POV-Ray : Newsgroups : povray.binaries.images : GSOPP Server Time
29 May 2024 05:54:36 EDT (-0400)
  GSOPP (Message 11 to 16 of 16)
Subject: Re: GSOPP
Date: 27 Sep 2018 19:38:40
Message: <5bad6a00$1@news.povray.org>
Am 27.09.2018 um 13:08 schrieb Jim Holsenback:
> yeah i think i might give relaxing area light parameters and see if i
> can see any gains in time. you didn't say anything about focal blur. not
> jitter per se but it's mechanism noise based... right?
That was intentional, because I'm currently not sure how random it is,
and how reproducible the randomness is.
If focal blur uses a random seed based on "pixel address", for instance,
then oversampling the same pixel again and again will always give the
same blur sample directions, which means -am3 can't improve the blur result.
Subject: Re: GSOPP
Date: 27 Sep 2018 19:39:17
Message: <5bad6a25$1@news.povray.org>
Le 18-09-27 à 07:08, Jim Holsenback a écrit :
> On 9/26/18 8:12 AM, clipka wrote:
>> Am 26.09.2018 um 12:10 schrieb Jim Holsenback:
>>> since i used radiosity, area lights, focal blur and am3...next time i
>>> have 62 hrs of free computer time i /might/ give it some more attention
>> While quality settings normally have a tendency to stack up pretty
>> brutally, am3 is somewhat different in this respect, as it lets you get
>> away with lower settings on other features - provided they can be set to
>> produce random noise instead of biased artifacts.
>> For example, area lights can be set to produce random noise by turning
>> on jitter. If you're using am3 anyway, you can then crank down on the
>> other area light quality settings.
>> (Radiosity, on the other hand, is an example where this doesn't work, as
>> its artifacts are biased, not random-noise-ish.)
>> This comes in particularly handy when combining multiple "jitterable"
>> features, e.g. area lights + media + SSLT + micronormals (the latter two
>> always being "jittery" by nature).
It's possible that you may be able to use adaptive 0 for those. If it's
not good, try adaptive 1.
With adaptive 0, you can use some insane values for your area_light, like :
area_light x y  1025 1025 circular orient adaptive 0
and still get good performances.
Using adaptive 0 don't turn the feature off, neither will using adaptive
off.
The only way to turn adaptive off is to remove adaptive from the definition.
Subject: Re: GSOPP
Date: 30 Sep 2018 05:18:35
Message: <5bb094eb$1@news.povray.org>
> off.
> definition.
i removed jitter and used adaptive 0 (with /no/ other area light
changes) and cut 20 hours off the render time...3 cheers for +am3...i'm
a fan!
Subject: Re: GSOPP
Date: 30 Sep 2018 07:06:13
Message: <5bb0ae25$1@news.povray.org>
>> it's not good, try adaptive 1.
>> like :
>> adaptive off.
>> definition.
> a fan!
Out of curiosity, what were your values for +a, +ac, and +r, using +am3?
Subject: Re: GSOPP
Date: 30 Sep 2018 08:56:53
Message: <5bb0c815$1@news.povray.org>
>>> like :
>>> adaptive off.
>>> definition.
>> +am3...i'm a fan!
+am3 +a0.015 +ac0.995 +r3
Subject: Re: GSOPP
Date: 1 Oct 2018 02:40:07
Message: <5bb1c147$1@news.povray.org>
>>>> like :
>>>> adaptive off.
>>>> definition.
>>> +am3...i'm a fan!
OK, thanks. Confirms what I am using in general; been using +r4 for
serious cases. With hindsight, I see that in my Paris scene I used
adaptive 1 and jitter on for the street lights. I should turn them off
to gain much needed render time.
