POV-Ray : Newsgroups : povray.binaries.images : Water: povray play with -1000 Server Time
17 Jun 2024 21:39:47 EDT (-0400)
  Water: povray play with -1000 (Message 1 to 10 of 40)
Subject: Water: povray play with -1000
Date: 25 Mar 2016 18:30:01
Message: <web.56f5bb8db518720d7a3e03fe0@news.povray.org>
See:
http://blender3d.org.ua/book/ocean/img/430.jpg
http://blender3d.org.ua/book/ocean/img/432.jpg
http://blender3d.org.ua/book/ocean/img/438.jpg
We can't make it in Povray.
If we will lower the camera below water level...
Where praised caustic of Povray?
I saw lessons here:
http://www.f-lohmueller.de/pov_tut/backgrnd/p_wat1.htm
I have a lesson of the Blender which was before: night ocean.
I don't represent as to make it in Povray.
If to lower the camera in water...
Download 'night_ocean.jpg' (42 KB)
Preview of image 'night_ocean.jpg'
Subject: Re: Water: povray play with -1000
Date: 26 Mar 2016 03:30:00
Message: <web.56f63993c8daa11fd6b6fe10@news.povray.org>
"LanuHum" <Lan### [at] yandexru> wrote:
> See:
> I saw lessons here:
I believe that PoV-Ray can simulate all of these results.  I know the theory,
but it would probably take someone better than me to do it.
1) start with a solid height_field or isosurface for the water geometry
2) give the water a good material with fade_distance and fade_power
3) use SSLT for the sea foam,or a scattering media with an aoi pattern for the
density.
for caustics, you would need to use photons.
A.D.B.
Date: 26 Mar 2016 03:45:54
Message: <56f63e32$1@news.povray.org>
On 25-3-2016 23:28, LanuHum wrote:
> See:
> I saw lessons here:
Hmmm. Tim Nikias and Marc Jacquier come to mind when ocean surfaces are
mentioned. I think they (and others, no doubt) did this. Nice sea
surface by the way :-)
I did this, based on code by Marc by the way:
http://www.irtc.org/ftp/pub/stills/2005-04-30/direpass.jpg
Date: 26 Mar 2016 04:50:27
Message: <56f64d53@news.povray.org>
On 26-3-2016 8:45, Thomas de Groot wrote:
> Hmmm. Tim Nikias and Marc Jacquier come to mind ...
My memory played me wrong. Not Tim Nikias but Tek. With his code it
seems I did this.
Download 'tek_roughsea_.png' (598 KB)
Preview of image 'tek_roughsea_.png'
Date: 26 Mar 2016 06:00:01
Message: <web.56f65cedc8daa117a3e03fe0@news.povray.org>
> Regards,
> A.D.B.
It is exotic! How to apply them in animation? If it is necessary to add splashes
and to simulate a sea surf?
To add splashes, I shall have exact coordinates of points of a surface.
But, I am interested in texturing of a mesh and animation of textures.
Date: 26 Mar 2016 06:20:01
Message: <web.56f661d5c8daa117a3e03fe0@news.povray.org>
> Thomas
Sea is mesh?
I want to simulate a sea surf. :)
Download 'surf.blend.jpg' (145 KB)
Preview of image 'surf.blend.jpg'
Date: 26 Mar 2016 07:12:57
Message: <56f66eb9$1@news.povray.org>
>> Thomas
> Sea is mesh?
Isosurface If I remember correctly.
Regards
Date: 26 Mar 2016 08:16:56
Message: <56f67db8$1@news.povray.org>
>>> Thomas
>> Sea is mesh?
Yep. Isosurface.
To make an animation of a sea surface, I just don't know how to do that
I am afraid.
Date: 26 Mar 2016 09:10:00
Message: <web.56f6895cc8daa117a3e03fe0@news.povray.org>
> Yep. Isosurface.
> I am afraid.
> Thomas
Thomas!
I don't ask to do animation. You the master to do very beautiful textures. How
to set up and what to use patterns?
Date: 26 Mar 2016 09:34:05
Message: <56f68fcd@news.povray.org>
>>>> Thomas
>>> Sea is mesh?
> Yep. Isosurface.
> I am afraid.
Yes, beyond me too and my PC, I suspect.
Using a series of meshes or heightfields should be possible. I remember
using a 3DMax plugin to create a mesh of bow waves. The resolution was
not good enough to use in close ups. I think that it could be acceptable
if you shrouded it in particles for the spray.
Regards
