POV-Ray : Newsgroups : povray.binaries.images : looks_like Server Time
2 Jun 2024 14:17:50 EDT (-0400)
  looks_like (Message 11 to 16 of 16)
Subject: Re: looks_like
Date: 13 Sep 2016 18:11:42
Message: <57d8799e$1@news.povray.org>
Am 13.09.2016 um 23:15 schrieb Mike Horvath:
> On 9/12/2016 3:57 AM, And wrote:
>> On the other hand, if you set the light_source color A, than the
>> looks_like
>> color will be A*pi/0.00006 ~= A*52333.
> Do I apply this to the pigment or the finish emission?
That's up to you, but personally I'd recommend the finish emission. The
pigment is also used in the other finish features, which are related to
reflection of light from somewhere else, where values above 1 make no
physical sense. But when it comes to emitting light on its own, there's
no limit for an object's material.
Date: 13 Sep 2016 18:58:39
Message: <57d8849f$1@news.povray.org>
>>> looks_like
So, like this?
	texture
		pigment {color srgb light_color}
		finish
			emission	pi/0.00006
			ambient		0
			diffuse		0
Date: 14 Sep 2016 05:05:00
Message: <web.57d9125be29f651c369d5640@news.povray.org>
> >>> looks_like
> So, like this?
>  texture
>   finish
>    emission pi/0.00006
>    ambient  0
>    diffuse  0
That should work.
Date: 14 Sep 2016 10:10:00
Message: <web.57d95a2be29f651b488d9aa0@news.povray.org>
The
> physical sense.
Does that include fluorescence, such as the widespread use of optical
brighteners in laundry detergents and printer paper?
(I'm not trying to claim that the actual reflected light intensity would exceed
the incident light in practice, in those two examples, but in theory I suppose
it might be possible?
Date: 14 Sep 2016 10:38:30
Message: <57d960e6@news.povray.org>
Le 14/09/2016 à 16:09, Bald Eagle a écrit :
> clipka <ano### [at] anonymousorg> wrote:
> The
>> physical sense.
Azurant... convert UV-radiation (invisible) into visible spectrum
(usually by doubling the wavelength). Black light is using the same system.
IMHO, you would need a non-diagonal matrix as pigment instead of a
vector to model such things (one column/row per wavelength) and a wider
vector for the light itself... and at the end, the camera collapse the
wider vector into the RGB value for the picture format.
Our traditional pigment would just be a pure diagonal matrix (everything
out of the main diagonal is 0).
Date: 14 Sep 2016 10:38:40
Message: <57d960f0$1@news.povray.org>
Am 14.09.2016 um 16:09 schrieb Bald Eagle:
> The
>> physical sense.
Even with fluorescence, technically values above 1 make no sense. But to
model this, colours would have to be matrices rather than vectors, and
one of the channels will be UV light, which doesn't show up in the image.
