POV-Ray : Newsgroups : povray.binaries.images : Ringworld re-re-revisited Server Time
17 Nov 2025 08:37:22 EST (-0500)
  Ringworld re-re-revisited (Message 13 to 22 of 32)
Subject: Re: Ringworld re-re-revisited
Date: 29 Oct 2005 09:43:02
Message: <43637c66$1@news.povray.org>
Thomas de Groot wrote:
> "David Buck" <dav### [at] simberoncom> schreef in bericht
> news:43635ed8$1@news.povray.org...
>>I've run into problems like this before.  POVRay is designed for
>>rendering scenes of "normal" sizes where "normal" is in the range of
>>arount 100,000 units from the origin.
> Would more scaling down help? My model has currently a radius of 95,000 pov
> units, but also translated 95,000 units to keep the camera near the origin.
> It is possible to scale everything down more of course, without changing the
> aspect of the scene...
> Thomas
That's one possibility but it might not work.  The problem may be the
relative scales of the scene.  If you scale it down to 95,000 pov units
you'll want scale the camera position as well which may cause the same
problems in calculations.  I suspect the problem is having a camera so
close to a relatively huge object no matter what the scale is.  You may
have the same problem with an ordinary scene and moving the camera to
0.00000001 pov units from an object.
Keep in mind, this is educated speculation since I haven't actually
tested this particular scenario, but I suspect it's causing a problem.
Try scaling down the world and see what happens, but I suspect you'll
have the same problem.  Changing EPSILON may be the only realistic answer.
David Buck
Date: 29 Oct 2005 09:55:24
Message: <43637f4c$1@news.povray.org>
>> 95,000 pov
>> origin.
>> changing the
>> Thomas
> David Buck
I just tried it - scaling the scene has no effect on the problem.
David
Date: 29 Oct 2005 09:59:45
Message: <$AGs$AAH+3YDFwBu@econym.demon.co.uk>
That was the first thing I tried when Bill posted the example scene.
It's easy to do, just reduce all those numbers by a factor of 1000 or
100000. But the result stays exactly the same in this case.
It look's like it's not the absolute size of the values that causes the
effect in this particular case, but the loss of precision.
Mike Williams
Gentleman of Leisure
Date: 29 Oct 2005 11:26:16
Message: <43639498$1@news.povray.org>
Mike Williams nous apporta ses lumieres en ce 2005-10-29 09:56:
You need 128 bit FPU! Now, they are 64 bits. In this case, double precision is just
not enough, you
need quadruple precision (or more!). It can be emulated, but it will take a LOT more
time to do the
maths, leading to proebitive render time.
E=MC^2.. I'm not fat! I'm energetic!
Date: 29 Oct 2005 12:41:57
Message: <l8WFxDAEZ6YDFwxR@econym.demon.co.uk>
>just not enough, you
>more time to do the
However, the code that calculates the intersection of a ray with a box
is first order, rather than second order, so it can be performed
accurately with less precision.
It's possible to patch the hole in the cylinder with a box that's a
million miles square. I reckon that the difference between where the box
is and where the cylinder should be, is less than the precision errors
incurred in tracing the cylinder.
camera { location <0, 0.0001, 0>
         up <0, 1, 0>
         right <4/3, 0, 0>
         //direction <0, 0, FoV_75>
         look_at <-1000, 0, 0> }
#declare Ring = union {
  light_source { <0, 0, 0> color White }
  union {
     cylinder { <0, 0, -500000>, <0, 0, 500000>, 90000000 open hollow }
     box{<-500000,-90000001,-500000><500000,-90000000,500000>}
             pigment { color SkyBlue }
             finish { ambient 0.5 } } }
object { Ring translate <0, 90000000, 0> }
Mike Williams
Date: 29 Oct 2005 17:37:39
Message: <4363eba3$1@news.povray.org>
> precision is just not enough, you need quadruple precision (or more!).
> It can be emulated, but it will take a LOT more time to do the maths,
You know, back in the day, you needed a Cray supercomputer just to even
think about being able to do what you can do in under a minute on a
modern desktop.  I'd like to see an actual time-cost of doing things
'the hard way' with software handling the precision out to whatever's
sufficient to remove precision-related artifacts, all I've seen is
people insisting that it's too long to be of any use.
Tim Cook
Version: 3.12
Date: 29 Oct 2005 19:25:39
Message: <436404f3$1@news.povray.org>
Tim Cook nous apporta ses lumieres en ce 2005-10-29 17:37:
About 18 years ago, my brother used autocad on a 286 with and without a mathematical
coprocessor.
Acording to him, it was MORE than twice as fast with the coprocessor than without. The
machine
without the coprocessor had a faster CPU and more RAM!
Rastafarianism: Let's smoke this shit!
Date: 30 Oct 2005 02:42:43
Message: <43647A2D.2020605@cheapcomplexdevices.com>
Or 256-bit fixed point.  The Java3D docs have the interesting
observation that practically all interesting physical dimensions
can be expressed in 256-bit fixed point with the fixed "decimal"
point right at bit 128.
Table 4-1 Java 3D High-Resolution Coordinates
2n Meters 	Units
87.29	Universe (20 billion light years)
69.68	Galaxy (100,000 light years)
53.07	Light year
43.43	Solar system diameter
23.60	Earth diameter
10.65	Mile
9.97	Kilometer
0.00	Meter
-19.93	Micron
-33.22	Angstrom
-115.57	Planck length
What Java3D does is makes only the bottom-most node in the scene graph
use this (slow but accurate) 256-bit fixed-point representation, and
all sub-branches in the scene graph use something small-and-fast
(floats? doubles?).
When doing math between objects within the same sub-graph of the
whole scene, it never needs to touch the slow-256-bit-fixed-point
matrices; so speed is unaffected. When doing math across
scene subgraphs rooted on two different 256-bit root nodes
I think they had clever ways of still doing most of the math
in floating point and minimizing the big integer match while
retaining precision.
I don't know if these tricks would make any sense in a ray tracer, though.
Date: 30 Oct 2005 03:25:37
Message: <43648381@news.povray.org>
"Mike Williams" <nos### [at] econymdemoncouk> schreef in bericht
news:$AGs$AAH+3YD### [at] econymdemoncouk...
Yes, David and Mike, I was afraid that would not help, and came to the same
conclusion before even trying....
Date: 30 Oct 2005 03:35:36
Message: <436485d8@news.povray.org>
... and so we are condemned to fly over the Ringworld and never be able to
land!  <sniff>  :-)
Indeed, like Mike Williams wrote, one can plug the hole. I think that for
any close up view, a combination of the larger view with a detailed scene is
needed. The boundaries would be hardly visible (with some care).
