQUET11_normal }
        finish { diffuse 0.9 specular 0.0 reflection {0.0 fresnel on } }
      [1.0 pigment { mat_TEX_PARQUET11_pigment }
        finish { diffuse 0.9 specular 1.0 reflection {0.1 fresnel on } }
Thanks,
Joel.
Download 'render.jpg' (274 KB)
Preview of image 'render.jpg'
Date: 15 Jan 2007 11:15:01
Message: <web.45aba81ff617fe16c150d4c10@news.povray.org>
Also note that the Arroway samples are of a lot lower resolution than the
actual pay ones (600x600 vs 6000x6000, i.e., 1/10th the resolution) so you
aren't going to get as nice detail close-up as their previews.
-tgq
Date: 15 Jan 2007 11:45:00
Message: <web.45abae90f617fe16d8ef73430@news.povray.org>
Yes, this is true. I must try with higher resolution textures, but anyway I
think that something is wrong in my scene. Tuning the scene is harder that
it seems.
Joel.
Date: 15 Jan 2007 13:45:00
Message: <web.45abcaa5f617fe16c150d4c10@news.povray.org>
> Joel.
I ran a pair of sample renders, one using normals for the bump map and one
using a heightfield.  I'll have to post them as 2 separate posts.
First the normals version
-tgq
Download 'woodfloorbm.jpg' (157 KB)
Preview of image 'woodfloorbm.jpg'
Message: <web.45abcacdf617fe16c150d4c10@news.povray.org>
Next, the heightfield version
-tgq
Download 'woodfloorhf.jpg' (159 KB)
Preview of image 'woodfloorhf.jpg'
Date: 16 Jan 2007 07:15:00
Message: <web.45acc114f617fe16d8ef73430@news.povray.org>
Thank you very much!
I like the result you get, the reflection and specular bright is what I look
for, and I need one more thing... SOURCE CODE
Can you post please?
Joel.
Date: 16 Jan 2007 09:30:00
Message: <web.45ace04ff617fe16c150d4c10@news.povray.org>
> Regards,
> Joel.
I posted a scene file in text.scene-files.  The version I did uses an HDRI
environment map, but for the scene file I replaced it with 2 square area
lights.  You'll note that I don't use specular for the texture, I rely
purely on reflection of visible light sources, but you can try playing with
specular if you like (I haven't used it in years so I can't tell you what
would be good settings)
-tgq
