On 08/08/2018 07:22, Thomas de Groot wrote:
> On 7-8-2018 14:01, Stephen wrote:
>> On 07/08/2018 12:23, Stephen wrote:
>>> I might try moving the shadow square radius back to the quoted radius
>>> and adjust the length of the shadow square to get equal day/night.
>> As threatened. :-)
>> Twilight is less obvious.
> Yes, but I think it is looking natural from that distance. On the ring,
> twilight would be gradual, as expected.
I think so too. The image I posted yesterday at 22:52, my time. Does
show the gradual darkening. The render did take an hour and a half to
complete.
Regards
On 07/08/2018 23:39, Mike Horvath wrote:
> On 8/7/2018 5:52 PM, Stephen wrote:
>> Funnily enough, I did not notice that when I read the books. ;)
>> It is PovRay's fault. It is too realistic. :)
>> I think it is better to bring the shadow shields nearer the sun, for
>> the data I found.
>> This last image (I promise) using Alain's settings, has a stary
>> background to show that the night part of the ring is occluding the
>> stars.
>> BTW Thanks for starting the thread. It has been a distraction for me
>> when I don't feel up to starting a new project.
> Hold on. I just noticed I wasn't using the correct sizes for the shadow
> squares. And I had 40 of them instead of 20. I will need to redo them.
The way of the world. :)
Regards
>>>> radius and adjust the length of the shadow square to get equal
>>>> day/night.
>>> As threatened. :-)
>> ring, twilight would be gradual, as expected.
> complete.
I often need to take stock again and again of the gigantic distances and
sizes we are dealing with in a planetary system. It is something quite
difficult to grasp, and rendering things like the Ringworld makes us
forget them, reducing them to simple rings to be taken into our hands ;-)
Okay, I uploaded my scene to here:
http://lib.povray.org/searchcollection/index2.php?objectName=Ringworld&version=2.0&contributorTag=SharkD
I also attached my latest render to this post. The shadow squares'
widths now match what was apparently stated in the books. The shadowed
regions on the ring look much better now.
However, I had to double the height of the shadow squares in order to
block out the sun. See the parameter `RWorld_Shadow_Square_Width`. I'm
not sure why this was necessary, as the original height was equal to the
sun's diameter, and should have fully blocked its light.
Oh well.
Mike
Download 'ringworld_foggy_save_03.png' (99 KB)
Preview of image 'ringworld_foggy_save_03.png'
Do the two area_light vectors <Axis_1> and <Axis_2> extend beyond the
star's volume?
> Oh well.
I like the image especially the shadows cast by the shadow squares in
the solar wind. :)
Unfortunately I don't have CIE.inc or lightsys.inc installed. :(
Regards
Yay for more Ringworld! Nice image.
I don't remember any of the details any more, but I remember spending time going
through the book for measurements and descriptions when I last tried this (some
years ago now), and I don't recall any issues like you describe. Someone
mentioned ambient in the foregoing discussion - of course, the lit areas of the
Ring would cast secondary light onto the night areas. I'm sure Niven mentioned
arch-light in place of moonlight somewhere...
And of course his maths was bad - he had to write an entire sequel novel just to
deal with the Ringworld's intrinsic instability ;-)
Bill
There is a link on this site. ;)
http://www.infradead.org/~wmp/proj_rings.html
He did, I had forgotten.
Regards
Thanks!
> Bill
I am using the stats from Niven's website:
http://news.larryniven.net/concordance/content.asp?page=Ringworld%20Appendix#Params
Mike
>> the sun's diameter, and should have fully blocked its light.
> star's volume?
1. the axis lengths are equal to the sun's diameter
2. the area light is circular and oriented
3. the sun's diameter should be equal to the shadow squares' height
according to Niven's website
4. an array of point lights in the shape of a sphere does not suffer
from the issues I'm experiencing
>> Oh well.
> the solar wind. :)
Thanks!
I use them in nearly everything. Not sure why. Probably just habit.
Mike
Le 18-08-07 à 11:20, Stephen a écrit :
> Thanks Alain, I seldom use area lights and this is the first time I have
> used adaptive.
> When you said samples is that what the offline help names Size_1 &
> Size_2, in the line;
> AXIS_1_VECTOR, AXIS_2_VECTOR, Size_1, Size_2?
Yes, Size_1 and Size_2.
AXIS_1_VECTOR and AXIS_2_VECTOR set the extent of the area_light.
Size_1 and Size_2 set the number of components, or samples, in the
area_light.
When using orient, the pairs need to be of the same size. The
AXIS_n_VECTORs need to have the same length and be perpendicular.
And, you need Size_1 = Size_2.
When using adaptive, always start with adaptive 0 and only increase if
you really need to.
