POV-Ray : Newsgroups : povray.binaries.images : Ringworld (continued) Server Time
5 Jul 2024 19:31:54 EDT (-0400)
  Ringworld (continued) (Message 31 to 40 of 81)
Subject: Re: Ringworld (continued)
Date: 8 Aug 2018 17:35:33
Message: <5b6b6225$1@news.povray.org>
On 08/08/2018 22:02, Mike Horvath wrote:
> On 8/8/2018 1:05 PM, Stephen wrote:
>> On 08/08/2018 15:08, Mike Horvath wrote:
>>> Okay, I uploaded my scene to here:
http://lib.povray.org/searchcollection/index2.php?objectName=Ringworld&version=2.0&contributorTag=SharkD
>>> I also attached my latest render to this post. The shadow squares'
>>> widths now match what was apparently stated in the books. The
>>> shadowed regions on the ring look much better now.
>>> However, I had to double the height of the shadow squares in order to
>>> block out the sun. See the parameter `RWorld_Shadow_Square_Width`.
>>> I'm not sure why this was necessary, as the original height was equal
>>> to the sun's diameter, and should have fully blocked its light.
>> Do the two area_light vectors <Axis_1> and <Axis_2> extend beyond the
>> star's volume?
> 1. the axis lengths are equal to the sun's diameter
> 2. the area light is circular and oriented
> 3. the sun's diameter should be equal to the shadow squares' height
> according to Niven's website
Just a check list.
I just noticed that the data I was looking at was from the game. Oops.
> 4. an array of point lights in the shape of a sphere does not suffer
> from the issues I'm experiencing
How do you do that without them clustering at the poles?
>>> Oh well.
>> I like the image especially the shadows cast by the shadow squares in
>> the solar wind. :)
> Thanks!
>> Unfortunately I don't have CIE.inc or lightsys.inc installed. :(
> I use them in nearly everything. Not sure why. Probably just habit.
Probably a good habit to have.
Regards
Date: 8 Aug 2018 17:36:54
Message: <5b6b6276$1@news.povray.org>
On 08/08/2018 22:12, Alain wrote:
> Le 18-08-07 à 11:20, Stephen a écrit :
>> Thanks Alain, I seldom use area lights and this is the first time I
>> have used adaptive.
>> When you said samples is that what the offline help names Size_1 &
>> Size_2, in the line;
>> AXIS_1_VECTOR, AXIS_2_VECTOR, Size_1, Size_2?
> Yes, Size_1 and Size_2.
> AXIS_1_VECTOR and AXIS_2_VECTOR set the extent of the area_light.
> Size_1 and Size_2 set the number of components, or samples, in the
> area_light.
> When using orient, the pairs need to be of the same size. The
> AXIS_n_VECTORs need to have the same length and be perpendicular.
> And, you need Size_1 = Size_2.
> When using adaptive, always start with adaptive 0 and only increase if
> you really need to.
Thanks for the advice Alain
Regards
Date: 8 Aug 2018 19:32:18
Message: <5b6b7d82@news.povray.org>
> block out the sun. See the parameter `RWorld_Shadow_Square_Width`. I'm
> not sure why this was necessary, as the original height was equal to the
I am dumb. Instead of specifying the area light's axis vectors in the
form of:
     x * foo, y * foo
I was instead simply using:
     foo, foo
which is the same as:
     <foo,foo,foo>, <foo,foo,foo>
which is too long.
I fixed that and things are fine now. Doing another really big render at
the moment. It might take over a day to render.
Mike
Date: 8 Aug 2018 19:37:18
Message: <5b6b7eae$1@news.povray.org>
>>>> to block out the sun. See the parameter
>>>> `RWorld_Shadow_Square_Width`. I'm not sure why this was necessary,
>>>> as the original height was equal to the sun's diameter, and should
>>> star's volume?
Oops! I screwed up here. See my other post. They're fixed now.
> Just a check list.
Here's a scan from the game:
https://img.fireden.net/tg/image/1464/06/1464060167901.jpg
The shadow squares seem much smaller than they should be.
I don't. They do cluster! I should investigate a "good enough" sphere
packing formula.
>>>> Oh well.
>>> the solar wind. :)
>> Thanks!
Date: 9 Aug 2018 02:07:25
Message: <5b6bda1d@news.povray.org>
Here's a partial render.
I would like to make the edge of the sun a bit sharper, and also make
the sun smaller while keeping the haze generally the same. Here is the
sphere I use for this:
#declare RWorld_Corona_Radius			= 95000*4;
#declare RWorld_Corona_Object = sphere
     0, RWorld_Corona_Radius
     hollow
     material
         texture
             pigment {rgbt 1}
         interior
             media
                 scattering {1, RWorld_Light_Point_Color/2000}
                 density
                     function {1/(x*x + y*y + z*z)/RWorld_Corona_Radius}
                     density_map
                         [0.0 rgb 0]
                         [1.0 rgb 1]
                     scale RWorld_Corona_Radius
Any idea on how I can accomplish this?
Download 'sdsadasdsa.png' (273 KB)
Preview of image 'sdsadasdsa.png'
Date: 9 Aug 2018 02:40:48
Message: <5b6be1f0$1@news.povray.org>
>      hollow
>      material
>          texture
>              pigment {rgbt 1}
>          interior
>              media
>                  density
>                      density_map
>                          [0.0 rgb 0]
>                          [1.0 rgb 1]
I would suggest to play with the settings of the density_map. Not
tested, but something like:
density_map {
   [0.00 rgb 0.0]
   [0.90 rgb 0.9]
   [0.90 rgb 1.0]
Date: 9 Aug 2018 04:10:48
Message: <5b6bf708@news.povray.org>
> density_map {
>    [0.00 rgb 0.0]
>    [0.90 rgb 0.9]
>    [0.90 rgb 1.0]
Yeah, I thought of that too, but haven't been successful.
I also tried changing the formula so that x y and z are cubed instead of
squared, but it turned the whole image black!
Meh.
Mike
Date: 9 Aug 2018 07:11:56
Message: <5b6c217c$1@news.povray.org>
On 08/08/2018 12:08, Thomas de Groot wrote:
> I often need to take stock again and again of the gigantic distances and
> sizes we are dealing with in a planetary system. It is something quite
> difficult to grasp, and rendering things like the Ringworld makes us
> forget them, reducing them to simple rings to be taken into our hands ;-)
Translating from the mind's eye to reality is always a problem with
planetary scales.
I wonder if it is possible to use a log rather than a linear scale along
the axis.
Regards
Date: 9 Aug 2018 07:32:44
Message: <5b6c265c$1@news.povray.org>
>> density_map {
>>    [0.00 rgb 0.0]
>>    [0.90 rgb 0.9]
>>    [0.90 rgb 1.0]
> Meh.
> Mike
I tested this and it looks acceptable to me:
#local MyScale = 10;
sphere {
   0, 1
   hollow
   texture {pigment {rgbt 1}}
   interior {
     media {
       emission 3/MyScale
       density{
         spherical
         density_map {
           [0.10 rgb <0.0, 0, 0.0>]
           [0.95 rgb <1.0, 1.0, 1.0>*0.2]
           [0.95 rgb <1.0, 1.0, 1.0>]
   scale MyScale
Instead of 'spherical', you may need something else more appropriate. I
have problems with the function you use for the density map.
Date: 9 Aug 2018 07:41:49
Message: <5b6c287d$1@news.povray.org>
>> and sizes we are dealing with in a planetary system. It is something
>> quite difficult to grasp, and rendering things like the Ringworld
>> makes us forget them, reducing them to simple rings to be taken into
>> our hands ;-)
> planetary scales.
Indeed. It is not just a matter of scaling up or scaling down the model.
More is involved.
> the axis.
I'll leave that to my betters, but it might be an interesting and
worthwhile experiment.
