POV-Ray : Newsgroups : povray.binaries.images : I've seen the light! Server Time
2 Jun 2024 04:34:21 EDT (-0400)
  I've seen the light! (Message 21 to 30 of 32)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: I've seen the light!
Date: 1 Dec 2016 22:56:05
Message: <5840f0d5$1@news.povray.org>
Am 02.12.2016 um 04:29 schrieb Cousin Ricky:
> On 2016-12-01 10:57 PM (-4), clipka wrote:
>> Am 02.12.2016 um 02:03 schrieb Alain:
>>>> Apple II: 280 x 192 (effective color resolution 140 x 192), 6 colors
>>> It have two graphic modes, low res and high res.
>>> You describe the hires mode.
>>> Low res is 40 x 48 in 16 colours.
>> Sounds like an abused text mode to me (40x24 characters, using 2-block
>> graphic characters and per-character foreground/background colours).
> That's effectively what it was, although I can't remember if that was
> literally the case.  Either way, it was handled transparently by the
> graphics commands.
> The original Apple II used a 6 bit ASCII subset, so there was plenty of
> room to play around with the extra bits.  The Apple IIe used the full 7
> bit ASCII set, but I'm less familiar with that model.
Ah, that brings memories to life!
Such as flipping a hardware switch to change the character set from
German to ASCII when writing program code, and later flipping back to
German when running the program.
Date: 2 Dec 2016 03:01:35
Message: <58412a5f$1@news.povray.org>
On 2-12-2016 0:00, clipka wrote:
> Am 01.12.2016 um 20:26 schrieb clipka:
>> Am 01.12.2016 um 18:16 schrieb scott:
>>>> Turns out the core module is already better than I had feared. Still, it
>>>> has highlighted various issues that still need sorting out -- mostly
>>>> expected (such as failure to set various default values upon object
>>>> construction), but a few I did not expect, like some compile-time config
>>>> settings that don't come with defaults.
>>> I guess you noticed already, but your checkered plane didn't seem to
>>> work properly either ;-)
>> Bah - checkered planes are for wussies. I'm much more worried about the
>> gamma handling... ;)
> Obviously I couldn't rest until the gamma handling was fixed.
Yes, much better indeed! How is aa coming along?
Date: 2 Dec 2016 06:27:15
Message: <58415a93$1@news.povray.org>
> Amstrad CPC: 160x200, 16 colours from a palette of 27 FTW!
> (alternatively 320x200, 4 colours from the same palette)
   I still have here my CPC 464 (it was my very first computer), but just
as decoration... I doubt it will still function properly.
jaime
Date: 2 Dec 2016 11:50:58
Message: <5841a672$1@news.povray.org>
>>> =?UTF-8?Q?J=c3=b6rg_=22Yadgar=22_Bleimann?= <yaz### [at] gmxde> wrote:
>>>> This is how POV-Ray should look on the Commodore 64! Block graphic font
>>>> in 40 by 25 characters! No image bigger than 1000 bytes!
>>>> Retrocomputing rules! There should be a POV-Ray version for each of the
>>>> 1980s' 8-bit classic machines!
some text into the graphic area and actually change the graphic, or plot
some dots into your text to get some weird changes in the displayed
text. Bits 0-3 stood for the bottom part and bits 4-7 for the top part.
As the text was strictly black and white, upper case only, there was no
foreground/background play. Text could be writen in normal (white on
black), inverse and flash, or blink mode. Inverse was triggered by
turning bit 7 on, and flash, IIRC, with bit 7 off and bit 6 on, but not
for punctuation and special characters.
I still have my Apple ][+ 48K, with all it's documentation.
Date: 2 Dec 2016 22:44:49
Message: <58423fb1$1@news.povray.org>
> TRaSh 80: 80 x 24 (IIRC), black and white
> IBM PC-XT with CGA: 320 x 200, 4 colors unevenly distributed on the color wheel
> P.S.  Examining the IBM CGA color selections, it was clear that it was designed
> for engineering shortcuts rather than for the end user.  This would not be the
> first time IBM chose an engineering shortcut over utility: their RANDU
> pseudorandom number generator was a clever hack that saved many CPU cycles, and
> churned out a stream that was horrifyingly non-random, even by LCG standards.
> (Imagine running a simulation on that system, getting it published in a
> peer-reviewed scientific journal, and then discovering that your entire study is
> utterly worthless because some engineer over at IBM cleverly solved the wrong
> problem.)
palette of 8 (black, blue, red, magenta, green, cyan, yellow and white).
Additionally, the entire attribute block may be designated as 'bright',
resulting in a total of 15 possible colours (because both bright and
dark black is the same color #000000).
________________________________________
-Nekar Xenos-
Date: 2 Dec 2016 23:15:29
Message: <584246e1$1@news.povray.org>
On 12/01/2016 12:27 PM, clipka wrote:
> Am 01.12.2016 um 20:28 schrieb Cousin Ricky:
> (According to Wikipedia it was 128x48. Alternatively, 64x16 "greyscale"
> using characters.)
> I still have one of those buggers at home, including some RAM expansion
> and an EPROM board, for a whopping 512+48 kB of usable physical RAM and
> about 128 kB of hard-wired software, so it might actually have the
> capacity to run a (arguably fairly limited) port of our famous
> raytracing software. Don't expect any renders to finish before the
> zombie apocalypse hits though ;)
> (Also, burning the software into a set of EPROMS might actually be the
> only reasonable way to get it into the computer; it doesn't have
> anything in terms of standardized external interfaces.)
> PC-XT doesn't cout; it's a 16 bit system, and therefore far too advanced
> to run interesting software.
Then there was the Zenith Z-100 (or H-100 for the Heathkit version) — 640 x 225, 8
colors, IIRC.
I wrote a graphics library for it in C for my own use.  An interesting challenge —
the way the
graphics were implemented was WEIRD!  The three R, B, B planes were separate 64K 8080
segments,
and it used this memory in a non-contiguous manner.  Lots of fun to work out with the
very
limited documentation provided.  But I did end up with a usable C library.   :-)
      -=- Larry -=-
Date: 2 Dec 2016 23:27:57
Message: <584249cd$1@news.povray.org>
On 12/02/2016 08:15 PM, Larry Hudson wrote:
>  The three R, B, B planes were separate 64K 8080 segments,
Oops:                                        8086
      -=- Larry -=-
Date: 3 Dec 2016 10:11:56
Message: <1914354734.502468873.201759.gdsHYPHENentropyAThotmaolDOTcom@news.povray.org>
> (many things)
I agree with he principle wholeheartedly; I nearly always prototype complex
things in an atomic fashion once I hash out the models mentally, in order
to sanity check my work.
I do the same when extricating legacy software algorithms from the
festering bulk from whence they originate.
Once you separate the routines which are responsible for doing the work
from whatever horrific matrix of septic horrors and sad excuses for OO
design patterns within which they were entombed, you are then free to
implement a plugin based architecture.
At my current place of employment I wrote a sort of meta framework.
Typically I use interface driven design with a pair of interfaces which
describe the module in question:
Lazy<IFooPlugin, IFooPluginMetadata>
Then I use MEF and a number of design patterns that allow me to represent
arbitrarily complex hierarchical relationships and access any given subset
in O(1) time, due to the interface pairs existing in a concurrent
collection and the hierarchy relationships enforced by interface.
Long story short you end up with a strongly typed system that supports
backwards compatibility, dynamic plugin loading and hosting, the ability to
compose functionality, versioning, business logic tracking and execution
tree reproduction for rerunning records, on the fly extensibility without
recompilation, etc..
With the WCF plugins that run on the same framework, you have dynamic
content type handling with no work required by the dev to support it, you
just decorate your service method, all the capabilities of the above,
dynamic REST/SOAP support, spooling of services based on load, across
servers....no hardcoded URIs but instead you request one and if an instance
exists that meets your spooling criteria you get the URI otherwise it
spools it...new servers can be stood up in under 20m and they immediately
become part of the global pool for load balancing on their own.
And more.
I wrote an extension to my framework that finds all plugins of the same I/O
type and loads them in a UI like Visio but node based, so you can compose
new programs from deployed plugins as easily as building a flow chart. It
makes an XML file that goes to the server, the UI host reads it and creates
a UI for input, and voila, business users can compose new apps from extant
plugins with no coding knowledge, letting them use the plugins written by
any BU and thus save time and testing and each new plugin benefits all
BUs...it uses dynamic generation of Func<> behind the scenes and chains a
call stack together with them using lambdas and TPL.
It is actually incredibly stable and fast as heck. :)
But I digress...my point was I guess to illustrate my love of well designed
code and systems architecture. :)
Like you have mentioned, some sort of truly modular architecture can be
implemented for Pov, where all parts can be replaced and new modules can be
dynamically inserted into the call stack of all parts without recompilation
so we basically have full composition capabilities via polymorphism, using
CoR, strategy, decorator, (and others).
Throw a nice node editor in there and we'll be in business. :-D
Folks will be able to add new algos for rendering pipeline, effects, domain
scripting languages and essentially any and everything.
Obviously the easier it is to do stuff like that the more likely it is
folks will in fact do it, which would be awesome.
Ian
Date: 3 Dec 2016 10:15:10
Message: <960014984.502470825.797426.gdsHYPHENentropyAThotmaolDOTcom@news.povray.org>
> BTW, here's a demonstration of why I think general-purpose programming
> languages are ill-suited for scene description:
You could be really malevolent and make people use Brainfuck as an SDL.
<evil grin>
Ian
Date: 3 Dec 2016 11:16:52
Message: <5842eff4$1@news.povray.org>
Am 03.12.2016 um 16:11 schrieb [GDS|Entropy]:
> clipka <ano### [at] anonymousorg> wrote:
>> (many things)
> (many other things)
> But I digress...
You don't say! ;D
> (yet some more things)
Indeed. Though I would be happy enough if for starters this could be
done at compile-time.
If some day folks studying computer graphics at Cornell would be
introduced to the various raytracing approaches by letting them toy
around with POV-Ray, and a typical homework assignment would be to
shuffle the basic building blocks of POV-Ray (which uses so-called
backward ray tracing) to turn it into a forward ray tracer just for
giggles (while still retaining its capability to render arbitrary
POV-Ray scenes of course), that would be enough to make my day.
