POV-Ray : Newsgroups : povray.binaries.images : Calling the Doctor - nighttime - 16:9 Server Time
25 Jun 2026 05:52:28 EDT (-0400)
  Calling the Doctor - nighttime - 16:9 (Message 31 to 40 of 41)
<<< Previous 10 Messages Goto Latest 10 Messages Next 1 Messages >>>
Subject: Re: Calling the Doctor - nighttime - 16:9
Date: 25 Sep 2017 11:09:57
Message: <59c91c45$1@news.povray.org>
On 09/25/2017 04:38 AM, Mr wrote:
> William F Pokorny <ano### [at] anonymousorg> wrote:
>> On 09/23/2017 08:19 AM, Ive wrote:
>>>   From what I can tell, especially aimed at architectural
>>> pre-visualisation,
>> So these could likely be a little sloppy. Good to know.
> two open source available implementations:
> http://www.luxrender.net/wiki/LuxRender_Lighting#IES_data
> If in doubt, a good compromise to not go as far as full IES support is also to
> look at Blender's custom curves light attenuation where a spline commands the
> blending of a spotlight from center to edge of cone:
https://docs.blender.org/manual/ja/dev/render/blender_render/lighting/lights/light_attenuation.html#custom-curve
Thanks for these references.
Starting with the Blender reference, you can accomplish the custom
curves sort of thing - and more - already in POV-Ray though in a less
pre-packaged way. See the attached 3.8 scene for a quick example.
On the luxrender reference.
- So the LuxRender code itself is open source with a license compatible
with POV-Ray's AGPLv3 license?
- Assuming a little about how the luxrender mesh light sources actually
work and seeing their warning regarding IES light intensity corruption
due them... One advantage of having some enclosing shape for
non-spherical lights while handing the spherical IES light profile is
that it gives you an adjustable transmission channel over the surface of
the shape which can compensate for less-than-correct IES fading for
non-point/centered source lights. Though, I have to think with some
work, the same sort of adjustments/compensations could be part of any
mesh light implementation using IES profiles and it more a matter it has
not yet been done.
Bill P.
Download 'utf-8' (2 KB)
Date: 25 Sep 2017 15:25:01
Message: <web.59c9573af158f762883fb31c0@news.povray.org>
> Interestingly, while looking for hair macro, I looked over at Rune's website and
> found his Pattern Control Trick - "Change the color_map of a pigment along a
> pattern"  Perhaps this could be of some use in this instance.
I must have missed that on Rune's site--but I'll definitely take a look! It
sounds like it would be VERY useful, in all sorts of ways. Thanks.
Date: 25 Sep 2017 16:15:33
Message: <59c963e5$1@news.povray.org>
On 25/09/2017 13:01, Bald Eagle wrote:
> "Kenneth" <kdw### [at] gmailcom> wrote:
>>> Or a slightly oversized version of the same object with filter/transmit applied
>>> to give a "ghost" around the edges?
>> Certainly possible, although I *think* the slightly larger object would still
>> look distinct/sharp. I'd have to experiment to find out.
> Well, all of the suggestions were with the idea that there would be a fog/haze
> in between the fake-blur and the camera to help hide the kludge.
> It also occurred to me that one might be able to make an object slightly ---
> hairy - to soften the edges.
Hmm! Do you know about Tim Nikias' site. He wrote a suit of macros. One
of them ye describes thus:
A set of macros to sample the surface of an object. Useful for
surface-dependant effects like snow, moss, dust, hair, etc.
I've not used that one but his Liquid-Surface-Simulation-Macros work a
treat.
Regards
Date: 25 Sep 2017 17:45:46
Message: <59c9790a$1@news.povray.org>
Am 25.09.2017 um 17:09 schrieb William F Pokorny:
LuxRender used to be licensed under GPL, presumably 3.0 (that's what
they're still displaying on their website, at any rate), but has
recently transitioned to something they refer to as "APL 2", presumably
Apache license 2.0 (that's what the `license.md` file in their repo is
titled, at any rate).
Note that neither GPL 3.0 nor, to my knowledge, the Apache license 2.0
contain provisions to relicense covered works under the AGPL 3.0, so we
can't just copy-and-paste LuxRender code into POV-Ray.
The AGPL 3.0, GPL 3.0 and, to my knowledge, Apache license 2.0 are
however compatible with each other in the sense that source files
covered by either of those licenses can coexist with source files
covered by another of those licenses within the same project (provided
they in fact comprise separate translation units, which are then
combined in the linkage phase of a build).
Of course IANAL.
Date: 25 Sep 2017 18:20:00
Message: <web.59c98015f158f7625cafe28e0@news.povray.org>
Yes, certainly.  The problem is always: can I remember that it exists and what
he has over there....
There's always just SOOOOOOOOOOOOOO much that people have written over the
years...   We need a POV-Ray Librarian / archivist to join the POV Team!
Oh.  Wait.  We have TdG.
:D
http://www.nolights.de/downloads.html
> One
Ah, yes.  I recall some of threads way back with snow scenes.   Very clever
stuff.
> treat.
Thanks, I'll check that out if an when I get enough uninterrupted free time.
<howling maniacal laughter>
Coincidentally, I've just been searching for a nice Mathematica Spikey / spiked
sphere / heavily stellated polyhedron, and his electrostatic repulsion macro
might just fit the bill.
Yay serendipity!
> Regards
>      Stephen
Date: 26 Sep 2017 02:53:28
Message: <59c9f968$1@news.povray.org>
> hairy - to soften the edges.  Maybe do _that_ with a transparent+ior or
> transmissive texture and see how that goes.
> For the oversized transmissive object, I was thinking that perhaps there's a way
> to soften / completely fade out the edges.
This all let me think that the /stochastic blink/ feature that is
available in the betas would do nicely.
Date: 26 Sep 2017 02:55:07
Message: <59c9f9cb$1@news.povray.org>
> :D
He does not come cheap ;-)
Date: 26 Sep 2017 03:54:47
Message: <59ca07c7$1@news.povray.org>
> years...
Isn't that the truth? :-)
Hence the link while I remembered.
Things haven't been the same since Uncle Ken went to the darkside of
photography.
> :D
Good luck with that one. :-)
>> One
> stuff.
>> treat.
Echoing in my head too. :-)
> Yay serendipity!
Nice one!
Regards
Date: 29 Sep 2017 23:25:01
Message: <web.59cf0de9f158f7625cafe28e0@news.povray.org>
This just in:
The TARDIS has been spotted in New Hampshire!
:D
Download 'tardis_in_nh.png' (1203 KB)
Preview of image 'tardis_in_nh.png'
Date: 2 Oct 2017 10:07:49
Message: <59d24835@news.povray.org>
Am 9/24/2017 um 16:32 schrieb William F Pokorny:
Sorry for the late response, was away for a week.
>> pre-visualisation,
This is not what I meant.
> - Is the profile information added as extra information into a given
> light source modulating the source intensity as was done in a megapov
> patch in the early 2000s?
Yes.
> - Is it a complete lighting rig with predefined media around the light?
No.
> - Do either of implementations put an extra transparent surface with a
> transfer function in play as I was trying?
No.
> - Are the implementations otherwise decoupled from / not-tangled with
> the other objects in the scene? I'd guess, yes, but if not would be nice
> to know what other methods are being employed.
Yes.
> - If those two tools have optional script outputs, might we get a look
> at code snipets from both tools with example use?
No script output, if this is indeed what you mean. But for sure script
input ;)
> - Also wonder if full spherical profiles are common or if it is
> primarily spot/directional lights?
There are e.g. light bulb and neon tube IES profiles as well. But as far
as I understand it, IES profiles are focused on the fixture and
others than spotlights are hard to come by and/or are not very
reliable/useful.
> I recall a free standing fixture having light bleeding through the back
> side such that the profile isn't the half sphere/horizontal angle sort.
> It had some holes on the topside/backside (venting for heat I suppose?)
> and the sampling looked to have caught some but not all the backside,
> peep hole light bolts. In this case the profile represented the reality
> poorly around part of the fixture. Suppose the support position could be
> the IES is what it is, but on seeing this I wondered whether a good IES
> implementation would offer options to perhaps force symmetry across an
> axis or something.
> - Do the two tools you use with IES support 'fix-up/clean-up' options on
> import?
No.
> Wonder how it can take zero extra time given extra calculations or
> surfaces must be involved... I guess I could see how 'adc bailout' might
> happen earlier for some rays at the surface of a transparency mapped
> sphere/cylinder, but that approach generates extra rays at the surface
> and transmission calculations overall. If IES is handled in the light
> code itself, I guess it could better prune the surface-look-to-light
> rays as I believe happens today with POV-Ray's spotlights. Though I've
> not spent much time with the light source code.
Both are unbiased, brute force render engines so I guess the few extra
calculations simply don't matter given the extreme amount of rays they
shoot anyway.
> One last question. Do these other ray tracing tools implement EULUMDAT,
> ..ldt, support too?
No. But, as far as I understand it, this would be even better.
Maxwell Render and Mental Ray (I once tried the free trial versions of
both, just to see what the Pros are working with) do support them.
> Thanks for your time and any further information you can offer. I've
> opened up a github issue:
>    https://github.com/POV-Ray/povray/issues/322
> where we can roll(1) up links, discussion and information. Perhaps one
> of us will take another run at 'IES support' at some point. For now I
> have to get back to some other work.
> Bill P.
A few links from my collection that might be of interest.
A freeware IES file viewer:
http://www.photometricviewer.com/
A small collection of IES profiles for "artists" that DO work very well:
http://www.derekjenson.com/3d-blog/ies-light-profiles
At the bottom of the side is a tool that claims to convert EULUMDAT to
IES, but I haven't tried it by myself yet:
http://www.helios32.com/resources.htm
-Ive
