POV-Ray : Newsgroups : povray.binaries.images : There will be no POVEarth! Server Time
27 Sep 2024 21:13:30 EDT (-0400)
  There will be no POVEarth! (Message 1 to 5 of 5)
Subject: There will be no POVEarth!
Date: 25 Feb 2020 14:51:48
Message: <5e557ad4$1@news.povray.org>
Hi(gh)!
...and thus, most likely no POVghanistan!
The reason: the data structure in the ASCII elevation data tiles
generated with 3DEM from the original ASTER GeoTIFFs is too
unpredictable to reliably generate anything from them using POV-Ray!
Values ending in .00 are intermingled with those ending in .0 or being
real decimal fractures, they are mostly separated by one space, but
sometimes also two... no combination of sed commands I ever tried
produced a POV-Ray-processible file! Some tiles work, while others won't...
I could give C++ a try, but even then it would be next to impossible for
me to take all peculiarities of the ASCII tiles into account...
POVghanistan will forever be limited to a classic heightfield containing
Kabul and a small portion of its surroundings I started pixeling
manually from that Russian topographic map in 2004. OpenCologne will
never come into existence unless I find a really powerful contour line
interpolation tool.
It just HURTS to give up some many dreams, from travelling to real
Afghanistan, growing my hair to waist length, making a living as a
professional programmer and now building Khyberspace...
See you in Khyberspace, perhaps in another world and time...
Yadgar
Subject: Re: There will be no POVEarth!
Date: 25 Feb 2020 21:31:24
Message: <5e55d87c$1@news.povray.org>
Am 2/25/20 2:51 PM, also sprach Jörg "Yadgar" Bleimann:
> Hi(gh)!
How about using Qt C++ regular expressions to read the data and then
write it out as something rigid for your SDL to interpret?
Regular expressions are pretty flexible when dealing with floating point
numbers.  For example, I parse this whole file from my cave scene. It
lays out the points of the plants and paths of the fish.
http://git.buckosoft.com/gitweb/pov.cgi?p=tteoac.git;a=blob;f=ttvo/ocean/forester.inc
This is the file that reads and writes that data.
http://git.buckosoft.com/gitweb/pov.cgi?p=forester.git;a=blob;f=filehandler.cpp
I would be willing to help you get that going, if you'd like.
I'd hate to see your dreams die.  Plus, I want to see POVghanistan. :)
dik
Rendered 49,882,521,600 of 49,882,521,600 pixels (100%)
Subject: There will be POVEarth!
Date: 25 Feb 2020 22:37:29
Message: <5e55e7f9@news.povray.org>
Hi(gh)!
Meanwhile, I have to soften my harsh initial stance... I finally found a
way to get those ASCII data tiles POV-readable, albeit at a slight
expense of accuracy. Very most of the elevation values are in fact
integers, written pro forma as floats, they end with .00 (or, rarely,
.0). A tiny fraction of them contains digits different from zero after
the decimal point, so I decided to truncate them all to integers by
using this bash script:
swcorner=$1
sed 's/.[0-9][0-9] /,/g' $swcorner".txt" > $swcorner"_pov.txt"
sed 's/ //g' $swcorner"_pov.txt" > $swcorner".txt"
sed 's/,,/,/g' $swcorner".txt" > $swcorner"_pov.txt"
mv -f $swcorner"_pov.txt" $swcorner".txt"
This way, I generated about ten heightfields of the Arctic Norwegian
archipelago of Svalbard, also known as Spitsbergen, all along the 80th
parallel (one attached here)... my next task will be cleaning up these
heightfields manually, as the ASTER Earth surveyor mission's radar was
not able to tell land from sea ice. I will model sea as a plain "basin"
about 100 meters deep, no actual bathymetry (at least for the time
being), at least deep enough to be intransparently dark when I once more
borrow Christoph Hormann's water like I did earlier in this decade.
Another issue will be finding texture tiles in cylindrical projection to
apply them to the terrain slices to be generated from the heightfields -
currently, I only have access the famous cloud-free "Blue Marble"
mosaic, 86400 by 43200 pixels for the whole Earth equaling 240 x 240
pixels per square degree - but as my elevation data tiles contain 3600 x
3600 (plus one in north and east direction for seamless aligning)
measuring points, I would like to find something at a higher resolution.
I know that LANDSAT tiles at 1200 x 1200 per square degree exist (or at
least have existed in the early 2010s). But recently, I could not get
access to single tiles... does anyone here know more?
An advantage of "Blue Marble" tiles, however, is that they are available
for each month of 2004, so that advancing and shrinking snow cover as
well as die-off and re-greening of vegetation can be included into
POVEarth (at least as basic soil texture as long as there are not real
snow or vegetation objects placed on the terrain relief)...
See you in Khyberspace!
Yadgar
Download 'n80e019.png' (4557 KB)
Preview of image 'n80e019.png'
Date: 26 Feb 2020 09:03:13
Message: <5e567aa1$1@news.povray.org>
On 2/25/2020 2:51 PM, Jörg "Yadgar" Bleimann wrote:
> Hi(gh)!
> interpolation tool.
> Yadgar
You should not have to use C++ to do this. Python likely supports
regular expressions too. And the PyPy extension is very fast!
Michael
Date: 2 Mar 2020 11:50:01
Message: <web.5e5d3831fac6f305594a84930@news.povray.org>
I am a software developer, and if you give me examples of all eventualities,
maybe I can create a program that can correct them with the intended substitute
signs. But then again, replacement can be done with programs as simple as
Notepad, too.
What exactly is wrong with the files? Please list all wrong elements and their
correct counterparts, maybe then I can understand better.
Also, have you tried other file versions of those areas, like DEM files?
