POV-Ray : Newsgroups : povray.binaries.images : Beam Engine Server Time
14 Jul 2025 18:03:17 EDT (-0400)
  Beam Engine (Message 11 to 20 of 23)
<<< Previous 10 Messages Goto Latest 10 Messages Next 3 Messages >>>
Subject: Re: Beam Engine
Date: 14 Jan 2021 11:55:37
Message: <60007789$1@news.povray.org>
> On 13/01/2021 4:08 am, Mr wrote:
>> "m@b" <sai### [at] googlemailcom> wrote:
>>> My first attempt at using radiosity.
>>> Comment welcome.
>>> m@
>> The beams through media look very crisp and nice. here are a fex
>> remarks in the
>> order that would matter most first:
>> There seems to be too much light from inside to have a balance that
>> would reveal
>> radiosity well. Could the inside lights be dimmed ? maybe even remove
>> with
>> radiosity. The scene would contrast more
>> Some of the colors are too saturated. (srgb? assumed_gamma?)
>> the reflective elements, show too strong a total reflective amounts.
>> You can use
>> conserve_energy and albedo keywords to solve that.
> Thanks for the comments.
> I have reduced the gamma, gray_threshold and brightness.
> The steel-work is now a darker pigment and less reflective.
> Getting there slowly, this radiosity thing is complicated :-)
> m@
Much better.
Date: 14 Jan 2021 15:05:06
Message: <web.6000a3abf4c22fe26adeaecb0@news.povray.org>
> > Comment welcome.
> > m@
> A cool scene!
> You need area light for the sun. Radiosity seems okay, perhaps a bit bright for
> such small window area.
> As said by Mr., colors and textures aren't very realistic - colors are extreme
> and the surfaces are too clean. The metal finishes use a diffuse value like 0.6,
> which is much to high. Good values are 0.05 to 0.2 together with reflection
> values like reflection {0.3 metallic} or higher.
> Keep up the good work,
> Norbert Kern
great tip ! thanks... And this version is indeed a huge level up ! maybe the
green is still too saturated? but this  may be an artistic decision.
Date: 15 Jan 2021 17:49:58
Message: <60021c16$1@news.povray.org>
I don't really see any shadows anywhere. Can you brighten the oil lamps?
>>> Comment welcome.
>>> m@
>> remarks in the
>> would reveal
>> with
>> You can use
> m@
Date: 20 Jan 2021 16:55:01
Message: <web.6008a6a1f4c22fe216086ed00@news.povray.org>
> >> Comment welcome.
> >> m@
> > The beams through media look very crisp and nice. here are a fex remarks in the
> > There seems to be too much light from inside to have a balance that would reveal
> > radiosity well. Could the inside lights be dimmed ? maybe even remove with
> > the reflective elements, show too strong a total reflective amounts. You can use
> m@
great improvements! Now the small dining table appears as a nice place to rest
the wandering eye... Cool details. Now the image is really passed the finished
state, but of course, one could always want to iterate more... so :
-I suspect the light outside is not parallel  sun like type and in that case too
close to the building because it makes beams directions diverge instead of
falling in the same direction if they were generated by sunlight.
-the red of the machine still slightly over saturated
-The mapping of what I assume to be metallic grids on the floor seems stretched
or unreadable.
-the floor seems too bright, clean and flat.
-The walls miss some history too. maybe just a little dirt in the corners,
textures allowing to identify what they are made of ?
Date: 22 Jan 2021 03:52:18
Message: <e948ff83-230e-0384-77b7-7aceefb823e8@googlemail.com>
>>>> Comment welcome.
>>>> m@
>> m@
> or unreadable.
The sun is 100 million units away and the beams are still not appearing
to be parallel, any thoughts?
light_source{<-40, 55, 100>*1000000 color rgb<1,1,1>*10 parallel
point_at <0,0,0>}
camera{ angle 50 location <-24,-15,-50> direction 1.5*z right
x*image_width/image_height look_at <5, -10, 15>}
I have de-saturated the red and green a bit and increased the normals.
Added some bozo to the walls.
Made the floor grids a bigger scale to stop the interference pattern.
Increased the fade distance on the lamps to give some shadows on the wall.
Download 'beam engine radiosity 02.png' (1267 KB)
Preview of image 'beam engine radiosity 02.png'
Date: 22 Jan 2021 04:05:36
Message: <600a9560@news.povray.org>
> Comment welcome.
> m@
Here is the associated animation:
<https://youtu.be/BjGFyq6L5wE>
m@
Date: 22 Jan 2021 04:37:07
Message: <87y2gls471.fsf@sp.am>
"m@b" <sai### [at] googlemailcom> writes:
> are still not appearing to be parallel, any
> thoughts?
> rgb<1,1,1>*10 parallel point_at <0,0,0>}
The light rays emitted by that light source /are/ parallel.  Their
images, as produced by a perspective camera, are not supposed to
be—you’d need an orthographic camera for that.  Rather, they intersect
where the image of the Sun would be if it were visible.
Date: 22 Jan 2021 10:03:21
Message: <600ae939$1@news.povray.org>
> point_at <0,0,0>}
Your light don't need to be THAT far. You only need to make it just
distant enough that it is farther than the farthest other object in your
scene.
The parallel attribute ensure that all rays coming from it are
effectively parallel.
What you are seeing is the effect of perspective that make the parallel
rays of light appear to diverge.
As Subclick mentioned, using an orthographic camera will show that those
rays are indeed parallel.
Also, if you place your camera very close to any of the windows and look
back, toward the current camera location, then, the rays will appear to
converge.
Date: 22 Jan 2021 19:00:01
Message: <web.600b6570f4c22fe287570eab0@news.povray.org>
This is looking much better than the original now. The lighting is more balanced
and the textures more realistic. The main thing that is distracting to my eye
are the aliasing artifacts, especially across the top of the green horizontal
beam. What antialiasing settings did you use?
Date: 22 Jan 2021 21:22:14
Message: <600b8856$1@news.povray.org>
Antialias=On
Antialias_Threshold=0.3
