POV-Ray : Newsgroups : povray.binaries.images : TBTFH 2018 status Server Time
29 May 2024 06:41:48 EDT (-0400)
  TBTFH 2018 status (Message 16 to 25 of 25)
Subject: Re: TBTFH 2018 status
Date: 8 Sep 2018 04:11:39
Message: <5b93843b@news.povray.org>
On 08/09/2018 08:38, BGimeno wrote:
>> On 08/09/2018 01:18, Bald Eagle wrote:
>>> And second of all, these damned dried frog pills that I imported from
>>> Scotland
>>> send up a cloud of dust every time I bite into them, so I missed that
>>> sections
>>> when I was scrolling down...
>> A cloud, you say. That sounds like dried midgie pills. (Highland
>> midge: Culicoides impunctatus) Generally used as groundbait or to keep
>> horses docile. ;)
> If this is true, it seems that the time is coming to compile my own
> version in Ubuntu.
Of course it's true.
Trust me I am a Pover. ;)
Regards
Date: 8 Sep 2018 07:50:01
Message: <web.5b93b645abd6e8dbb0d4fc1e0@news.povray.org>
hi,
"jr" <cre### [at] gmailcom> wrote:
> will follow this up tomorrow, I've been playing with the colour and the latest
> run was two minutes faster (!!) than the previous.  need to chck this further.
I changed the colour of the filigree to 'BrightGold', and the return value of
the CW_angle macro (ie use the other colour).
that more than doubled the radiosity time, from ~130s to ~348s, and the render
went up from about 20 minutes to:
Render Time:
  Photon Time:      No photons
  Radiosity Time:   0 hours  5 minutes 48 seconds (348.012 seconds)
              using 4 thread(s) with 1384.908 CPU-seconds total
  Trace Time:       0 hours 31 minutes 50 seconds (1910.868 seconds)
              using 4 thread(s) with 7562.702 CPU-seconds total
the difference between white + gold filigree is around 3.5 minutes for the
original Cw_angle, and 4.5 minutes for the 5-colour version, white being slower.
now I would like to find out how to increase the translucence of the rhomboids.
regards, jr.
Download 'snip.png' (309 KB)
Preview of image 'snip.png'
Date: 9 Sep 2018 10:47:07
Message: <5b95326b$1@news.povray.org>
Am 08.09.2018 um 13:45 schrieb jr:
Are you aiming for semi-transparency or diffuse translucency?
Date: 9 Sep 2018 12:21:16
Message: <5b95487c$1@news.povray.org>
>>> parsing is well under a minute, and (4 threads) radiosity ....
> So, I'm triply confused.
> a)  There's a quality 11?    (Throws horns, bangs head)
Yes, but quality 10 and 11 are functionally the same as 9.
Date: 9 Sep 2018 12:45:00
Message: <web.5b954de3abd6e8db8e45b0fa0@news.povray.org>
> regards, jr.
Look in the last line of the CW_angle macro, I deactivated the values
​​of transparency and filters to avoid warning messages.
The code is a little clumsy and needs many fixes to avoid duplicate code here
and there. Patience.
BGimeno
Pd. Don't call them rhomboids, they are squares subjected to great tension. Very
sensitive polygons.
Date: 9 Sep 2018 12:55:01
Message: <web.5b954f4fabd6e8dbb0d4fc1e0@news.povray.org>
hi,
translucent I guess.  I replaced (in BGimeno's code) the rgb colour returned
from  the CW_angle macro with a rgbt (with fixed .45 transmit, see image) but
that results in increased transparency.  the effect I'd like to achieve is more
like very, very thin mother-of-pearl.
regards, jr.
Download 'snip.png' (349 KB)
Date: 9 Sep 2018 13:00:01
Message: <web.5b955088abd6e8dbb0d4fc1e0@news.povray.org>
hi,
> > regards, jr.
thanks.  I put a '#debug concat' inside the macro and found that both filter +
transmit stayed at 0.0 throughout.  that led me to use a (fixed) transmit value
as part of a 'rgbt' colour.  see reply to clipka for image.
> BGimeno
> sensitive polygons.
:-)  "square" too is full of connotations, how about "retro oblong"?  ;-)
regards, jr.
Date: 9 Sep 2018 13:08:41
Message: <5b955399$1@news.povray.org>
Am 09.09.2018 um 18:50 schrieb jr:
> hi,
Then - presuming your torus thingumajig is using non-solid geometry -
you want backside diffuse illumination, and maybe one or two more levels
of radiosity recursion.
To enable backside diffuse illumination, use the two-parameter version
of `diffuse`:
    finish { diffuse FRONT,BACK }
where FRONT is how much light is reflected to the illuminated side, and
BACK is how much light is transmittend to the other side. The sum should
be smaller than than 1.0 for realistic materials.
Date: 10 Sep 2018 19:25:16
Message: <5b96fd5c@news.povray.org>
>> hi,
> of `diffuse`:
For mother-of-pearl, you also need a fair amount of iridescence. Maybe
something in the 0.4 .. 0.6 range.
Date: 11 Sep 2018 04:50:01
Message: <web.5b9780acabd6e8dbb0d4fc1e0@news.povray.org>
hi,
> > ... like very, very thin mother-of-pearl.
"my" torus.  lol.  I would not be able to create anything like it -- if my life
depended on it.
> of `diffuse`:
only had one quick try so far (got a bit paranoid last night when the CPU temp
thanks.  I'll add this "into the mix" next run.
regards, jr.
