POV-Ray : Newsgroups : povray.binaries.images : Normal documentation images. Quilted. Server Time
15 Mar 2026 14:49:36 EDT (-0400)
  Normal documentation images. Quilted. (Message 4 to 13 of 33)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Normal documentation images. Quilted.
Date: 12 Oct 2020 07:11:01
Message: <5f8439c5$1@news.povray.org>
On 10/11/20 9:22 AM, William F Pokorny wrote:
> This led me to allnormals.pov which, IIRC, is used for the normal{}
> pattern images in the documentation. The set up is shown below and it's
> 'wrong' as indicated for normal{ <true normal-pattern> } images(1)):
well i don't know / recall... perhaps t / d stamp can provide some
guidance. the 1st link shows what is likely the initial load when wiki
was being setup, the 2nd shows Jerome made a change... maybe his memory
is better than mine!
http://wiki.povray.org/content/File:RefImgQuiltpt4.gif
http://wiki.povray.org/content/File:RefImgQuiltedNormal.png
Date: 12 Oct 2020 07:18:23
Message: <5f843b7f$1@news.povray.org>
>> it's 'wrong' as indicated for normal{ <true normal-pattern> } images(1)):
lol... 11 and 6 years ago!!! holy crap... lately last week is ancient
history. senility must be setting in
Date: 12 Oct 2020 14:40:01
Message: <web.5f84a1e0cc1d58b61f9dae300@news.povray.org>
William F Pokorny <ano### [at] anonymousorg> wrote:
> No doubt you found some of quilted's complications. I "think" I
> understand most of what's happening and why. We'll see.
> I believe any updated code should 'perturb' with the original surface
> normal in mind. I see a path to do this with flat surface stuff like
> cubes, but I don't know how to do it for curved surfaces in normal.cpp.
Maybe you could write a scene trying to express the quilted pattern in SDL as a
function?
Sometimes it's a bit difficult to translate the somewhat cryptic C++ syntax into
something intelligible.
Then at least you could have a few people play with the function and have more
eyes and minds analyzing how it all works, and where it goes wrong.
Including a note or two about how to translate the C++ to SDL (if possible)
would help future efforts, and people could begin to play with more of the
source code and patterns.   I have found this approach to be personally
educational, developmentally useful  (how many "bugs" have we found?), and it
inspires me to invent new derivative functions and patterns.
Date: 12 Oct 2020 19:45:01
Message: <web.5f84ea71cc1d58b61f9dae300@news.povray.org>
> I created quilted test cases and reviewed the shipped demo scenes. A
> number of other issues popped out. One of which is the 'true normal'
> results do not match what our documentation shows for quilted normals.
Perhaps I'm wrong or misreading something, but it doesn't appear that the
documentation properly describes the pattern.
http://wiki.povray.org/content/Reference:Quilted_Pattern
Just looking at the last image,
"A control value of 1 at both ends will give an "s" shaped curve, resulting in a
softer, more rounded edge."
yet the solid line is the s-shaped curve, and it says for that c1 = 0.
After skimming through the source code in patterns and normals, the basic
formula used to generate the curve seems an awful lot like a specialized form of
bicubic spline with c0 and c1 influencing the internal two control points...
but it's ... bizarrely different.
And I can't reproduce the curves and s-shape reliably.
And I don't know why they don't use a function based on 2*x, or use mod(), ...
Date: 12 Oct 2020 22:50:00
Message: <web.5f851559cc1d58b61f9dae300@news.povray.org>
Pfft.
I rolled my own and came up with more or less the same curves, but the way the
parameters influence them is different (of course...).
Maybe I can adapt this into a pigment pattern and a normal.
Do we know who made, how, and where the files are for the illustrations at:
http://wiki.povray.org/content/Reference:Quilted_Pattern ?
That would be a huge help.
Download 'newquiltedpattern.png' (205 KB)
Preview of image 'newquiltedpattern.png'
Date: 13 Oct 2020 03:57:11
Message: <5f855dd7@news.povray.org>
> function?
Hmm. More automatic c++ -> sdl idea interesting. Some things wouldn't be
doable at all, but certain stuff would be more or less - I guess. Busy
with real life today and tomorrow won't leave me a lot of time, but I'll
stick the idea in my head and start to let it bang around in there.
Bill P.
Date: 13 Oct 2020 04:06:50
Message: <5f85601a$1@news.povray.org>
Yes, I'm not quite sure what's going on there either.
Though I specified defaults of 1 and 1 it looked to me more like 1 and 0
or 0 and 1 depending on how the normals flip on the half unit
intervals... I didn't dive into it. ;-)
One of the complications is the curves as shown have one value inputs.
The result we 'see' is a combination of three applications to three
input values. Ahhh, as I expect you know! :-)
Bill P.
Date: 13 Oct 2020 06:35:25
Message: <5f8582ed$1@news.povray.org>
On 10/12/20 10:47 PM, Bald Eagle wrote:
> Pfft.
well as far as who and how... don't know. the where is on the wiki...
just click on the image to bring up revision info. given my confusion
about your question i'm guessing my response is a swing and a miss
Date: 13 Oct 2020 14:00:01
Message: <web.5f85ea24cc1d58b61f9dae300@news.povray.org>
> > Pfft.
Jim,
From the source code,
Who:
* FUNCTION
*   quilted_pattern
* AUTHOR
*   Dan Farmer & Chris Young
As for how - those function graphs didn't make themselves, so I'm wondering what
source information was used and how those graphs were generated for the
documentation.
Their existence implies some (non-POV-Ray?) file(s) that were used to graph the
function, and those might shed some additional light the issue.
-BW
Date: 13 Oct 2020 15:15:00
Message: <web.5f85fcafcc1d58b61f9dae300@news.povray.org>
> Pfft.
Played around a bit more.
It seems that the quilted pattern uses a radial/spherical distance as the
driving parameter for the function, whereas I thought using a min max formula
for a box would give a "distance formula" that tracked the square/cubic shape.
It also seems that the quilted normal is an inverted function from the pigment
pattern, as I need to use 1-Fn(x,y,z) to get the same effect (convex face, with
concave edges)
Stock quilted in foreground (control0 0 control1 0), my function in the back
(c0=1 c1=0)
SO many things here have touched on what I learned and developed in past
projects.
rounded box isosurface
bilinear interpolation pattern
Bezier bicubic spline
space-tesselating patterns and isosurfaces
crackle/Delaunay/Voronoi wips
No ideas at this point about performance or numerical stability with regard to
the offsets, etc.
Download 'newquiltedpatternandnormal.png' (93 KB)
Preview of image 'newquiltedpatternandnormal.png'
