POV-Ray : Newsgroups : povray.binaries.images : Floating - WIP Server Time
5 Oct 2024 01:18:20 EDT (-0400)
  Floating - WIP (Message 11 to 20 of 25)
<<< Previous 10 Messages Goto Latest 10 Messages Next 5 Messages >>>
Subject: Re: Floating - WIP
Date: 16 Apr 2024 09:40:00
Message: <661e7fb0$1@news.povray.org>
On 4/15/2024 10:51 PM, William F Pokorny wrote:
> On 4/15/24 15:31, RATH, CHRISTOPHER A wrote:
>> However, when I used a value < 1, I was running into the floating
>> point range problem that was giving very weird results.
> Moving to a smaller isosurface accuracy setting(a) might well help too,
> if you've not already tried it.
> Bill P.
> (a) - As a rough rule, accuracy values of 1e-5 / 1e=6 are about the best
> we can actually achieve with isosurfaces.
I'm actually using 1e-7, which seems to make a difference from 1e-6.
I'm not getting any artifacts at 1e-7, but there are a few on the front
of bubbles at 1e-6.
-- Chris R
Date: 16 Apr 2024 09:45:29
Message: <661e80f9$1@news.povray.org>
On 4/16/2024 6:33 AM, Bald Eagle wrote:
> "RATH, CHRISTOPHER A" <car### [at] comcastnet> wrote:
>> I'm playing with the fountain crack and the balloon texture now and will
>> post an update later.
> This is looking great - I think what you need for the balloon is
> transparency/filter, double_illumination, and SSLT.
> How did you make that cracked brick?   It looks awesome!
I'm playing with a bunch of suggestions for the balloon.  Currently the
texture is:
     #local _p1  = pigment { color rgbf <0.6, 0.6, 0.005, 0.7> }
     #local _p2  = pigment { color rgbf <0.6, 0.6, 0.005, 0.6> }
         material {
                     bozo
                     pigment_map {
                         [0.0 _p1]
                         [0.5 _p1]
                         [0.8 _p2]
                         [1.0 _p2]
                     warp { turbulence 0.9 }
                     scale 2
                 //normal { bumps 0.01 scale 0.01 }
                 finish {
                     fresnel 0.4
                     specular albedo 1.0
                     roughness 0.005
                     diffuse albedo 1.0
                     reflection { 0.4 }
             interior { ior 1.5 }
I'm working out how to get a more realistic reflection and will look at
the suggestions provided here.  I haven't tried rendering this with
radiosity yet.
-- Chris R
Date: 16 Apr 2024 09:48:04
Message: <661e8194$1@news.povray.org>
As for the brick, (which is changing slightly in the updated version), I
do almost everything with isosurfaces.  The bricks are just slices of a
cylindrical tube, and I subtract out a pigment function based on the
marble pattern.  In the first version, each block had its own random
cracked marble pattern applied to it.  In the new one, there is a global
crack pattern that gets applied to the foundation and each block so
there is consistency with the way the fountain is cracking.
-- Chris R
Date: 17 Apr 2024 08:29:19
Message: <661fc09f@news.povray.org>
On 4/16/2024 9:35 AM, RATH, CHRISTOPHER A wrote:
>>> This is a work-in-progress inspired by a photo I took of my grandson
>>> chasing soap bubbles in his yard.  As usual, it was supposed to be a
>>> brief doodle, but has morphed beyond that.  I have started adding other
>>> things that "float" in various ways to model in the scene as well.
>>> -- Chris R
>> I like the way you play. Why not use Iridescence on the soap bubbles?
>> That is what it was made for.
>> Have Fun!
> The bubbles do have iridescence; the bug in the shape is probably making
> it too hard to see.  I will probably put a few bubbles closer to the
> camera so you can see it better in the final image.
This is a ways from being done, but I wanted to share the updated image
with the bubbles fixed.  The balloon texture is still not quite right,
even when I render with radiosity (which this version does not).
-- Chris R
Download 'scene.png' (3793 KB)
Preview of image 'scene.png'
Date: 17 Apr 2024 12:17:47
Message: <661ff62b$1@news.povray.org>
I doubt radiosity makes any difference here.  I would give Alain's
suggestion of blurred reflection a try.  If you haven't seen it yet, the
technique is at:
https://wiki.povray.org/content/Knowledgebase:Language_Questions_and_Tips#Topic_13
To avoid having this technique stall and take forever, use Alain's
modification:
https://news.povray.org/49b9809b%241%40news.povray.org
And I would cut the reflection in half or even lower; and if you're
using finish-level Fresnel, remember to use the reduced reflection as
its argument:
finish
{ fresnel 0.5
  reflection { 0.5 fresnel }
  conserve_energy
The reflection of the water highlights on the right edge of the balloon
looks suspiciously metallic.  Is this not a rubber balloon?
Date: 17 Apr 2024 12:43:27
Message: <661ffc2f$1@news.povray.org>
> technique is at:
> modification:
> its argument:
> finish
> { fresnel 0.5
>    conserve_energy
I agree about toning the transparency down. I'd go as far as dividing it
by 3 to 4.
Date: 17 Apr 2024 17:35:00
Message: <web.66203ff3239499c91f9dae3025979125@news.povray.org>
I really like the trees.
Wondering if you can divvy them up by progressively subtracting inverted cones
from them and recombining the sections with some randomness to make them a
little less perfectly conical.
The planks on the bench need to be far thicker.
I have no doubt that you can figure out what to do with the granite blocks.
I'd experiment with jiggling and bending the water spouts, and adding in a
verdigris patina to the texture.
The grass and paths are looking good.
For the paths, consider that grass usually grows inward from the edges, you may
have rogue tufts in the middle of the path, and perhaps ruts with water /
different texture or color - maybe cracked mud.
Wildflowers, dandelions, bees, butterflies...
Would be great if you could throw a few birds into the scene.
Maybe a squirrel.
The field looks rather - empty.  Not saying dump some trash onto it, but maybe a
bike, a sunbathing towel, ... just some more indicators that it's been recently
visited and used.  A trash can and or a drinking fountain would be cool too.
- BE
Date: 18 Apr 2024 08:52:05
Message: <66211775$1@news.povray.org>
> Maybe a squirrel.
> - BE
The trees are isosurfaces using a cone function with noise added in to
get the layers of branches.  I can add some noise to the slope function
that drives the main shape and perturb the central access as well.  I
was surprised, though, by how nice they look with so little effort.
The spouts actually shoot bubbles, but you are right, the texture is
just a pure RC3Metal.  They need a little texture as well as some
corrosion, and the directions they are pointing don't have any noise in
them either.
I started working on better grass for the foreground, but then got
distracted by the balloon.  I'll have to work out some ways to get the
grass to grow more realistically into the sides of the path.  I'll
probably use whatever near-view grass shapes to create tufts in the path
as well.
The current working version has a cluster of balloons floating over the
field.  I'll be adding more elements as I get the existing ones cleaned up.
-- Chris R
-- Chris R
Date: 18 Apr 2024 08:56:58
Message: <6621189a$1@news.povray.org>
> technique is at:
> modification:
> its argument:
> finish
> { fresnel 0.5
>    conserve_energy
I looked at the code for doing the blurred reflections and started
experimenting with it.  I was able to get a nice blurring mirror using
CSG objects and this technique where I can play with the variables.
However, the balloon is an isosurface with a pretty small accuracy value
to remove artifacts, so hitting it with 40X more rays drops the
rendering to a halt.  I can get it to go with a small blur count, but I
don't think that will give me the blur effect.
I'm still playing with it.  If I can find a good way to create the
balloon using CSG instead of isosurfaces that may be the better
solution, since I don't need a bumpy surface.
-- Chris R
-- Chris R
Date: 18 Apr 2024 13:35:50
Message: <662159f6$1@news.povray.org>
>> technique is at:
>> modification:
>> its argument:
>> finish
>> { fresnel 0.5
>>    conserve_energy
> -- Chris R
Then, you need to use the micro-normal technique. Add a normal statement
scaled very small.
normal{granite scale 0.01}
Then use a reasonable amount of antialiasing. Without antialiasing, the
micro-normal will result in a grainy image.
Optionally : You may add some averaged blurring using a small number of
textures. Using averaged textures and micro-normals, you can use about 4
to 6 averaged textures and get very good results.
