POV-Ray : Newsgroups : povray.binaries.images : A bauble Server Time
23 Dec 2025 07:08:07 EST (-0500)
  A bauble (Message 1 to 9 of 9)
Subject: A bauble
Date: 20 Dec 2010 19:42:29
Message: <op.vn1f8ukj0819q0@gdsentropy.nc.rr.com>
Just a little thing, a side effect of experimenting with negative strength
blob components for the air bubble icicles. It is wrong. I left the
glows/lightsources out of the scaling, so they aren't in the right place.
I have one rendering which have them in the proper place.
Most puzzling though is the color of the object. I didn't make it in any
way *that* color blue.
It is:
   color_map {
    [0.00 rgbt <0.98,0.97,0.96,filterVal+0.1>]
    [0.03 rgbt <0.91,0.97,0.93,filterVal+0.1>]
    [0.40 rgbt <0.91,0.97,0.93,filterVal+0.1>]
    [0.40 rgbt <0.91,0.94,0.94,filterVal+0.1>]
    [0.42 rgbt <0.91,0.97,0.93,filterVal+0.1>]
    [1.00 rgbt <0.91,0.97,0.93,filterVal+0.1>]
It only seems to behave that way in the presence of the
glows/lightsources....which again are not *that* color blue. Some
graininess in the reflections in places. Boooooo!
The whole thing, save the glows and lightsources, is a single blob object
constructed with loops.
Ian
Using Opera's revolutionary email client: http://www.opera.com/mail/
Download 'blobtest2011.png' (134 KB)
Preview of image 'blobtest2011.png'
Subject: Re: A bauble
Date: 20 Dec 2010 21:32:25
Message: <4d1011b9@news.povray.org>
> strength blob components for the air bubble icicles. It is wrong. I left
> the glows/lightsources out of the scaling, so they aren't in the right
> place. I have one rendering which have them in the proper place.
> It is:
> color_map {
> object constructed with loops.
> Ian
Looking at that color_map, I'd expect it to be somewhat green.
Do you have any fade_color? Does it tend toward blue?
Does changing the background's colour have any effect? Right now, it's
deep blue...
You have some reflection. What colour is it?
Date: 20 Dec 2010 21:36:52
Message: <op.vn1ljlcz0819q0@gdsentropy.nc.rr.com>
finish {
   ambient 0
   diffuse 1
   brilliance 0.05
   specular 0.5
   roughness 0.001
   reflection 0.125
   interior {
    fade_distance 2
    fade_power 3 // maybe this?
    ior 1.45
    caustics 1.0
Actually the bluish look of the background comes from the glows, as it i
s
really black and the ground white.
Weird stuff.
Ian
eft
t
any
>> It is:
>> color_map {
>> Ian
> deep blue...
> Alain
Date: 20 Dec 2010 22:38:13
Message: <4d102125$1@news.povray.org>
> finish {
> ambient 0
> diffuse 1
Try diffuse 0, or some smallish value.
> brilliance 0.05
Extremely low value! Your surface reaction to illumination is almost
independent from the direction of the incident light. Such a value is
rather unexpected for a shiny, reflective surface.
I'm partial of using larger value, at least 1, probably more.
> specular 0.5
> roughness 0.001
> reflection 0.125
For your material, I'd use some variable reflection with fresnel and
conserve_energy, but, here it's mostly a test.
Suggestion: reflection{0.05, 0.25 fresnel} conserve_energy
> interior {
> fade_distance 2
This should be fade_power 1 OR fade_power 1001.
fade_power 3 is totaly unrealistic in the real world. It may be used to
simulate a light_source glowing through some medium that restricts it's
propagation, like in some underwater scene.
The realistic values are:
interior: fade_power 1 OR fade_power 1001
light_source: fade_power 2
> ior 1.45
> caustics 1.0
remove this if you use photons.
> is really black and the ground white.
> Weird stuff.
> Ian
You don't define fade_color, so it defaults to black.
Finaly, it looks like your sphere is reflecting your glow colour.
Date: 20 Dec 2010 23:09:09
Message: <op.vn1ps92m0819q0@gdsentropy.nc.rr.com>
Ok, glows off, adapted texture in use (seems dark, like impure glass?),
and many more spheres. This takes an awful amount of time with glows on.
Ultimately, I need to make this texture consistent with generic ice.
Ian
On Mon, 20 Dec 2010 22:38:13 -0500, Alain <aze### [at] qwertyorg> wrote:
>> finish {
>> ambient 0
>> diffuse 1
>> brilliance 0.05
>> specular 0.5
>> roughness 0.001
>> reflection 0.125
>> interior {
>> fade_distance 2
o
s
>> ior 1.45
>> caustics 1.0
t
>> Weird stuff.
>> Ian
> Alain
Download 'blobtest2011_0_0.png' (180 KB)
Preview of image 'blobtest2011_0_0.png'
Date: 21 Dec 2010 19:46:44
Message: <op.vn3a3pfs0819q0@gdsentropy.nc.rr.com>
Glows correctly positioned, but not using the corrected texture. The dee
p
blue one took 3 days, the other (with corrected texture) took 15 min (wi
th
radiosity?!?)...go figure... O__o'
So much to learn...
Ian
On Mon, 20 Dec 2010 23:08:59 -0500, [GDS|Entropy]
n.
> Ian
>>> finish {
>>> ambient 0
>>> diffuse 1
>>> brilliance 0.05
>>> specular 0.5
>>> roughness 0.001
>>> reflection 0.125
>>> interior {
>>> fade_distance 2
to
's
>>> ior 1.45
>>> caustics 1.0
it
>>> Weird stuff.
>>> Ian
>> Alain
Download 'blobtest2011_0.png' (163 KB) Download 'blobtest2011_0_0.png' (225 KB)
Preview of image 'blobtest2011_0.png'
Date: 21 Dec 2010 21:18:15
Message: <4d115fe7$1@news.povray.org>
> deep blue one took 3 days, the other (with corrected texture) took 15
> min (with radiosity?!?)...go figure... O__o'
> So much to learn...
> Ian
>> glass?), and many more spheres. This takes an awful amount of time
>> with glows on.
>> Ian
>>>> finish {
>>>> ambient 0
>>>> diffuse 1
>>>> brilliance 0.05
>>> is rather unexpected for a shiny, reflective surface.
>>>> specular 0.5
>>>> roughness 0.001
>>>> reflection 0.125
>>>> interior {
>>>> fade_distance 2
>>> used to simulate a light_source glowing through some medium that
>>> restricts it's propagation, like in some underwater scene.
>>>> ior 1.45
>>>> caustics 1.0
>>>> as it is really black and the ground white.
>>>> Weird stuff.
>>>> Ian
>>> Alain
I know what you mean about so much to learn!  Its never ending!  Just when
you have worked one thing out, something else gets in your way and its back
to the books!  All good fun though.
Its probably not what you want to hear, but I actually like the first pic
better, the one that took 3 days, the blue looks much nicer to me...
Cheers Dre
Date: 21 Dec 2010 21:35:39
Message: <op.vn3f5koe0819q0@gdsentropy.nc.rr.com>
> when you have worked one thing out, something else gets in your way and
> its back to the books!  All good fun though.
Indeed! I dislike easily learned things; the more complicated the better!
;D
This is why I pursue things like this in cycles; multiple complex topics
in rotation capture the eye of the mind far more effectively than some
singularly myopic aspiration.
Actually, from a purely aesthetic perspective, I agree completely. I like
the darker blue images far more than the others.
However, the desired outcome of this experiment is a realistic
distribution of "bubbles" within an icicle construct (in these images,
they are sin and cos distributed helices). Not shown within this thread
are more advanced examples; but they looks like hammered dog poo (they is
all about distribution and enclosure within the icicle object, not looking
nice). So far, the render times have been prohibitively lengthy...to quote
Warp, I will need to find a different way unless waiting "for the sun to
die" is an acceptable amount of render time . ;D
I think this will come to tessellation...which means I will release an
alpha before I go that far, with capabilities which allow reasonable
render times.
> Cheers Dre
Ian
Date: 21 Dec 2010 21:38:36
Message: <op.vn3gahd80819q0@gdsentropy.nc.rr.com>
;D
are more advanced examples; but they look like hammered dog poo (they are
render times.
> Cheers Dre
Ian
