POV-Ray : Newsgroups : povray.binaries.images : Clothed in light. Server Time
14 Jul 2025 21:35:57 EDT (-0400)
  Clothed in light. (Message 1 to 10 of 35)
Subject: Clothed in light.
Date: 13 Nov 2017 15:27:50
Message: <5a0a0046@news.povray.org>
The tunic and wings are emissive df3s, made from Poser models.
I think I need a dragon and a rocky scene to complete this. :)
Regards
Download 'studio_vic2cm_0000.png' (726 KB)
Preview of image 'studio_vic2cm_0000.png'
Subject: Re: Clothed in light.
Date: 14 Nov 2017 03:03:45
Message: <5a0aa361$1@news.povray.org>
Yes indeed although I like this ballet school setting with the mirrors.
A couple of things, if I may: (1) the overhead lights should be dimmed -
probably by at least 50 % (if not 25%) also for compensating the light
reflections from the mirrors. (2) Could you merge this scene with your
ballerina animation? That was awesome.
Date: 14 Nov 2017 04:57:32
Message: <5a0abe0c$1@news.povray.org>
It is old enough to have been made in Moray. :-)
The lighting is problematic. The light in the hall of mirrors brightens
when I switch on radiosity. I did not mean this to turn into an
experiment in radiosity but it looks looks like it is going to be. I
have a normal area light in there to even things out.
Hmm! has anyone told you that you have an evil mind, recently?
As if I haven't enough to do. ;-)
It is an interesting challenge though. First I have to find out why when
I create the df3s there is a problem with the handiness. Or more likely
with my set up. Then unless I wanted to make a df3 that coveres the
whole playing area. I would need to work out a method of tracking the
mesh to move the slicing rig there.
On the brighter side. jr is working on a set of utilities for df3s. So
it might be possible in the future.
Regards
Date: 14 Nov 2017 08:57:09
Message: <5a0af635$1@news.povray.org>
Am 14.11.2017 um 10:57 schrieb Stephen:
>> - probably by at least 50 % (if not 25%) also for compensating the
>> light reflections from the mirrors.
Problems with different "quality levels" of illumination are to be
expected here, due to the huge mirrors as well as the glowing wings.
In reality, objects in the room would be lit by...:
(1) Light coming directly from the light sources.
(2a) Light bouncing off diffuse objects.
(2b) Light emitted by glowing stuff.
(3a) Light bouncing off diffuse objects and then the mirrors.
(3b) Light emitted by glowing stuff and bouncing off the mirrors.
(4) Light coming from the light sources and bouncing off the mirrors.
(5) Light bouncing off the mirrors and then diffuse objects.
To simulate (1), "classic" raytracing will do.
To simulate (2) and (3), you need to enable radiosity.
To simulate (4), you need to enable photons.
To simulate (5), you need to enable both radiosity and photons.
If any of these are not simulated, the corresponding portion of
illumination will simply be missing, causing the image to appear darker.
The lack of illumination from (2), (3) and (5) can be compensated for to
some degree, by making use of the "ambient" mechanism.
As far as overall brightness goes, you should ideally use renders with
radiosity and photons as a yardstick, and set up "ambient" accordingly
for fast test renders.
(As a faster alternative to photons for this particular scene, you might
try using mirrored copies of your primary light sources,
`projected_through` the corresponding mirrors. Make sure to properly
account for any dimming effect if your mirrors aren't 100% reflective.)
Date: 14 Nov 2017 16:32:53
Message: <5a0b6105@news.povray.org>
Thanks, they aren't, they are about 95% reflective. But I've ditched the
ordinary light source and am using emissive cubes as light sources.
I was thinking of adding a scattering media container first. Before
trying photons.
Regards
Download 'studio_vic2d_y_901a1_0000.png' (764 KB)
Preview of image 'studio_vic2d_y_901a1_0000.png'
Date: 14 Nov 2017 17:00:00
Message: <web.5a0b663753fdf90589df8d30@news.povray.org>
As the mirror reflections indicate, your dance hall has mirrors on only two
walls. I wonder what would happen re: radiosity and photon complexity if all
four walls were mirrored?! (The 'infinite mirror-reflection' thing.) I have no
idea, but it sounds like an interesting experiment to try. ;-)
Date: 14 Nov 2017 17:05:00
Message: <web.5a0b67b753fdf90589df8d30@news.povray.org>
> `projected_through` the corresponding mirrors...
That's an interesting trick, that I wouldn't have thought of. Thanks.
Date: 14 Nov 2017 17:40:43
Message: <5a0b70eb$1@news.povray.org>
> walls.
Three mirrored walls in fact. I chose the camera position so that I
wouldn't have much of a hall of mirrors, effect.Just a view of three sides.
So you want that I give my machine a stress test? ;)
Of course I'll give it a go. :)
Regards
Date: 14 Nov 2017 19:00:34
Message: <5a0b83a2@news.povray.org>
Not so bad. Less than 6 minutes
No AA nor photons. Max Level 53/64
Regards
Download 'studio_vic2d_y_901a2x_0000.png' (773 KB)
Preview of image 'studio_vic2d_y_901a2x_0000.png'
Date: 15 Nov 2017 02:54:24
Message: <5a0bf2b0$1@news.povray.org>
No. Nobody dares to. ;-)
I knew it was a difficult question, but I am confident in the results :-)
