POV-Ray : Newsgroups : povray.binaries.images : Into the Wild Server Time
23 May 2024 02:08:26 EDT (-0400)
  Into the Wild (Message 11 to 20 of 26)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: Into the Wild
Date: 14 Aug 2020 07:34:41
Message: <5f3676d1$1@news.povray.org>
On 8/14/20 2:20 AM, Thomas de Groot wrote:
> Op 13/08/2020 om 13:47 schreef William F Pokorny:
>>> The green image with a complex slope texture.
>>> The grey image with a simple pigment. I restarted three times there
>>> too; can you see them? ;-)
>> I do indeed. Aside from the continuity on continuations issue those
>> results look pretty good for quick vegetation, frosted vegetation. :-)
> My original image seems to be definitely due to an uncontrolled change
> to the code by me. I was misled by this present issue apparently.
> Yes, this makes up for an interesting vegetation indeed. However, it is
> not fast of course.
>> I await the test scene.
> Posted the scene in p.t.scene-files.
Thank you.
Is it easy to post one or both of the simpler isosurface fuzzy
vegetation scenes too. I was thinking I would start there over the
complete scene.
Trying your scene currently in v3.8 master and the first thing I notice
is the radiosity blocks on continuation appear to be generated just
short, below the position where the render re-starts. Do you see
something similar?
Aside: Suppose I would have expected those looking to continue renders
to save radiosity results (photon results) to a file? Maybe I'm not
running the right flags with your scene. I didn't look at it that
closely as yet...
See the scene is using f_bicorn() which I dumped from povr so I have
that too in the way of a quick 'is it the shadow cache bugs.' More if/as
I figure more out.
Bill P.
Date: 14 Aug 2020 07:48:20
Message: <5f367a04$1@news.povray.org>
Ignore this bit. Just clicked this is me running my development povr2
and not a correctly configured povr. I was picking up the wrong
functions.inc which has f_bicorn in it.
Bill P.
Date: 14 Aug 2020 09:18:17
Message: <5f368f19$1@news.povray.org>
> complete scene.
Hold off. I now have something simpler running in povr showing
differences on continuations, but seeing other issues too. Perhaps
jitter related. Need to sort it out, but but render turns fast so
hopefully can get to some better understanding.
Bill P.
Date: 14 Aug 2020 10:16:35
Message: <5f369cc3$1@news.povray.org>
OK. You found a continuation bug with radiosity (non saved).
Using my current povr and after turning jitter off somewhat easy to see
you can use continuation when using just lights, but not with radiosity.
The top row in the attached image is a foliage like isosurface sphere
which matches perfectly up to the first continuation. I stopped and
restarted roughly every render block row. I used a multiplier of 15 for
the isosurface image differences.
In the second row of the image I used a regular sphere, but used a
multiplier of 60 for the image differences. The issue is there with all
shapes, it's just harder to see on something like a sphere.
If I get fired up maybe I'll try saving radiosity samples (couldn't get
it to work trying quickly...). An outside chance that might fix it, but
given the circular patterns we see on the sphere, I suspect there is
some sort of offset in the sampling pattern on continuation. A bug no
matter saved samples or not - good find.
Bill P.
Download 'continuestory.jpg' (279 KB)
Preview of image 'continuestory.jpg'
Date: 15 Aug 2020 02:20:02
Message: <5f377e92@news.povray.org>
Op 14/08/2020 om 13:34 schreef William F Pokorny:
> complete scene.
Late but sorry, I should have been more explicit. Both isosurfaces
Isoveg and Isorock are there at the bottom of the scene; just
comment/uncomment the one you need.
> something similar?
Yes, but I assume that depends on the pretrace_end size. Change that to,
e.g. 0.004, and the gap is much smaller, controlled by that size value.
> closely as yet...
Well, I never save radiosity data (in contrast to photon data of course)
so I would not know.
> I figure more out.
> Bill P.
Date: 15 Aug 2020 02:22:32
Message: <5f377f28$1@news.povray.org>
Op 14/08/2020 om 16:16 schreef William F Pokorny:
Right! I shall try on my side to see if there is a difference when
radiosity data is saved in the scene.
Date: 15 Aug 2020 02:51:07
Message: <5f3785db$1@news.povray.org>
Op 15/08/2020 om 08:22 schreef Thomas de Groot:
Did a test: not better, maybe even worse!
Download 'continueissue_grey_2.jpg' (24 KB)
Preview of image 'continueissue_grey_2.jpg'
Date: 15 Aug 2020 03:09:36
Message: <5f378a30$1@news.povray.org>
Op 15/08/2020 om 08:51 schreef Thomas de Groot:
Question: /where/ is the radiosity data file saved??? I am unable to
find it anywhere...
I assumed it was into the same folder as the scene.
Date: 15 Aug 2020 03:27:47
Message: <5f378e73@news.povray.org>
Op 15/08/2020 om 09:09 schreef Thomas de Groot:
> find it anywhere...
Well... Not sure what happens but somehow /reading/ (+RFI) makes the
render to fail when restarting. I do not completely understand the use
of RF from the explanation in the wiki.
I tested this time in version 3.7.1 with identical results as 3.8.
Date: 15 Aug 2020 05:42:57
Message: <5f37ae21$1@news.povray.org>
>> find it anywhere...
Thanks for digging. Remembering now something like radiosity's save and
load got moved to flag/ini control (v3.7 to v3.8 ?) while the photon
load and save did not.
Aside: I got no errors (or saved radiosity file) using save_file,
load_file in the radiosity block which, in the moment, allowed me to
think the changes and state were the other way around.
Aside 2: There is the +hr and vain pretrace radiosity stuff too. For
exact image compares when running radiosity I've always had to drop back
to one thread.
I'm not a big radiosity user, but I'll play a little with the flags
while my coffee brews and post if I figure more out.
Bill P.
