POV-Ray : Newsgroups : povray.binaries.images : Chromadepth scaling to model Server Time
1 Jul 2025 00:10:41 EDT (-0400)
  Chromadepth scaling to model (Message 31 to 40 of 40)
Subject: Re: Chromadepth scaling to model
Date: 21 Feb 2018 09:00:15
Message: <5a8d7b6f$1@news.povray.org>
On 2/21/2018 8:38 AM, Stephen wrote:
> On 21/02/2018 13:19, Bald Eagle wrote:
>> Stephen <mca### [at] aolcom> wrote:
>>> Too much coffee? ;-)
>> (Though "enough coffee" is an unusual state of affairs.)
> Whoop, whoop, whoooooop!
> Attention! Low, low level coffee alarm.
I did not know you were a Juggalo, Stephen.
Mike
Date: 21 Feb 2018 09:05:00
Message: <web.5a8d7a35b61f5657a47873e10@news.povray.org>
> Mike Horvath <mik### [at] gmailcom> wrote:
> > Are you saying that it doesn't matter which corners I choose, as long as
> > the corners are opposite of each other? I don't quite understand.
> You need to choose the nearest and the farthest corners, to get the largest
> spread to scale your color map across.
If I understand what you're asking, the min_extent/max_extent features choose
those corners automatically for you. (Although, some of my tests indicate the
'reversal' of those, for some wacky reason.) But generally speaking, they work
quite well.
> Kenneth didn't realize that bounding boxes are _always_ cardinal-axis aligned.
.... un, yeah, except for that ;-)
But I'm seeing another oddity about the bounding box that I don't understand.
(See the image.) Of course, I made the box object myself, as a
(hopefully-accurate!) representation of the bounding-box volume-- and
orientation. But in renders looking exactly along the x/y/z axes, there is
clearly additional space between object and box-- when the box should exactly
delineate the boundaries of the object(?). Why that occurs when the object is
rotated is mysterious; it doesn't always happen. But it does make me suspicious,
that maybe just maybe the REAL bounding box may not actually be cardinal-axis
aligned?? Otherwise, where is the extra space coming from? Maybe it's just the
natural behavior of auto-bounding... ?
Download 'chromadepth_bounding_boxes_2.jpg' (123 KB)
Preview of image 'chromadepth_bounding_boxes_2.jpg'
Date: 21 Feb 2018 10:10:00
Message: <web.5a8d8bafb61f5657c437ac910@news.povray.org>
> quite well.
I'm not sure why that would be or if I'm following exactly what you're doing.
Your labels on the renders below seem to indicate that you're looking in
negative directions for whatever reason.  Are you sure that's not part of the
confusion?
And that white arrow is from the origin through the center of the object?
> orientation.
Are you just using something like box {min_extent(object{thing}),
max_extent(object{thing})...} ?
What IS that, and how is it made?   There might be some odd CSG thing going on.
Have you tried just a simple cylinder?
I also suggested you do exactly what you're doing and animate the rotation of
the object so you can see if that extra space is always there, or just with
certain odd orientations.
> aligned??
Well, they have to be, because you're just getting 2 corners out of min and max
extent, and if you box{} that...
vide supra
Date: 21 Feb 2018 11:39:29
Message: <5a8da0c1$1@news.povray.org>
Juggalo, gigolo? Who cares. ;-)
Did you not read to the end of the letter?
"U" is the international signal for "You are standing/running into danger".
As for Low-low... ;-)
Regards
Date: 21 Feb 2018 12:25:06
Message: <web.5a8da679b61f5657a47873e10@news.povray.org>
> > choose those corners automatically for you. (Although, some of my tests
> > indicate the 'reversal' of those, for some wacky reason.) But generally
> > speaking, they work quite well.
> confusion?
The examples I've shown so far don't have that 'reversal' of the near-and-far
bounding-box points. I've only seen that behavior when the camera and object are
really far apart-- and I haven't gone back to test that yet. The orthographic
views I made were not rendered with the 'real' scene camera but with an extra
'uncoupled' camera, from a different viewpoint; so the -y vs. +y (etc) camera
orientations that I chose wouldn't matter.
Nope, it's from the *actual* scene-code camera position, through the object--
it's there just to prove to myself that my code is applying its chromadepth
spherical-pigment color_map correctly, and 'projected' /scaled in the correct
orientation between 'real' camera and the object.
> > understand. See the image.) Of course, I made the box object myself, as
> > a (hopefully-accurate!) representation of the bounding-box volume-- and
> > orientation.
Yep. I have to assume that it's representative of the object's REAL bounding
box.. barring any other unknown discoveries ;-) BTW, it's not part of the
scene's main operation and it's not CSG; it's just an extra object placed at the
same coordinates.
Funny thing: I actually did such an animation-- a series of them, in fact. Maybe
I'll post one. They definitely show the (my) translucent box
'squashing-and-stretching' as the inner object rotates.
> > But it does make me suspicious, that maybe just maybe the REAL bounding
> > box may not actually be cardinal-axis aligned??
> and max extent, and if you box{} that...
I thought so too-- but I've been playing around with some experiments, and it
does seem possible to create a (fake) bounding-box in a *different* / tilted
orientation, that still uses the same two corner positions.
I made an image of that (using my 'uncoupled' camera again.) This time, the
'real' camera and the object are father apart than in my previous images-- and
which now shows a squashed color_map (possibly from an erroneous bounding-box
and wrong corner points?) Anyway, this image shows-- I think-- that *a*
bounding-box could conceivably be generated that doesn't really align to the
cardinal axes.
Just a fun experiment, really, but it looks too interesting to ignore. BTW, I
didn't create those slicing planes arbitrarily; they actually delineate the
spherical color_map's (scaled-up) index values in my code-- 'T' and 0.0 there.
I.e., the slicing planes would be the 'spherically-curved surfaces' of those
color_map values as they intersect the object, if that makes any sense. And the
center of that spherical pattern is also where the 'real' camera is located...
which is quite interesting. Those slicing planes sure do look like what *could*
be a differently-oriented and incorrect bounding-box shape.
Download 'chromadepth_bb_experiment.jpg' (219 KB)
Preview of image 'chromadepth_bb_experiment.jpg'
Date: 21 Feb 2018 12:35:06
Message: <web.5a8dacf6b61f5657a47873e10@news.povray.org>
Oops, I just realized that my slicing planes (and the corner points) wouldn't
produce a nicely-square box, but a trapezoid/whatever. Oh well, it was fun to do
anyway. I really thought I was on to something important... :-O
Date: 21 Feb 2018 13:20:01
Message: <web.5a8db733b61f5657c437ac910@news.povray.org>
"parallelpiped"
https://en.wikipedia.org/wiki/Parallelepiped
http://mathworld.wolfram.com/Parallelepiped.html
I'll look over your preceding post when I get some more time - off to work I
go...
Date: 22 Feb 2018 09:20:00
Message: <web.5a8ecfc6b61f5657a47873e10@news.povray.org>
Well, I've found the root of the problems-- all having to do with the object's
bounding-box:
1) There IS a subtle flaw in my code. Right now, I can't describe it clearly in
words, or how to go about fixing it.
2) There's nothing wrong with POV-ray's bounding boxes or min_extent/max_extent
or vlength (except maybe the 'extra space' that's sometimes between object and
box boundaries, depending on the object's rotation. That's still a mystery.)
3) I had another misconception, about the meaning of a bounding-box's min_extent
and max_extent locations. They are *just* coordinates in space-- and the
location of any 'shoot-from' point to *find* those coordinates has an important
bearing on whether they are considered 'near' or 'far' (i.e., which is min and
which is max.) That was my mistaken notion of the points appearing to 'reverse.'
I'm making an animation to show both my current code flaw AND this min/max
relationship. It's very instructive ;-)  I'll post it.
Date: 22 Feb 2018 10:10:00
Message: <web.5a8edc2ab61f5657c437ac910@news.povray.org>
Yes, I think I was [too briefly] trying to point toward that when I asked about
the [virtual/real] camera direction.
The bounding box coordinates are absolute coordinates referenced to the origin.
 10 > 0 > -10
Write out a formula using min() and max() to calculate the min_extent and
max_extent functions, and you'll _get it_.
Date: 23 Feb 2018 05:30:00
Message: <web.5a8fecdeb61f5657a47873e10@news.povray.org>
BTW: If it's not clear yet (because of my digressions about bounding-box stuff),
my code example works fine and dandy *if* CAM_LOCATION is at the origin,
<0,0,0>. (It puts both the 'MAIN camera' and its associated spherical pigment
there.) I haven't seen any problems when doing so.
